Issue with simple program for PLDuino (turning relay on and off)
I am writing the following, simple code to try to turn a relay in the PLDuino on and off, and it is giving me warnings and not compiling/uploading. Any help would be greatly appreciated. Here is my code:
#include <PLDuino.h>
using namespace PLDuino;
  // A necessary call.
  // It sets pin modes according to their function.
  PLDuino::init();
  // Simple switch RELAY3 on and off with 2 second timeout.
  digitalWrite(PLDuino::RELAY3, HIGH);
  delay(2000);
  digitalWrite(PLDuino::RELAY3, LOW);
  delay(2000);
I have installed the proper libraries. Here are the warnings I am getting:
"WARNING: Category 'Graphics' in library PLDTouch is not valid. Setting to 'Uncategorized'
WARNING: Category 'General' in library PLDuino-Library is not valid. Setting to 'Uncategorized'
WARNING: Category 'Graphics' in library PLDuinoGUI is not valid. Setting to 'Uncategorized'
Sketch uses 1702 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "\.\COM4": The system cannot find the file specified.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer"
You selected the wrong serial port on your PC. Choose the serial port in the IDE you have attached your Arduino to.
