Hei people I am trying to implement an interrupt function as follows:
// Random seed includes
#include <avr/interrupt.h>
#include <avr/wdt.h>
#include <util/atomic.h>
#define randomSeed(s) srandom(s)
volatile uint32_t seed; // These two variables can be reused in your program after the
volatile int8_t nrot; // function CreateTrulyRandomSeed()executes in the setup() function
Define arduino output pins. Change these values as necessary.
The LED_BUILTIN pin is helpful as an indicator that the program is running.
#define N_PINS 3
const int pins[N_PINS] = { 13, 14, LED_BUILTIN };
// define baud rate
int bd = 9600;
// define interrupt timer
IntervalTimer SerialTimer;
//define pulse parameters
#define INTERVAL_MIN 1000 //define minimum interval length [ms]
#define INTERVAL_MAX 1000 //define maximum interval length [ms]
#define PULSE_LEN 1000 //define the pulse length [ms]
bool LEDstate = 0;
int counter = 0;
void CreateTrulyRandomSeed() {
seed = 0;
nrot = 32; // Must be at least 4, but more increased the uniformity of the produced
// seeds entropy.
// The following five lines of code turn on the watch dog timer interrupt to create
// the seed value
cli();
MCUSR = 0;
_WD_CONTROL_REG |= (1 << _WD_CHANGE_BIT) | (1 << WDE);
_WD_CONTROL_REG = (1 << WDIE);
sei();
while (nrot > 0); // wait here until seed is created
// The following five lines turn off the watch dog timer interrupt
cli();
MCUSR = 0;
_WD_CONTROL_REG |= (1 << _WD_CHANGE_BIT) | (0 << WDE);
_WD_CONTROL_REG = (0 << WDIE);
sei();
ISR(WDT_vect) {
nrot--;
seed = seed << 8;
seed = seed ^ TCNT1L;
//function called by the interrupt sending the signal through USB port
void sendSerial60() {
counter++;
Serial.print(LEDstate);
Serial.print(" - ");
Serial.println(counter);
//start Serial connection
Serial.begin(bd);
//define interrupt function and interrupt timing 60Hz -> 166666.6667us (projectors @60Hz)
SerialTimer.begin(sendSerial60, 16666.66667); //120: 8333.3333333, 59.81: 16719.61211
CreateTrulyRandomSeed();
randomSeed(seed);
// Serial.print("Random seed = ");
// Serial.print(seed);
// Serial.print("\n");
for (int i = 0; i < N_PINS; i++) {
pinMode(pins[i], OUTPUT);
digitalWrite(pins[i], LOW);
//switch LED to HIGH
LEDstate = 1;
//change the signal to on (high, 3.3V)
digitalWrite(pins[i], LEDstate); //turn the pins on (high, 3.3V)
//keep the signal on for the length of PULSE_LEN
delay(PULSE_LEN); //keep the current state for the length of PULSE_LEN
//switch LED to LOW
LEDstate = 0;
//change the signal to off (low, 0V)
digitalWrite(pins[i], LOW); //turn the pins off (low, 0V)
// Wait for random inter-pulse interval
int random_delay = random(INTERVAL_MIN, INTERVAL_MAX);
Serial.println(random_delay);
delay(random_delay);
I know for now it is not crazy random having 1s on and offs, in future this will change. More I get some errors I don't remember having them before as I used that code already on the mentioned Teensy 3.2.
The error list looks as follows:
C:\Users\lukashi\Arduino\randomSerialTest\randomSerialTest.ino:76:5: error: expected constructor, destructor, or type conversion before '(' token
76 | ISR(WDT_vect) {
C:\Users\lukashi\Arduino\randomSerialTest\randomSerialTest.ino: In function 'void CreateTrulyRandomSeed()':
C:\Users\lukashi\Arduino\randomSerialTest\randomSerialTest.ino:61:3: error: 'MCUSR' was not declared in this scope
61 | MCUSR = 0;
C:\Users\lukashi\Arduino\randomSerialTest\randomSerialTest.ino:62:3: error: '_WD_CONTROL_REG' was not declared in this scope
62 | _WD_CONTROL_REG |= (1 << _WD_CHANGE_BIT) | (1 << WDE);
C:\Users\lukashi\Arduino\randomSerialTest\randomSerialTest.ino:62:28: error: '_WD_CHANGE_BIT' was not declared in this scope
C:\Users\lukashi\Arduino\randomSerialTest\randomSerialTest.ino:62:52: error: 'WDE' was not declared in this scope
C:\Users\lukashi\Arduino\randomSerialTest\randomSerialTest.ino:63:27: error: 'WDIE' was not declared in this scope
63 | _WD_CONTROL_REG = (1 << WDIE);
C:\Users\lukashi\Arduino\randomSerialTest\randomSerialTest.ino: At global scope:
C:\Users\lukashi\Arduino\randomSerialTest\randomSerialTest.ino:76:4: error: expected constructor, destructor, or type conversion before '(' token
exit status 1
Compilation error: expected constructor, destructor, or type conversion before '(' token
Any help would be clearly appreciated! Thanks and cheers.
