avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is "C:\Users\ADMIN\OneDrive\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" Using Port : COM7 Using Programmer : arduino Overriding Baud Rate : 115200 AVR Part : ATmega328P Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : Arduino Description : Arduino Hardware Version: 3 Firmware Version: 4.4 Vtarget : 0.3 V Varef : 0.3 V Oscillator : 28.800 kHz SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\ADMIN\AppData\Local\Temp\arduino_build_824545/5_servo_control.ino.hex"
avrdude: writing flash (1774 bytes):Writing | ################################################## | 100% 0.25s
avrdude: 1774 bytes of flash written
avrdude: verifying flash memory against C:\Users\ADMIN\AppData\Local\Temp\arduino_build_824545/5_servo_control.ino.hex:
avrdude: load data flash data from input file C:\Users\ADMIN\AppData\Local\Temp\arduino_build_824545/5_servo_control.ino.hex:
avrdude: input file C:\Users\ADMIN\AppData\Local\Temp\arduino_build_824545/5_servo_control.ino.hex contains 1774 bytes
avrdude: reading on-chip flash data:Reading | ################################################## | 100% 0.19s
avrdude: verifying ...
avrdude: 1774 bytes of flash verifiedavrdude done. Thank you.
This thing is showing up when i try to upload a code, i tried blink file, same mssg appears but the light blinks just fine, what do i do, my project is due today. HELP!!! here's the most recent code i tried to upload
#include <Servo.h>
int servoPin1=13;
Servo s1;
s1.attach(servoPin1);
s1.write(0);
s1.write(180);
so i did some searching on yt about the error mssg "avrdude done.Thank you'
and what i've learned is it might be a problem related to bootloader, if it is how can i fix it, i'll be in a REALLY BAD situation if i don't get this arduino fixed. so please help, thank you
