I accidentally pressed the reset switch at the same time I was downloading a program and something strange happened. I can't download anymore but the port shows up.
I attached some screen grabs.
When I try to download I get:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\joker\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM6
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\.\COM6": The system cannot find the file specified.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
Did I lose the bootloader? Any suggestions.
Thanks
