Hello,
I am trying to setup an automatic voice recorder, which records to a SD card with the correct file date. I can get the recording to work, and I can get the file date to work. However, with both in use it will create a file, but the file will not have any audio data.
Board- ProMini
RTC- DS3232
SD- SanDisk A1 (64GB)
Microphone- MAX9814
SD holder- Generic one.
#include <TMRpcm.h>
#include <SD.h>
#include <SPI.h>
#include <Wire.h>
#include <DS3232RTC.h>
const uint8_t CS = 10; // SD chip select
void dateTime(uint16_t* date, uint16_t* time)
setSyncProvider(RTC.get);
*date = FAT_DATE(year(), month(), day());
*time = FAT_TIME(hour(), minute(), second());
TMRpcm audio;
int file_number = 0;
char filePrefixname[50] = "Test";
char exten[10] = ".wav";
const int recordLed = 7;
const int mic_pin = 14;
const int sample_rate = 16000;
#define SD_CSPin 10
// delay function for with serial log.
void wait_sec(int secs) {
int count = 0;
// int secs = 1;
while (1) {
Serial.print('.');
count++;
if (count == secs) {
count = 0;
return ;
//initialises the serial connection between the arduino and any connected serial device(e.g. computer, phone, raspberry pi...)
SdFile::dateTimeCallback(dateTime);
//Sets up the pins
pinMode(mic_pin, INPUT);
pinMode(recordLed, OUTPUT);
Serial.println("loading... SD card");
if (!SD.begin(SD_CSPin)) {
Serial.println("An Error has occurred while mounting SD");
while (!SD.begin(SD_CSPin)) {
Serial.print(".");
audio.CSPin = SD_CSPin;
Serial.println("####################################################################################");
char fileSlNum[20] = "";
itoa(file_number, fileSlNum, 10);
char file_name[50] = "";
strcat(file_name, filePrefixname);
strcat(file_name, fileSlNum);
strcat(file_name, exten);
Serial.print("New File Name: ");
Serial.println(file_name);
digitalWrite(recordLed, HIGH);
audio.startRecording(file_name, sample_rate, mic_pin);
Serial.println("startRecording ");
// record audio for 2mins. means , in this loop process record 2mins of audio.
// if you need more time duration recording audio then
// pass higher value into the wait_min(int mins) function.
wait_sec(10);
digitalWrite(recordLed, LOW);
audio.stopRecording(file_name);
Serial.println("stopRecording");
digitalWrite(7, LOW);
file_number++;
My question is is there something with the SD file dating that is causing the audio to not be recorded?
(P.S. There are no error codes)
