Issue with reading serial data
Anand_kumar:
I did try a code with RDY/CLK in past, but like I said, I need to write a whole new code without any reference to EM4095. So, I started this post without any reference to that module as it might again mislead to EM4095 and using its reference code, that I shouldn't be using.
I used pin 2 of the Arduino in past for the RDY/CLK signal, but like I said, it's not involved in my present project, I just mentioned about those modules for idea purpose only.
Surely from next time, I'll post much clearer with more references.
Thank you guys once again for the help.
So how do you detect start of the data pulse, you can't use the data stream to detect the pulse start as there will be no pulse start to a ZERO data bit.
You have to be synchronized to the data stream.
Tom.... :slight_smile:
