Issue with my code
Hey Im trying to build a car with a rgb led, temp sensor, button to controll rgb colors, petentiometer, my code is as follows, not sure what I did wrong, I probably did something wrong, So if someone can help that would be awesome! First time using this software sorry bois
SparkFun Inventor's Kit
Example sketch 13
SparkFun Motor Controller with Inputs
Use the inputs to manually set the direction and speed of a motor.
This sketch was written by SparkFun Electronics,
with lots of help from the Arduino community.
This code is completely free for any use.
Visit http://learn.sparkfun.com/products/2 for SIK information.
Visit http://www.arduino.cc to learn more about Arduino.
//define the two direction logic pins and the speed / PWM pin
const int DIR_A = 5;
const int DIR_B = 4;
const int PWM = 6;
const int RED_PIN = 13;
const int GREEN_PIN = 12;
const int BLUE_PIN = 11;
int DISPLAY_TIME = 10;
//define the input pins
const int switchPin = 10;
const int potPin = 0;
//set all pins as output
pinMode(DIR_A, OUTPUT);
pinMode(DIR_B, OUTPUT);
pinMode(PWM, OUTPUT);
//set the switchPin as INPUT
pinMode(switchPin, INPUT);
//set the three pin variables as outputs
pinMode(RED_PIN, OUTPUT);
pinMode(GREEN_PIN, OUTPUT);
pinMode(BLUE_PIN, OUTPUT);
// We've written a custom function called mainColors() that steps
// through all eight of these colors. We're only "calling" the
// function here (telling it to run). The actual function code
// is further down in the sketch.
mainColors(); {
if (digitalRead(switchPin) == HIGH)
void mainColors()
// Off (all LEDs off):
digitalWrite(RED_PIN, LOW);
digitalWrite(GREEN_PIN, LOW);
digitalWrite(BLUE_PIN, LOW);
//wait 1 second
// Red (turn just the red LED on):
digitalWrite(RED_PIN, HIGH);
//wait 1 seconds
// Green (turn just the green LED on):
digitalWrite(GREEN_PIN, HIGH);
//wait 1 second
// Blue (turn just the blue LED on):
digitalWrite(BLUE_PIN, HIGH);
//wait 1 second
// Yellow (turn red and green on):
//wait 1 second
// Cyan (turn green and blue on):
//wait 1 second
// Purple (turn red and blue on):
//wait 1 second
// White (turn all the LEDs on):
//wait 1 second
//read the value from the potentiometer and divide
//it by 4 to get a 0-255 range. Store the value in
//the speed variable
int speed = analogRead(potPin) / 4;
//read the value of the switch and store it in the
//direction variable.
//if the value of direction is HIGH drive forward at
//a speed set by the speed variable, else drive reverse
//at a speed set by the speed variable.
forward(speed);
reverse(speed);
//create a custom function that defines moving forward
//the forward() function accepts one parameter and that is
//the speed at which you want to drive forward (0-255)
void forward(int spd)
//motor contoller direction pins set to forward
digitalWrite(DIR_A, HIGH);
digitalWrite(DIR_B, LOW);
//write the speed by using the parameter of spd
analogWrite(PWM, spd);
//create a custom function that defines moving in reverse
//the reverse() function accepts one parameter and that is
//the speed at which you want to drive in reverse (0-255)
void reverse(int spd)
//set motor controller pins to reverse
digitalWrite(DIR_A, LOW);
digitalWrite(DIR_B, HIGH);
You didn't tell us what the problem is.
This part has several mistakes and will not compile:
Look carefully at the number and position of curly brackets in the loop() function. Auto Format the code in the IDE to help see the problem.
Hey I know that is the issue.
Looking on directions from on here and on.
When I try and upload the code to arduino it shoots out a error on the part on the portion the user reported above me.
Here is the program Auto Formatted in the IDE and in code tags
const int PWM = 6;
  mainColors();
    void mainColors()
      //wait 1 second
      //wait 1 seconds
      //wait 1 second
      //wait 1 second
      //wait 1 second
      //wait 1 second
      //wait 1 second
      //wait 1 second
      forward(speed);
      reverse(speed);
Each function should start with a { and end with a }
The block of code to be executed conditionally should start with a { and end with a }
Every { should have a corresponding }
Start by fixing those problems
