Issue with Reading SD Card Formatted Using SDFat library on ESP32
I tried the code below to format an SD card using the SDFat library on an ESP32, and it works fine. However, when I try to read the SD card using the default Arduino SD.h library, it fails. Specifically, SD.begin(SD_cs) does not work, and the card cannot be read.
Interestingly, I can still open the SD card on my PC without any issues. and add files there
Has anyone encountered a similar problem or know how to fix this?
#include <SPI.h>
#include <SdFat.h>
const uint8_t chipSelect = 5; // Define the chip select pin for the SD card module
SdFat SD; // Create an SdFat object
  while (!Serial) {
    ; // Wait for serial port to connect (needed for native USB)
  Serial.println("Type 'format' to format the SD card.");
  if (Serial.available() > 0) {
    String command = Serial.readStringUntil('\n');
    command.trim();
    if (command == "format") {
      formatSDCard();
void formatSDCard() {
  // Initialize the SD card with default SPI pins
  if (!SD.begin(chipSelect, SD_SCK_MHZ(25))) {
    Serial.println("Initialization failed. Is the SD card inserted?");
    return; // Exit the function if initialization fails
  // Attempt to format the SD card
  if (!SD.format()) {
    Serial.println("Formatting failed.");
    return; // Exit the function if formatting fails
  Serial.println("Formatting completed successfully.");
Why format it when it accepts data? Move on...
i used MiniTool Partition Wizard (Free) to check difference in sd formated on pc and via sp32
