issue with servo library
For some reason that i cannot figure out i am getting a verify error when loading my sketch. If i comment everything that has to do with the servo library it compiles fine. If i open a servo example sketch it does not compile and i get this error in both window, the code i am working on and the servo example code all by itself.
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
this is the error
“Show verbose output during compilation”
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: “Arduino Mega 2560 or Mega ADK”
Sweep.cpp.o: In function __static_initialization_and_destruction_0': C:\Program Files\Arduino/Sweep.ino:8: undefined reference to Servo::Servo()’
Sweep.cpp.o: In function loop': C:\Program Files\Arduino/Sweep.ino:23: undefined reference to Servo::write(int)’
C:\Program Files\Arduino/Sweep.ino:28: undefined reference to Servo::write(int)' Sweep.cpp.o: In function setup’:
C:\Program Files\Arduino/Sweep.ino:31: undefined reference to `Servo::attach(int)’
I'd guess that your servo library has gone astray, which is odd since it's part of a standard ide install. Is it in the libraries folder of your install folder?
