Issue with the nRF24L01 module
im making an RC robot, using the nRF24l01 modules to send movement data (yet to be implemented)
I have 2 nRF24l01 modules, I have gotten the transmitter to start writing data, but it's not able to be picked up by the receiver. they are both on the same address, and i have checked the wiring.
im using an ESP32-wroom-32 as the transmitter and an UNO as my receiver.
i also have a 10uf capacitor across GND and VCC of the module
if you have any advice for this, i would love to hear it
thanks
(P.S if I don’t respond in a timely fashion, I’m most likely at school)
my code below
//Transmitter
//===Libaries===//
//---General---
#include <SPI.h>
//---Radio---
#include <nRF24L01.h>
#include <RF24.h>
//---Fingerprint---
#include <Adafruit_Fingerprint.h>
//---WiFi---
#include <WiFi.h>
#include <WebServer.h>
#include "disarmed.h"
#include "armed.h"
//===Variables===//
bool TestingCheats = false;
const int FingerRequested = 2;
bool FingerGood = false;
bool ServerStarted = false;
bool Armed = false;
const int JoyL = 39;
const int JoyR = 36;
const int Serv = 34;
const int Button = 35;
struct WirelessData {
  int JoyLVal;
  int JoyRVal;
  int ServVal;
  int ButtonVal;
//===Object Initiation===//
//---Radio Initiation---
RF24 radio(22, 21);               // CE, CSN
const byte address[] = "21875";  // Communication address
//---Fingerprint Initiation---
#define mySerial Serial1
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);  // RX, TX
//---WiFi Initiation---
const char* ssid = "Control";    //Enter SSID here
const char* password = "jc705";  //Enter Password here
IPAddress local_ip(192, 168, 4, 1);
IPAddress gateway(192, 168, 4, 1);
IPAddress subnet(255, 255, 255, 0);
WebServer server(80);  //WebServer port listening to
//===Void Functions===//
//---Setup---//
void RadioSetup() {
  radio.begin();
  radio.openWritingPipe(address);
  radio.setPALevel(RF24_PA_LOW);
  radio.stopListening();
  Serial.println("Radio setup complete");
void FingerprintSetup() {
  Serial.println("\n\nAdafruit finger detection setup");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  delay(5);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  Serial.println(F("Reading sensor parameters"));
  finger.getParameters();
  Serial.print(F("Status: 0x"));
  Serial.println(finger.status_reg, HEX);
  Serial.print(F("Sys ID: 0x"));
  Serial.println(finger.system_id, HEX);
  Serial.print(F("Capacity: "));
  Serial.println(finger.capacity);
  Serial.print(F("Security level: "));
  Serial.println(finger.security_level);
  Serial.print(F("Device address: "));
  Serial.println(finger.device_addr, HEX);
  Serial.print(F("Packet len: "));
  Serial.println(finger.packet_len);
  Serial.print(F("Baud rate: "));
  Serial.println(finger.baud_rate);
  finger.getTemplateCount();
  if (finger.templateCount == 0) {
    Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
    Serial.println("Waiting for valid finger...");
    Serial.print("Sensor contains ");
    Serial.print(finger.templateCount);
    Serial.println(" templates");
void WifiSetup() {
  Serial.println("Configuring access point...");
  // You can remove the password parameter if you want the AP to be open.
  WiFi.softAP(ssid);
  Serial.println("Wifi setup complete");
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  Serial.print("SSID:");
  Serial.println(ssid);
  Serial.print("PASS:");
  Serial.println(password);
  server.onNotFound(handleNotFound);
  server.on("/", handleRoot);
  server.on("/disarmed.html", handleRoot);
  server.on("/armed.html", handleArmed);
//---Loop---//
void RadioLoop() {
  WirelessData data = {
    analogRead(JoyL),
    analogRead(JoyR),
    analogRead(Serv)
  if (radio.write(&data, sizeof(data)))
    Serial.println("data sent");
  else{
    Serial.println("data not sent");
  Serial.print("Joystick L: ");
  Serial.println(data.JoyLVal);
  Serial.print("Joystick R: ");
  Serial.println(data.JoyRVal);
  Serial.print("Servo Value: ");
  Serial.println(data.ServVal);
void FingerLoop() {  //part 1
  getFingerprintID();
  delay(50);  //don't ned to run this at full speed.
uint8_t getFingerprintID() {  //part 2
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      FingerDeny();
      return p;
    default:
      Serial.println("Unknown error");
      FingerDeny();
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      FingerDeny();
      return p;
      FingerDeny();
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      FingerDeny();
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      FingerDeny();
      return p;
    default:
      FingerDeny();
      return p;
  // OK converted!
  p = finger.fingerSearch();
  if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    FingerDeny();
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    FingerDeny();
    return p;
    FingerDeny();
    return p;
  // found a match!
  Serial.print("Found ID #");
  Serial.print(finger.fingerID);
  Serial.print(" with confidence of ");
  Serial.println(finger.confidence);
  if (FingerRequested == finger.fingerID) {
    FingerGood = true;
    Serial.println("Finger Validated");
    finger.LEDcontrol(FINGERPRINT_LED_ON, 0, FINGERPRINT_LED_BLUE);
    finger.LEDcontrol(FINGERPRINT_LED_OFF, 0, FINGERPRINT_LED_BLUE);
    FingerDeny();
    finger.LEDcontrol(FINGERPRINT_LED_ON, 0, FINGERPRINT_LED_RED);
    finger.LEDcontrol(FINGERPRINT_LED_OFF, 0, FINGERPRINT_LED_RED);
  return finger.fingerID;
int getFingerprintIDez() {  //part 3
  // returns -1 if failed, otherwise returns ID #
  if (p != FINGERPRINT_OK) return -1;
  p = finger.fingerFastSearch();
  // found a match!
    FingerGood = true;
    FingerDeny();
void FingerDeny() {
void WifiLoop() {
  server.handleClient();
//---Website pages---//
void handleNotFound() {                              // 404 Error page
  server.send(404, "text/plain", "404: Not Found");  // Send HTTP status 404 (Not Found) when there's no handler for the URI in the request
void handleRoot() {  // disarmed page
  Serial.println("disarmed page");
  server.send(200, "text/html", disarmed);
  Armed = false;
void handleArmed() {  // armed page
  Serial.println("armed page");
  server.send(200, "text/html", armed);
  Armed = true;
//===Main Code===//
  RadioSetup();
  FingerprintSetup();
  WifiSetup();
  pinMode(JoyL, INPUT);
  pinMode(JoyR, INPUT);
  pinMode(Serv, INPUT);
  pinMode(Button, INPUT);
  Serial.println("Setup Done");
  WifiLoop();
  if (Armed == false) {
    RadioLoop();
    Serial.println("Radio loop Done");
  if (FingerGood == false) {
    FingerLoop();
    Serial.println("Finger loop Done");
  if (FingerGood == true && ServerStarted == false) {
    server.begin();
    Serial.println("Server loop Done");
    ServerStarted = true;
//Receiver
//===Libaries===//
//---General---
#include <SPI.h>
//---Radio---
#include <RF24.h>
//===Variables===//
  int JoyLVal;
  int JoyRVal;
  int ServVal;
RF24 radio(9, 10);                 // CE, CSN
const byte address[5] = "21875";  // Communication address
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.startListening();
  Serial.println("setup done");
  if (radio.available()) {
    WirelessData data;
    radio.read(&data, sizeof(data));
    // Print the values received
    Serial.println("done");
    Serial.println("\n");
  else {
  Serial.print("Radio no avalabe");
  Serial.println(radio.available());
