I plugged both a SD card backpane and a ILI9341 (produced in China) to the DUE SPI header.
if I compile and run the following file targeting a DUE
- for ILI9341 Adafruit libs and a SD card, everything is fine for SD.h
- for ILI9341 Adafruit libs and SdFat instead, it’s fine too.
issues are about the following:
- for ILI9341_due libs, with SD.h the program finds the SD card but blocks display output
- for ILI9341_due libs with SdFat instead, the SD card sometimes can be found, sometimes delayed, sometimes not, but display output is ok
so there are lib incompatibilities about SD libs
#include <SPI.h>
#include <SD.h> // <<<<<<<<<<<<<<<<<<< define SD driver <<<<<<<<<<<<<<
//#include <SdFat.h>
//SdFat SD;
// TFT LCD
#define _SmallFont_ 1 // 9341 6x9
#define _MediumFont_ 2 // 9341 12x16
#define _BigFont_ 3 // 9341 18x23
int16_t LCDmaxX , LCDmaxY ; // display size
int16_t _curx_, _cury_, // last x,y cursor pos on TFT screen
_maxx_, _maxy_; // max. x,y cursor pos on TFT screen
// set LCD TFT type
int16_t LCDTYPE = -1;
#define _UTFT_ 4
#define _ILI9341_ 8 // https://github.com/adafruit/Adafruit_ILI9340
// https://github.com/adafruit/Adafruit-GFX-Library //
#define _ILI9341due_ 9 // ILI9341_due NEW lib by Marek Buriak
// http://marekburiak.github.io/ILI9341_due/ //
#define tft_cs 49
#define tft_dc 48
#define tft_rst 0
// TFT Adafruit LIL9340/ILI9341
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9340.h>
Adafruit_ILI9340 tft = Adafruit_ILI9340(tft_cs, tft_dc, tft_rst);
// TFT ILI9341_due // http://marekburiak.github.io/ILI9341_due/ //
#include <ILI9341_due_config.h>
#include <ILI9341_due.h>
#include <SystemFont5x7.h>
ILI9341_due dtft = ILI9341_due(tft_cs, tft_dc);
// Color set
#define BLACK 0x0000
#define RED 0xF800
#define GREEN 0x07E0
//#define BLUE 0x001F
#define BLUE 0x102E
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define ORANGE 0xFD20
#define GREENYELLOW 0xAFE5
#define DARKGREEN 0x03E0
#define WHITE 0xFFFF
uint16_t color;
int16_t fontwi= 8; // default
int16_t fonthi=10; // default
void putfonttype(uint8_t fsize) {
if(LCDTYPE==_UTFT_) {
if(LCDTYPE==_ILI9341_) {
if(fsize==_SmallFont_) { fontwi= 6; fonthi=9; } // 5x7 + overhead
if(fsize==_MediumFont_) { fontwi=12; fonthi=16; } // ?
if(fsize==_BigFont_) { fontwi=18; fonthi=23; } // ?
if(LCDTYPE==_ILI9341due_) {
_maxx_ = LCDmaxX / fontwi; // max number of letters x>>
_maxy_ = LCDmaxY / fonthi; // max number of letters y^^
void setlcdorient(int16_t orient) {
tft.setRotation(orient);
LCDmaxX=tft.width();
LCDmaxY=tft.height();
dtft.setRotation((iliRotation)orient);
LCDmaxX=dtft.width();
LCDmaxY=dtft.height();
void lcdcls() {
if(LCDTYPE==_UTFT_) { }
if(LCDTYPE==_ILI9341_) { tft.fillScreen(ILI9340_BLACK); }
if(LCDTYPE==_ILI9341due_) { dtft.fillScreen(BLACK); }
_curx_ =0; _cury_ =0;
void curlf() {
_curx_=0;
if( _cury_ <=(LCDmaxY-10) ) _cury_+=fonthi;
else _cury_=0;
if(LCDTYPE==_ILI9341_) { tft.setCursor(0, _cury_); }
if(LCDTYPE==_ILI9341due_) { dtft.cursorToXY(0, _cury_); }
void curxy(int16_t x, int16_t y) {
_curx_ = x;
_cury_ = y;
if(LCDTYPE==_ILI9341_) {tft.setCursor(x, y); }
if(LCDTYPE==_ILI9341due_) {dtft.cursorToXY(x, y); }
void lcdprintxy(int16_t x, int16_t y, char * str) {
else if(LCDTYPE==_ILI9341_) {
tft.setCursor(x,y);
tft.print(str);
_curx_=tft.getCursorX();
_cury_=tft.getCursorY();
else if(LCDTYPE==_ILI9341due_) {
dtft.cursorToXY(x,y);
dtft.printAt(str, x, y);
_curx_=x+strlen(str)*fontwi;
_cury_=y;
void lcdprint(char * str) {
tft.setCursor(_curx_, _cury_);
tft.print(str);
dtft.cursorToXY(_curx_, _cury_);
dtft.printAt(str, _curx_, _cury_ );
_curx_=_curx_+strlen(str)*fontwi;
void initLCD(uint8_t orientation) { // 0,2==Portrait 1,3==Landscape
tft.begin();
setlcdorient(orientation);
tft.setTextSize(_SmallFont_);
putfonttype(_SmallFont_);
dtft.begin();
dtft.setFont(SystemFont5x7);
dtft.setTextColor(WHITE);
dtft.print("ILI9341due");
// SD Card
#define sd_cs 38 // <<<<<<<< adjust!
File myFile;
char _fname_[64];
#define fileIO_OK +1
#define fileIO_NO_ERR 0
#define fileIO_ERR_CREATE -1
#define fileIO_ERR_OPEN -2
#define fileIO_ERR_REMOVE -3
#define fileIO_ERR_WRITE -4
#define fileIO_ERR_READ -5
#define fileIO_ERR_IMPLAUS -6
#define fileIO_ERR_NAME -8
#define fileIO_ERR_SDCARD -16
// SD init
int16_t initSD() {
char sbuf[128];
uint32_t tstamp;
int16_t ior=0;
tstamp = clock();
ior=SD.begin(sd_cs); // true on sucess; else false
while( !ior) {
sprintf(sbuf, "#: ...SD not found... ");
curlf(); lcdprint("#: ...SD not found... ");
Serial.println(sbuf);
if (clock()-tstamp>20000) {Serial.println("#: ...break!"); break; }
if(!ior) return fileIO_ERR_SDCARD; // SD ioresult==0 => error = -16
return fileIO_OK ; // SD ioresult==1 => ok = 1
char sbuf[128];
int32_t i=0;
// Serial terminal window
i=115200;
Serial.begin(i);
Serial.print("Serial started, baud="); Serial.println(i);
// TFT LCD
LCDTYPE = _ILI9341_; // <<<<<<<<<<<<<<<<<<< define TFT driver <<<<<<<<<<<<<<
Serial.print("init LCD...");
initLCD(1);
Serial.println(" done."); lcdcls();
sprintf(sbuf, "LCD=%d wi%dxhi%d Font %dx%d",LCDTYPE,LCDmaxX,LCDmaxY,fontwi,fonthi);
lcdcls(); lcdprint(sbuf);
// SD card
sprintf(sbuf, "SD init... "); Serial.println(sbuf);
i = initSD();
if(i==fileIO_ERR_SDCARD) sprintf(sbuf, "SD failed! ERROR ! ");
else sprintf(sbuf, "SD OK ! ");
curlf();
lcdprint(sbuf);
sprintf(sbuf, "setup(): done.");
Serial.println(); Serial.println(sbuf);
curlf(); curlf(); lcdprint(sbuf);
void loop(){
char sbuf[128];
