Greetings,
I have recently acquired a NFC Module for Arduino SKU: DFR0231 to produce a prototype security system, however I cannot manage to get the shield to wake up.
The following is expected when waking up the reader:
#wake up reader
send: 55 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 03 fd d4 14 01 17 00
return: 00 00 FF 00 FF 00 00 00 FF 02 FE D5 15 16 00
In my case all I am getting back is:
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
I am using the code provided in the documentation ( http://www.dfrobot.com/wiki/index.php/NFC_Module_for_Arduino_(SKU:DFR0231) ) for the exception that I am using SoftwareSerial rather than Serial1 (Arduino Uno).
PN532 reads the tag by Arduino mega/Leonardo
command list:
#wake up reader
#get firmware
send: 00 00 FF 02 FE D4 02 2A 00
return: 00 00 FF 00 FF 00 00 00 FF 06 FA D5 03 32 01 06 07 E8 00
#read the tag
send: 00 00 FF 04 FC D4 4A 01 00 E1 00
return: 00 00 FF 00 FF 00 00 00 FF 0C F4 D5 4B 01 01 00 04 08 04 XX XX XX XX 5A 00
XX is tag.
const unsigned char wake[24]={0x55,0x55,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0x03,0xfd,0xd4,0x14,0x01,0x17,0x00};//wake up NFC module
const unsigned char firmware[9]={0x00,0x00,0xFF,0x02,0xFE,0xD4,0x02,0x2A,0x00};//
const unsigned char tag[11]={0x00,0x00,0xFF,0x04,0xFC,0xD4,0x4A,0x01,0x00,0xE1,0x00};//detecting tag command
unsigned char receive_ACK[25];//Command receiving buffer
int inByte = 0; //incoming serial byte buffer
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#define print1Byte(args) Serial1.write(args)
#define print1lnByte(args) Serial1.write(args),Serial1.println()
#else
#include "WProgram.h"
#define print1Byte(args) Serial1.print(args,BYTE)
#define print1lnByte(args) Serial1.println(args,BYTE)
#endif
#include <SoftwareSerial.h>
SoftwareSerial Serial1(10,11);
Serial.begin(9600); // open serial??et Baund rate 9600 bps
Serial1.begin(115200);
//Serial2.begin(115200);
wake_card();
delay(100);
array_ACK(15);
delay(100);
dsplay(15);
if (Serial.available() > 0)
// get incoming byte:
inByte = Serial.read();
if (inByte=='r')
read_tag();
delay(100);
array_ACK(25);
delay(100);
dsplay(25);
else if (inByte=='v')
firmware_version();
delay(100);
array_ACK(19);
delay(100);
dsplay(19);
void UART1_Send_Byte(unsigned char command_data)
//Serial1.print(command_data);
print1Byte(command_data);// command send to device
Serial1.flush();// complete the transmission of outgoing serial data
#endif
void UART_Send_Byte(unsigned char command_data)//, unsigned charBYTE
Serial.print(command_data,HEX);
Serial.print(" ");
void array_ACK(unsigned char temp)
for(unsigned char i=0;i<temp;i++)
receive_ACK[i]= Serial1.read();
delay(100);
void wake_card(void)
unsigned char i;
for(i=0;i<24;i++) //send command
UART1_Send_Byte(wake[i]);
void firmware_version(void)
unsigned char i;
for(i=0;i<9;i++) //send command
UART1_Send_Byte(firmware[i]);
void read_tag(void)
unsigned char i;
for(i=0;i<11;i++) //send command
UART1_Send_Byte(tag[i]);
void dsplay(unsigned char tem)
unsigned char i;
for(i=0;i<tem;i++) //send command
UART_Send_Byte(receive_ACK[i]);
Does anyone have any experience with this module or can give me an insight or what could be causing the issue? I have already double check the connections and attempted to run in different OS with the same result.
Best Regards.
