Issue with logic on while loop clause
IDE 1.8.19
I am sure I have had this issue more than once and worked arround it , but it's bugging me... No mater what I try , I can't get a logical "or" "||" to work , adding extra () does not help. It compiles ok, uploads ok but when a clause is met, it does not seem to do anything, it never drops out of the loop and just keep decrementing.
the below is just a test code , I know my IDE is out of date but this seems fairly fundamental.
TIA..
Rob
int step1 = 100;
int step2 = 50;
  while ( step1 != 0 or step2 != 0  ) {
    Serial.println(step1);
    Serial.println(step2);
    step1--;
    step2--;
    delay(300);
  delay (5000);
  Serial.println("zero");
  step1 = 100;
Yes, reading your code, that's exactly what I would expect. The loop would only stop if both variables are zero at the same time, which is never.
Look up DeMorgan's law...
is the same as
while ( not(step1 == 0 and step2 == 0)  ) {
Would you ever expect the loop to stop with that test?
What did you want it to do?
Indeed. This is how C code works, how logic works, nothing to do with the version of the IDE.
Perhaps you meant to use and ?
The issue with your while loop condition is that you're using or (||) instead of and (&&). Currently, the loop will continue as long as either step1 or step2 is not zero. If you want the loop to stop when either variable reaches zero, you should use and (&&).
Here's the corrected version:
int step1 = 100;
int step2 = 50;
  while (step1 != 0 && step2 != 0) {  // Changed 'or' to 'and'
    step1--;
    step2--;
    delay(300);
  delay(5000);
  step1 = 100;
The loop will now stop when either step1 or step2 reaches zero
&& ... yes both constrains need to be true to maintain the loop.
It's been a long week.
Thanks all..
