Issue with writing a variable on a webpage
Hi again, sorry I'm asking so many questions
I'm trying to get a status update (provided by my Arduino Mega via softSerial) to appear on a web page run from my Arduino Uno WiFi rev2. This is my current code:
#include <SPI.h>
#include <WiFiNINA.h>
#include <SoftwareSerial.h>
char ssid[] = "REDACTED";
char pass[] = "REDACTED";
int keyIndex = 0;
int status = WL_IDLE_STATUS;
WiFiServer server(80);
SoftwareSerial softSerial(9, 8);
int LED = 2;
void printWifiStatus() {
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
  pinMode(LED_BUILTIN, OUTPUT);
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to Network named: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
    delay(10000);
  server.begin();
  printWifiStatus();
  softSerial.begin(9600);
  pinMode(LED, OUTPUT);
  WiFiClient client = server.available();
  if (softSerial.available()) {
    char number = softSerial.read();
    Serial.println(number);
    if (number == '0') {
      digitalWrite(LED, LOW);
      char status[9] = "activated";
      Serial.println(status);
    else if (number == '1') {
      digitalWrite(LED, HIGH);
      char status[11] = "deactivated";
    char status[7] = "offline";
  if (client) {
    Serial.println("new client");
    String currentLine = "";
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        if (c == '\n') {
          if (currentLine.length() == 0) {
            client.println("Content-type:text/html");
            client.println();
            client.print("Current Status:");
            client.print(status);
            client.print("<br>");
            client.print("Click <a href=\"/H\">here</a> to activate the alarm<br>");
            client.print("Click <a href=\"/L\">here</a> to deactivate the alarm<br>");
            client.println();
          else {
          currentLine = "";
        } else if (c != '\r') {
        currentLine += c;
      if (currentLine.endsWith("GET /H")) {
        Serial.println("H");
      if (currentLine.endsWith("GET /L")) {
        Serial.println("L");
When I run it, the Status update does not appear on either the serial monitor or the web page however instead the webpage says Current Status:3
I have no idea where this is coming from or why I'm not getting a status update so if anyone has any ideas please let me know.
Many Thanks
You have two status variables
a global one
and a very transient one
the latter does not survive the if() statement in which it's defined, so outside the if, you go back to the global status which (if WiFi was connected successfuly) is WL_CONNECTED (which is 3)
it's time to read about scope
PS/ 9 is not enough bytes for your local variable... you need space for a trailing null char.
In general it would be better to write
      char status[] = "activated";
and let the compiler calculate how many bytes are needed.... or just use a constant pointer if you don't need to modify the content
     const char * status  = "activated";
Thanks for that
This is how I've tried to fix it:
#include <SPI.h>
int keyIndex = 0;
int LED = 2;
char state = (" ");
  Serial.println(ip);
  Serial.print(rssi);
  Serial.println(ip);
    while (true);
    delay(10000);
  server.begin();
  printWifiStatus();
      char state[] = "activated";
      Serial.println(state);
      char state[] = "deactivated";
    char state[] = "offline";
  if (client) {
        Serial.write(c);
        if (c == '\n') {
            client.println();
            client.print(state);
            client.println();
          else {
          currentLine = "";
        currentLine += c;
Unfortunately, I'm now getting a current status of P.
read again about scope
you still have the same issue
with multiple local definitions that get thrown out the minute you leave the if() in which they are defined.
define a global variable
const char * state = "unknown";
then in each if just assign a new value to the pointer like
state = "activated";
state = "deactivated";
state = "offline";
but do not redefine a new variable by adding the type in front of the variable.
Why are you using SoftwareSerial? The Mega has multiple hardware UART ports that will far out-perform the software version with fewer issues.
The code here is for "the other side", I'm assuming a hardware Serial port was used on the MEGA.
But still a good point because the Arduino Uno WiFi has 3 hardware serial ports.
  • Serial is connected to the USB interface,
  • Serial1 is connected to Pin 0 (RX) and 1 (TX),
  • Serial 2 is connected to the u-blox NINA-W13 module.
So Serial1 could be used on the receiving end rather than
Thanks for the responses, I think I now understand scope and I will look at whether I'd be better off using hardware serial later when I have time.
it's a trivial modification and you'll get a project that is more robust
Thanks again everyone, I'm now getting a \ bizarrely. Does anyone have any suggestions please?
#include <SPI.h>
int keyIndex = 0;
int LED = 2;
char number = (" ");
char state = (" ");
  Serial.println(ip);
  Serial.print(rssi);
  Serial.println(ip);
    while (true);
    delay(10000);
  server.begin();
  printWifiStatus();
    state = "offline";
  if (client) {
        Serial.write(c);
        if (c == 'n') {
            client.println();
            client.println();
          else {
          currentLine = "";
        } else if (c != 'r') {
        currentLine += c;
You want \n
Sorry, that was a mistake copying over.
I have put the \ back in on that line and a similar line further down, I'm still getting status: \
Well… what type did you pick for state….
I gave you code, why do you go with some random stuff that does not make sense… :man_shrugging:
I'm so sorry, I misunderstood your first post, I have it working now. Thanks for the help.
Good !
Have fun
