issue with output given by motor encoder encoder
i have a hall effect encoder motor
encoder_motor
pulse per minute =827.1
i am using the following code for getting no of pulse per sec then converting it to rpm
volatile  int  count=0;
 float rpm=0.00;
pinMode(2,INPUT);
  //interrupts();
  attachInterrupt(0,countf,RISING);
  delay(1000);// use delay to give time to motor to count no of pulse in 1 sec.
  Serial.println(count);
  detachInterrupt(0);
   rpm=count*(60.000/823.10000); //converting pulse per sec to rpm
  Serial.print("rpm=");
  Serial.println(rpm);
  count=0;
void countf()
  count=count+1;
but i am getting a weird output
its rpm value is not stable it is getting decreasing
please see attached file for output
please help me here
Why is count a float when what you do in the ISR is to add 1 to it ?
@UKHELLBOb even if i change the the data type of count to int does it change the output that i am getting?
That is the worst possible way to count interrupts per second.
  count=0;
Count is not a byte sized variable, so resetting it is not an atomic operation. An interrupt could occur between setting the high order byte to 0 and setting the low order byte to 0. If the low order byte is 255 when that happens, the resulting value in count will be all hosed up.
thats why i have used detachinterrupt() before setting the count to zero.
Give this a try, untested.
unsigned long start;
const byte encoderPinA = 2;//A pin -> the interrupt pin 0
volatile long pulse;//the number of the pulses
int fin = 250, rpm;
  // initialize serial:
  attachInterrupt(0, readEncoder, FALLING);
  pinMode(encoderPinA,INPUT);
  if(millis() - start > fin){
  noInterrupts();
  rpm = pulse * 240 / 11;
  interrupts();
  Serial.print(rpm);Serial.print(" \t"); // motor RPM
  Serial.println(rpm / 74.83);           // shaft RPM
  pulse = 0;
  start = millis();
void readEncoder()
  ++pulse;
