issue with RC PPM(in) to PWM(out) -voltage wrapping..?
hey! im fairly new to this whole code/sketch thing -
ive found some pre-written code - trying to modify it for my own project -
the issue im having seems to be related to specifying the reading in milliseconds PPM between pulses
FYI - I’m using the interrupt method for reading things
things work fine with my RC controller when making small movements with the control stick - and PWM output voltages swing up and down smoothly -
BUT
when i move the control sticks to any FULL position (pushing all the way) the PWM output voltage rises from 2.5v (center position) up to about 3.4v - THEN itll drop down low for some reason when pushing stick to max position…
only thing i can think of, is the code im using is looking for a max pulse of about 1800ms and i cant figure out how to adjust it…?
have done a lot of searching all over the intewebs but cant quite figure out whats going on here
im attaching a short 60 second video to help illustrate my issue
thanks for any help / guidance!!
-Dan
Here’s the code im using currently
(i chopped out some of the comments to keep this post under 9000 characters)
// Assign your channel in pins
#define FORWARD_REVERSE_PIN 7
#define RIGHT_LEFT_PIN 8
#define AUX_IN_PIN 12
// Assign your channel out pins
#define FORWARD_REVERSE_OUT_PIN 3
#define FORWARD_REVERSE_OUT_INV_PIN 9
#define RIGHT_LEFT_OUT_PIN 10
#define RIGHT_LEFT_OUT_INV_PIN 11
#define AUX_OUT_PIN 6
// These bit flags are set in bUpdateFlagsShared to indicate which
// channels have new signals
#define FORWARD_REVERSE_FLAG 1
#define RIGHT_LEFT_FLAG 2
#define AUX_FLAG 4
// holds the update flags defined above
volatile uint8_t bUpdateFlagsShared;
// shared variables are updated by the ISR and read by loop.
// In loop we immediatley take local copies so that the ISR can keep ownership of the
// shared ones. To access these in loop
// we first turn interrupts off with noInterrupts
// we take a copy to use in loop and the turn interrupts back on
// as quickly as possible, this ensures that we are always able to receive new signals
volatile uint16_t unForwardReverseInShared;
volatile uint16_t unRightLeftInShared;
volatile uint16_t unAuxInShared;
// These are used to record the rising edge of a pulse in the calcInput functions
// They do not need to be volatile as they are only used in the ISR. If we wanted
// to refer to these in loop and the ISR then they would need to be declared volatile
uint32_t ulForwardReverseStart;
uint32_t ulRightLeftStart;
uint32_t ulAuxStart;
uint32_t timer = 0;
  // define variables for later
  int ForwardReverse;
  int ForwardReverseInv;
  float ForwardReversePWM;
  int RightLeft;
  int RightLeftInv;
  float RightLeftPWM;
  Serial.println("rOcK oN");
  // set PWM pins as outputs
  pinMode(FORWARD_REVERSE_OUT_PIN, OUTPUT);
  pinMode(FORWARD_REVERSE_OUT_INV_PIN, OUTPUT);
  pinMode(RIGHT_LEFT_OUT_PIN, OUTPUT);
  pinMode(RIGHT_LEFT_OUT_INV_PIN, OUTPUT);
  pinMode(AUX_OUT_PIN, OUTPUT);
 // set pins to 2.5 volts, joystick centered
  analogWrite(FORWARD_REVERSE_OUT_PIN, 128);
  analogWrite(FORWARD_REVERSE_OUT_INV_PIN, 128);
  analogWrite(RIGHT_LEFT_OUT_PIN, 128);
  analogWrite(RIGHT_LEFT_OUT_INV_PIN, 128);
  // analogWrite(AUX_OUT_PIN, 128)
  // using the PinChangeInt library, attach the interrupts
  // used to read the channels
  PCintPort::attachInterrupt(FORWARD_REVERSE_PIN, calcForwardReverse,CHANGE);
  PCintPort::attachInterrupt(RIGHT_LEFT_PIN, calcRightLeft,CHANGE);
  PCintPort::attachInterrupt(AUX_IN_PIN, calcAux,CHANGE);
   delay(50);  // add delay to allow trasmitter to power up and prevent bad readings
  // create local variables to hold a local copies of the channel inputs
  // these are declared static so that thier values will be retained
  // between calls to loop.
  static uint16_t unForwardReverseIn = 1480;  //initialize to neutral position to prevent unintended motion
  static uint16_t unRightLeftIn = 1480;
  static uint16_t unAuxIn;
  // local copy of update flags
  static uint8_t bUpdateFlags;
  // set all output to neutral if no signal - FAIL SAFE FOR LOST RECEPTION
  if(millis()-timer > 1000)
   Serial.println("No Signal");
  // check shared update flags to see if any channels have a new signal
  if(bUpdateFlagsShared)
    noInterrupts(); // turn interrupts off quickly while we take local copies of the shared variables
    timer = millis();
    // take a local copy of which channels were updated in case we need to use this in the rest of loop
    bUpdateFlags = bUpdateFlagsShared;
    // in the current code, the shared values are always populated
    // so we could copy them without testing the flags
    // however in the future this could change, so lets
    // only copy when the flags tell us we can.
    if(bUpdateFlags & FORWARD_REVERSE_FLAG)
      unForwardReverseIn = unForwardReverseInShared;
    if(bUpdateFlags & RIGHT_LEFT_FLAG)
      unRightLeftIn = unRightLeftInShared;
    if(bUpdateFlags & AUX_FLAG)
      unAuxIn = unAuxInShared;
    // clear shared copy of updated flags as we have already taken the updates
    // we still have a local copy if we need to use it in bUpdateFlags
    bUpdateFlagsShared = 0;
    interrupts();
  // we are checking to see if the channel value has changed, this is indicated
  // by the flags. For the simple pass through we don't really need this check,
  // but for a more complex project where a new signal requires significant processing
  // this allows us to only calculate new values when we have new inputs, rather than
  // on every cycle.
  // Radio signal; 1056 = full reverse; 1480 = neutral, 1884 = full forward
  // Output PMW; 77 = Full Reverse, 128 = neutral, 179 = full forward
  if (unForwardReverseIn < 1500 && unForwardReverseIn > 1450)  // Create deadband
    ForwardReverse = 128;
    ForwardReverseInv = 128;
    analogWrite(FORWARD_REVERSE_OUT_PIN, ForwardReverse);
    analogWrite(FORWARD_REVERSE_OUT_INV_PIN, ForwardReverseInv);
    Serial.println(ForwardReverse);
    ForwardReversePWM = (unForwardReverseIn-1056)/8.11;
    ForwardReverse = 77 + (int) ForwardReversePWM;
    ForwardReverseInv = 179 - (int) ForwardReversePWM;
    // Serial.println(unForwardReverseIn);
    // Serial.println(ForwardReverse);
  if (unRightLeftIn < 1500 && unRightLeftIn > 1450)  // Create deadband
    RightLeft = 128;
    RightLeftInv = 128;
    analogWrite(RIGHT_LEFT_OUT_PIN, RightLeft);
    analogWrite(RIGHT_LEFT_OUT_INV_PIN, RightLeftInv);
    Serial.println(RightLeft);
   // Serial.println(unRightLeftIn);
    RightLeftPWM = (unRightLeftIn-1056)/8.11;
    RightLeft = 77 + (int) RightLeftPWM;
    RightLeftInv = 179 - (int) RightLeftPWM;
    // Serial.println(RightLeft);
// simple interrupt service routine
void calcForwardReverse()
  // if the pin is high, its a rising edge of the signal pulse, so lets record its value
  if(digitalRead(FORWARD_REVERSE_PIN) == HIGH)
    ulForwardReverseStart = micros();
    // else it must be a falling edge, so lets get the time and subtract the time of the rising edge
    // this gives use the time between the rising and falling edges i.e. the pulse duration.
    unForwardReverseInShared = (uint16_t)(micros() - ulForwardReverseStart);
    // use set the throttle flag to indicate that a new throttle signal has been received
    bUpdateFlagsShared |= FORWARD_REVERSE_FLAG;
void calcRightLeft()
  if(digitalRead(RIGHT_LEFT_PIN) == HIGH)
    ulRightLeftStart = micros();
    unRightLeftInShared = (uint16_t)(micros() - ulRightLeftStart);
    bUpdateFlagsShared |= RIGHT_LEFT_FLAG;
void calcAux()
  if(digitalRead(AUX_IN_PIN) == HIGH)
    ulAuxStart = micros();
    unAuxInShared = (uint16_t)(micros() - ulAuxStart);
    bUpdateFlagsShared |= AUX_FLAG;
You are using uint16_t type variables to measure your pulsewitdh in microseconds. That means you only get 65535 usec or 65.5 msec of measurement but you said you go up to 1800 msec. You need to use uint32_t variables to measure something that large.
thanks!
ive switched to uint64_t variables now - and its working!!
uint_64_t is not needed. Why did you choose that? The 32 bit (unsigned long) is more typical since micros() reutrns 'unsigned long'
Either way, it will work...
i used 32 and still had the same issue.. it was slightly better -
got a bit more movement from the control stick before it dropped off..
but figured id bump up to 64, and seemed to do the trick!
You should really try to understand why. If not you’ll just come a cropper next time when you make the same mistake.
Also 8-bit micros don’t have a lot of resources (memory or clock cycles) and doubling up on storage is very wasteful of both.
Perhaps post your modified code so we can see where the issue is?
For readability and to aid understanding I would also suggest not mixing int/unsigned int and the equivalent standard portable types int16_t/uint16_t.
Use one or the other, not both. My personal preference is for int16_t/uint16_t etc. because they make the size and limitations of the type chosen clear.
I’d love to learn what all this means - been going thru things and looking up each part, learning how it works etc…
im controlling a wheelchair joystick - emulating the voltage swings it would usually see from its own hardware. (now disconnected)
up/down/left/right
the voltage swing i measured is approx 1v - 2.5v(neutral) - 3.8v
this is the same sweep for both of the axis’s
for example when pushing forward, one axis needs voltage to rise, and the inverted one needs to fall by the same rate
this exact code was from someone else who had it working on his setup - but i think he was using a different RC transmitter/receiver…
the way ive learned in the past is finding something similar and cropping out the bits i can use and combining with others
I’d like to write my own from scratch… but itll be a while before i get my head around a new language
this is my modified code im now using that has been working reliably… but no clue if its wasting resources/overhead etc…
any input is appreciated!
// MultiChannels
// rcarduino.blogspot.com
// include the pinchangeint library - see the links in the related topics section above for details
#include <PinChangeInt.h>
// #define AUX_IN_PIN 12
// #define AUX_OUT_PIN 6
// #define AUX_FLAG 4
volatile uint64_t bUpdateFlagsShared;
volatile uint64_t unForwardReverseInShared;
volatile uint64_t unRightLeftInShared;
volatile uint64_t unAuxInShared;
uint64_t ulForwardReverseStart;
uint64_t ulRightLeftStart;
// uint32_t ulAuxStart;
uint64_t timer = 0;
  int ForwardReverse;
  int RightLeft;
  int RightLeftInv;
  float RightLeftPWM;
  // pinMode(AUX_OUT_PIN, OUTPUT);
  // PCintPort::attachInterrupt(AUX_IN_PIN, calcAux,CHANGE);
  static uint64_t unForwardReverseIn = 1480;  //initialize to neutral position to prevent unintended motion
  static uint64_t unRightLeftIn = 1480;
  // static uint32_t unAuxIn;
  static uint64_t bUpdateFlags;
    timer = millis();
//    if(bUpdateFlags & AUX_FLAG)
//      unAuxIn = unAuxInShared;
    interrupts(); // we have local copies of the inputs, so now we can turn interrupts back on
    // as soon as interrupts are back on, we can no longer use the shared copies, the interrupt
    // service routines own these and could update them at any time. During the update, the
    // shared copies may contain junk. Luckily we have our local copies to work with :-)
  // on every cycle.
    RightLeft = 128;
    RightLeftInv = 128;
    unForwardReverseInShared = (uint64_t)(micros() - ulForwardReverseStart);
    unRightLeftInShared = (uint64_t)(micros() - ulRightLeftStart);
