After spending money in newer cards and adapters I found out the problem.
I know that interfacing SD cards is tricky because they need a steady power supply.
So, first I put my power supply in parallel with the 5Volt supplied by the USB port. No success.
Then, I reassemble the whole circuit in a new breadboard, new Arduino, new SD card, new SD adapter,
new SD interface module, new wires... No success.
I was aware about the 3.3V which the SD cards use. But as the SD card module as a 3.3V voltage regulator I though I was OK by powering up the SD with 5V in the input of the 3.3V voltage regulator.
My last idea was to power up the SD card directly with 3.3 Volt.
Voila... It is now working.
I believe that 5V in the input of the voltage regulator is not enough to produce 3.3 Volt and that's why I can create and remove files but not writing into it. Because writing needs more current.
It depends what kind of voltage regulator you are using. Except a low-drop-out ones (which needs 0.5-1V more at the input side) the others may need 2-2.5V volt over the output. Also the modern sdcards may consume 100-200mA peak current during write, a good decoupling is a must..
pito:
It makes perfect sense. That SD board does not have a 5 volt to 3.3 volt logic level converter. If you put 5 volts into the SS, MOSI and SCK pins on the SD card. it will damage the SD card. Maybe not today, but sometime soon.
SurferTim:
The module is marginal but some cards work. Cards that work draw lots of current due to input protection circuits. This drops the input voltage. Probably not best for the card or Arduino.
