Issue with PWM statement
Hello all. Some days I just hate Arduinos >:(
Running a fan on PWM.
const int Lift_fan = 3;
int Lift_fan_speed=500; //Lift fan start speed
If I write:
analogWrite(Lift_fan,500);
Then all is well. The fan starts, I can adjust that second value and control the speed.
But.... if I write:
analogWrite(Lift_fan,Lift_fan_speed);
It doesn't work. The motor doesn't run.
Lift_fan_speed shows as a value of 500 in debug.
Eh? What is the difference between the analogWrite using a fixed value and a variable?
There is no difference.
The problem must be elsewhere. Show us the rest of the code.
The problem is that analogWrite is only 0-255. Not 0-1023 as I assumed (as analogRead is).
However, I have noted that I don't seem to be able to increment the value Lift_fan_speed by saying:
if (something happens) {Lift_fan_speed++;}
It refuses to allow that.
I will have to lift the code when I get back
Arduino_Steve:
It’s a poor craftsman who blames his tools.
Arduino_Steve:
Yeah that's true, I didn't spot that. It shouldn't make a difference though, whether 500 is a literal or the value of a variable the results should be the same.
That should be fine too. How does it refuse to allow it? Does it refuse to compile? Does it crash? Some other expected result?
gfvalvo:
No… its a flu riddled, fed up, tired man who blames his tools…
I just don’t get it, so walking a way for a bit.
It’s an odd one. As soon as I I change the value of Lift_fan_speed, the code hangs and will not run… at all.
If I say:
if (Sensor>100) {}
analogWrite(Lift_fans,Lift_fan_speed);
Then the motor turns at the speed (Lift_fan_speed) that was declared at the start of the program.
but, if I say:
if (Sensor>100) {Lift_fan_speed=200;}
Then code code will compile, but not run.
There are no other instances of Lift_fans or Lift_fan_speed in the code at all.
Bizarre (but probably some quirk of Arduinos I don’t understand).
We still have not seen a complete program that illustrates the problem.
UKHeliBob:
Relax… mere half an hour since op said he would post when he gets back, presumably to where the sketch is.
