I am using two motor drivers from sparkfun (SN754410 which is a replacement for a L293D) to control four 5V dc motors using a battery pack of four AA batteries. When I started test running some simple code to move the robot using the Arduino IDE, I notice that sometimes the motors would get stuck and not move when placed on the floor. This isn't an issue when I lay the robot on its "back" since all the motors run fine in that configuration.
I believe that the h bridge motor drivers lowers either the voltage or current (maybe both) so I'm trying to find an alternative right now to fix this issue of stuck motors whether it be a different source of power such as LiPo.
Any advice on how to fix this issue since I'm using this robot for path planning and I don't want the robot to drift from its assigned course.
Additional Information:
I am separately powering the arduino using another four AA battery pack so its not supplying the power to both motors and arduino.
There could also be an issue with weight(?) since I have everything on top of the robot.
