Hi Sir/Madam,
I’m trying to interface arduino compatible Camera and GSM module with Arduino Uno.
To keep the demo kit compact and good looking I preferred this layered/stack approach. I tested both individually with Arduino Uno and they are working. but when I stack them it is not working.
The Camera Module details: http://www.seeedstudio.com/wiki/Camera_Shield
The GSM module Details:
http://www.ebay.in/itm/301311860023?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
The code i used:
#include <VC0706_UART.h>
#include "SoftwareSerial.h"
#include <SD.h>
#include <SPI.h>
#define SS_SD 10
//use software serial
SoftwareSerial cameraconnection(2,3);//Rx, Tx
VC0706 cam = VC0706(&cameraconnection);
//use hardware serial
//VC0706 cam = VC0706(&Serial);
//GSM MODULE CODE SECTION
Serial.print("\r");
Serial.print("AT+CMGF=1\r");
Serial.print("AT+CMGS=\"+919884969933\"\r"); //Number to which you want to send the sms
Serial.print("SMS- HELLO RALAK\r"); //The text of the message to be sent
Serial.write(0x1A);
//CAMERA MODULE AND SD CARD CODE SECTION
Serial.println("VC0706 Camera Snapshot Test ...");
if (!SD.begin(SS_SD)) {
Serial.println("SD Card init failed...");
return;
if(true == cameraInit()){
snapShot();
}else{
Serial.println("camera init error...");
//nothing to do
bool cameraInit()
cam.begin(BaudRate_19200);
char *reply = cam.getVersion();
if (reply == 0) {
Serial.println("Failed to get version");
return false;
Serial.println("version:");
Serial.println("-----------------");
Serial.println(reply);
return true;
void snapShot()
Serial.println("Snap in 3 secs...");
delay(3000);
if (! cam.takePicture()){
Serial.println("Failed to snap!");
}else {
Serial.println("Picture taken!");
// Create an image with the name IMAGExx.JPG
char filename[13];
strcpy(filename, "IMAGE00.JPG");
for (int i = 0; i < 100; i++) {
filename[5] = '0' + i/10;
filename[6] = '0' + i%10;
// create if does not exist, do not open existing, write, sync after write
if (! SD.exists(filename)) {
// Open the file for writing
File imgFile = SD.open(filename, FILE_WRITE);
Serial.print("create ");
Serial.println(filename);
uint16_t jpglen = cam.getFrameLength();
Serial.print("wait to fetch ");
Serial.print(jpglen, DEC);
Serial.println(" byte image ...");
int32_t time = millis();
cam.getPicture(jpglen);
uint8_t *buffer;
while(jpglen != 0){
uint8_t bytesToRead = min(32, jpglen);
buffer = cam.readPicture(bytesToRead);
imgFile.write(buffer, bytesToRead);
//Serial.print("Read "); Serial.print(bytesToRead, DEC); Serial.println(" bytes");
jpglen -= bytesToRead;
imgFile.close();
time = millis() - time;
Serial.println("Done!");
Serial.print("Took "); Serial.print(time); Serial.println(" ms");
cam.resumeVideo();
I hope there is no issue with the code and only with h/w.
Note : The GSM module supplier told it needs 12V…And I did. but is it still not sufficient to the third layer camera module?. but for Camera module i think only 5V sufficient.
Thanks
