I created a video to illustrate my issue, you can find it here: Issue with Seeed Studio Motor Shield V2.0 and Arduino UNO - YouTube
I’m failing to make an Arduino UNO work with a Seeed Studio Motor Shield V2.0 to control a pair of Geeetech Smart Car Tire/Wheel with DC Gear Motor
You can find my code below based on a similar post in the forum. I also tried to make it run with the provided example that includes the library on the wiki with the same results.
I tried using a 9V/170mA battery and a 12V/500mA power adapter. The motor specs are:
Parameter Operating voltage: 3V ~ 12V DC (recommended value is 6 ~ 8V)
Load current: 70mA (250mA MAX)
I don’t think the problem is code related, since I see the LED indicators show the activity expected, as you can see on the video.
Thanks in advance for any help,
Alejandro
#define M1 8
#define M2 11
#define M3 12
#define M4 13
#define SPA 9
#define SPB 10
int i;
for (i=8; i<14; i++) pinMode(i,OUTPUT);
digitalWrite(M1,HIGH); // direction motor 1
digitalWrite(M2,LOW);
digitalWrite(M3,HIGH); // direction motor 2
digitalWrite(M4,LOW);
analogWrite(SPA,130); // 50% to motor 1
analogWrite(SPB,192); // 75% to motor 2
for (i=130; i>0; i--)
analogWrite(SPA,i); // reduce speed Motor 1
delay(50);
digitalWrite(SPB,LOW); // stop motor 2
delay (3000); // wait - then repeat
