I get the following error when trying to upload a sketch to my Nano. I had been working on this all morning and had no issues until all of a sudden it can't upload anymore. I restarted the PC, swapped cables. PC recognizes the device and is listed in my device manager. This error occurs on all Nanos I've tried (I've tried 3 other Nano's and sketches won't upload on those either. All board files are updated. Not sure what else to try here. Any thoughts would be appreciated. Oh I also tried uploading use the ATmega328P and the Old Bootloader, both fail.
Arduino: 1.8.15 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Program Files (x86)\Arduino_update\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino_update\hardware -hardware C:\Users\dpalacio\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino_update\tools-builder -tools C:\Program Files (x86)\Arduino_update\hardware\tools\avr -tools C:\Users\dpalacio\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino_update\libraries -libraries \teleflex.global.pvt\global\Home\Medical\NA\MOR\Home2\dpalacio\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=2341_0058 -ide-version=10815 -build-path C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640 -warnings=none -build-cache C:\Users\dpalacio\AppData\Local\Temp\arduino_cache_189321 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose \teleflex.global.pvt\global\Home\Medical\NA\MOR\Home2\dpalacio\Arduino\analog_test\analog_test.ino
C:\Program Files (x86)\Arduino_update\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino_update\hardware -hardware C:\Users\dpalacio\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino_update\tools-builder -tools C:\Program Files (x86)\Arduino_update\hardware\tools\avr -tools C:\Users\dpalacio\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino_update\libraries -libraries \teleflex.global.pvt\global\Home\Medical\NA\MOR\Home2\dpalacio\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=2341_0058 -ide-version=10815 -build-path C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640 -warnings=none -build-cache C:\Users\dpalacio\AppData\Local\Temp\arduino_cache_189321 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose \teleflex.global.pvt\global\Home\Medical\NA\MOR\Home2\dpalacio\Arduino\analog_test\analog_test.ino
Using board 'nano' from platform in folder: C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\eightanaloginputs" "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640\sketch\analog_test.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\eightanaloginputs" "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640\sketch\analog_test.ino.cpp" -o "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino_update\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\eightanaloginputs" "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640\sketch\analog_test.ino.cpp" -o "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640\sketch\analog_test.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\dpalacio\AppData\Local\Temp\arduino_cache_189321\core\core_arduino_avr_nano_cpu_atmega328old_6c7a5e344ea07451da30444c02d0ba25.a
Linking everything together...
"C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640/analog_test.ino.elf" "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640\sketch\analog_test.ino.cpp.o" "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640/..\arduino_cache_189321\core\core_arduino_avr_nano_cpu_atmega328old_6c7a5e344ea07451da30444c02d0ba25.a" "-LC:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640" -lm
"C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640/analog_test.ino.elf" "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640/analog_test.ino.eep"
"C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640/analog_test.ino.elf" "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640/analog_test.ino.hex"
"C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640/analog_test.ino.elf"
Sketch uses 3704 bytes (12%) of program storage space. Maximum is 30720 bytes.
Global variables use 204 bytes (9%) of dynamic memory, leaving 1844 bytes for local variables. Maximum is 2048 bytes.
C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM10 -b57600 -D -Uflash:w:C:\Users\dpalacio\AppData\Local\Temp\arduino_build_707640/analog_test.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\dpalacio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM10
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x46
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x46
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
