Issues after installing 2.3.2
I recently updated my Arduino IDE from version 1.8.xx to 2.3.2
This is on Windows 10.
Each time I open a sketch I get the following error:
Could not install Arduino AVR platform: Error: Could not find platform.
I also get the following in the output window:
Already installed Keyboard@1.0.5
Already installed LiquidCrystal@1.0.7
Already installed SD@1.2.4
Already installed Servo@1.2.1
Already installed Stepper@1.1.3
Already installed Ethernet@2.0.2
Already installed Firmata@2.5.9
Already installed Mouse@1.0.1
Already installed TFT@1.0.6
Already installed Arduino_BuiltIn@1.0.0
I have tried uninstalling and re-installing. I also tried using the REVO portable uninstaller and re-installing, but keep getting the same result.
Any ideas on how to remedy the problem?
Hi @rhammond61. I'm going to ask you to post some additional information that might help us to identify the problem.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Quit from the Arduino IDE menus if it is running.
    All Arduino IDE windows will close.
  2. Start Windows "File Explorer".
  3. Open the Arduino IDE installation folder.
    The default installation location is at one of the following paths:
    • C:\Program Files\Arduino IDE
    • C:\Users\<username>\AppData\Local\Programs\Arduino IDE
      (where <username> is your Windows username)
      :exclamation: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  4. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  5. From the context menu, click "Open PowerShell window here".
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  6. Type the following command:
    & ".\Arduino IDE"
  7. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  8. Wait until you see that "Could not find platform." error in Arduino IDE.
  9. Switch back to the PowerShell window.
  10. Press the Ctrl+Shift+A keyboard shortcut.
    This will select all the text in the PowerShell window.
  11. Press the Ctrl+C keyboard shortcut.
    This will copy the contents of the PowerShell window to the clipboard.
  12. Open a forum reply here by clicking the "Reply" button.
  13. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block icon on toolbar
  14. Press the Ctrl+V keyboard shortcut.
    This will paste the output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
PS C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 29912
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Roger%20Hammond/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-24T17:07:16.185Z root INFO Backend Object.initialize: 2.9 ms [Finished 0.361 s after backend start]
2024-03-24T17:07:16.186Z root INFO Backend Object.configure: 2.4 ms [Finished 0.361 s after backend start]
2024-03-24T17:07:16.186Z root INFO Backend s.onStart: 1.3 ms [Finished 0.361 s after backend start]
2024-03-24T17:07:16.186Z root INFO Backend s.configure: 0.2 ms [Finished 0.376 s after backend start]
2024-03-24T17:07:16.187Z root INFO Backend d.onStart: 0.1 ms [Finished 0.376 s after backend start]
2024-03-24T17:07:16.187Z root INFO Backend d.configure: 0.1 ms [Finished 0.376 s after backend start]
2024-03-24T17:07:16.188Z root INFO Backend d.initialize: 15.4 ms [Finished 0.376 s after backend start]
2024-03-24T17:07:16.188Z root INFO Backend c.onStart: 0.2 ms [Finished 0.376 s after backend start]
2024-03-24T17:07:16.188Z root INFO Backend a.configure: 0.8 ms [Finished 0.377 s after backend start]
2024-03-24T17:07:16.189Z config INFO >>> Initializing CLI configuration...
2024-03-24T17:07:16.189Z root INFO Backend c.initialize: 0.3 ms [Finished 0.377 s after backend start]
2024-03-24T17:07:16.189Z root INFO Backend R.onStart: 0.5 ms [Finished 0.378 s after backend start]
2024-03-24T17:07:16.189Z config INFO Loading CLI configuration from c:\Users\Roger Hammond\.arduinoIDE\arduino-cli.yaml...
2024-03-24T17:07:16.190Z daemon INFO Starting daemon from C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-24T17:07:16.190Z root INFO Backend a.initialize: 0.2 ms [Finished 0.378 s after backend start]
2024-03-24T17:07:16.190Z root INFO Backend w.onStart: 0.7 ms [Finished 0.379 s after backend start]
2024-03-24T17:07:16.190Z root INFO Backend r.configure: 1.1 ms [Finished 0.379 s after backend start]
2024-03-24T17:07:16.190Z discovery-log INFO start
2024-03-24T17:07:16.190Z discovery-log INFO start new deferred
2024-03-24T17:07:16.190Z root INFO Backend d.initialize: 0.3 ms [Finished 0.379 s after backend start]
2024-03-24T17:07:16.190Z root INFO Backend y.onStart: 1.2 ms [Finished 0.380 s after backend start]
2024-03-24T17:07:16.190Z root INFO Backend r.configure: 1.0 ms [Finished 0.380 s after backend start]
2024-03-24T17:07:16.190Z root INFO Backend a.onStart: 0.3 ms [Finished 0.381 s after backend start]
2024-03-24T17:07:16.190Z root INFO Backend h.configure: 0.2 ms [Finished 0.381 s after backend start]
2024-03-24T17:07:16.190Z root INFO Backend s.configure: 0.1 ms [Finished 0.381 s after backend start]
2024-03-24T17:07:16.190Z root INFO Backend l.configure: 0.0 ms [Finished 0.381 s after backend start]
2024-03-24T17:07:16.192Z root INFO Theia app listening on http://127.0.0.1:62671.
2024-03-24T17:07:16.192Z root INFO Finished starting backend application: 1.8 ms [Finished 0.383 s after backend start]
2024-03-24T17:07:16.192Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Roger%20Hammond/.arduinoIDE/plugins does not exist.
2024-03-24T17:07:16.192Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Roger%20Hammond/.arduinoIDE/extensions does not exist.
2024-03-24T17:07:16.192Z root WARN The local plugin referenced by local-dir:C:\Users\Roger Hammond\.arduinoIDE\plugins does not exist.
2024-03-24T17:07:16.195Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\Roger Hammond\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-24T17:07:16.195Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-24T17:07:16.195Z config INFO Loaded the CLI configuration.
Restoring workspace roots: c:\Users\Roger Hammond\Documents\Arduino\PointInPoly
isTempSketch: false. Input was c:\Users\Roger Hammond\Documents\Arduino\PointInPoly\PointInPoly.ino
2024-03-24T17:07:16.202Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Roger%20Hammond/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Roger%20Hammond/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-03-24T17:07:16.202Z config INFO Validating the CLI configuration...
2024-03-24T17:07:16.203Z config INFO The CLI config is valid.
2024-03-24T17:07:16.203Z config INFO <<< Initialized the CLI configuration.
2024-03-24T17:07:16.211Z root INFO Resolve plugins list: 21.5 ms [Finished 0.402 s after backend start]
2024-03-24T17:07:16.260Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="Using config file: c:\\Users\\Roger Hammond\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-24T12:07:16-05:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-03-24T12:07:16-05:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:62672
{"IP":"127.0.0.1","Port":"62672"}
2024-03-24T17:07:16.260Z daemon INFO Daemon is running.
2024-03-24T17:07:16.304Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="Checking signature" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-03-24T12:07:16-05:00" level=info msg="Loading hardware from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading package MattairTech_Arduino from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\hardware"
time="2024-03-24T12:07:16-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded platform" platform="MattairTech_Arduino:samd@1.6.18-beta-b1"
time="2024-03-24T12:07:16-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\tools"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\tools"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="MattairTech_Arduino:CMSIS-Atmel@1.0.0-mattairtech-2"time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="MattairTech_Arduino:bossac@1.7.0-mattairtech-3"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading package SparkFun from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded platform" platform="SparkFun:avr@1.1.13"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded platform" platform="SparkFun:samd@1.8.7"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading package arduino from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-03-24T12:07:16-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded platform" platform="arduino:megaavr@1.8.8"
time="2024-03-24T12:07:16-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\installed.json"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded platform" platform="arduino:samd@1.8.14"
time="2024-03-24T12:07:16-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:CMSIS@4.5.0"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:CMSIS-Atmel@1.2.0"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.0"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.1"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.7.0-arduino3"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.8.0-48-gb176eee"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.10.0-arduino7"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.9.0-arduino"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading package builtin from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-03-24T12:07:16-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading package esp32 from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
time="2024-03-24T12:07:16-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\installed.json"
2024-03-24T17:07:16.338Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
time="2024-03-24T12:07:16-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@3.0.0"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading hardware from: C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware"
time="2024-03-24T12:07:16-05:00" level=info msg="Loading package arduino from: C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino"
time="2024-03-24T12:07:16-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.4"
time="2024-03-24T12:07:16-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" location=platform
time="2024-03-24T12:07:16-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\avr\\1.1.13\\libraries" location=platform
time="2024-03-24T12:07:16-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.7\\libraries" location=platform
time="2024-03-24T12:07:16-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
time="2024-03-24T12:07:16-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\libraries" location=platform
time="2024-03-24T12:07:16-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
2024-03-24T17:07:16.340Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\hardware\\samd\\1.6.18-beta-b1\\libraries" location=platform
time="2024-03-24T12:07:16-05:00" level=info msg="Loading libraries index file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-24T17:07:16.476Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-03-24T12:07:16-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
2024-03-24T17:07:16.705Z root INFO Deploy plugins list: 21.5 ms [Finished 0.896 s after backend start]
2024-03-24T17:07:16.943Z discovery-log INFO start resolved watching
2024-03-24T17:07:16.943Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="starting discovery builtin:mdns-discovery process"
2024-03-24T17:07:16.943Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="starting discovery builtin:dfu-discovery process"
time="2024-03-24T12:07:16-05:00" level=info msg="starting discovery builtin:serial-discovery process"
2024-03-24T17:07:16.947Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="started discovery builtin:serial-discovery process"
time="2024-03-24T12:07:16-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:serial-discovery"
2024-03-24T17:07:16.947Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2024-03-24T12:07:16-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:mdns-discovery"
time="2024-03-24T12:07:16-05:00" level=info msg="started discovery builtin:dfu-discovery process"
2024-03-24T17:07:16.947Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:dfu-discovery"
2024-03-24T17:07:16.952Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-24T17:07:16.952Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2024-03-24T12:07:16-05:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2024-03-24T17:07:16.952Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-24T17:07:16.953Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
2024-03-24T17:07:16.953Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2024-03-24T17:07:16.955Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-24T17:07:16.955Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="sending command START_SYNC to discovery builtin:dfu-discovery"
2024-03-24T17:07:16.956Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: start_sync, message: OK"
2024-03-24T17:07:16.959Z daemon INFO time="2024-03-24T12:07:16-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM1"
2024-03-24T17:07:16.960Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-03-24T17:07:17.399Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-03-24T17:07:17.456Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\Roger Hammond\Documents\Arduino\PointInPoly\PointInPoly.ino>, response: <c:\Users\Roger Hammond\Documents\Arduino\PointInPoly>.
2024-03-24T17:07:17.560Z root INFO Start frontend contributions: 235.7 ms [Finished 1.277 s after frontend start]
2024-03-24T17:07:17.560Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-03-24T17:07:17.560Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-03-24T17:07:17.560Z root INFO >>> Restoring the layout state...
2024-03-24T17:07:17.560Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-03-24T17:07:17.560Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Roger%20Hammond/Documents/Arduino/PointInPoly/PointInPoly.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":6,\"column\":57},\"position\":{\"lineNumber\":1,\"column\":25}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":283,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":0}},"pinned":[false,false],"size":229,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2024-03-24T17:07:17.560Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-03-24T17:07:17.615Z root INFO [97028198-668b-4941-aac0-bd47df2af4fd] Waiting for backend deployment: 106.9 ms [Finished 1.381 s after frontend start]
2024-03-24T17:07:17.900Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836) starting instance
2024-03-24T17:07:18.264Z root INFO [97028198-668b-4941-aac0-bd47df2af4fd] Sync of 23 plugins: 668.3 ms [Finished 2.049 s after frontend start]
2024-03-24T17:07:18.418Z root INFO <<< The layout has been successfully restored.
2024-03-24T17:07:18.458Z root INFO Initialize the workbench layout: 910.5 ms [Finished 2.203 s after frontend start]
2024-03-24T17:07:18.459Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-03-24T17:07:18.459Z root INFO [97028198-668b-4941-aac0-bd47df2af4fd] Loading plugin contributions
2024-03-24T17:07:18.460Z root INFO [97028198-668b-4941-aac0-bd47df2af4fd] Load contributions of 23 plugins: 39.2 ms [Finished 2.242 s after frontend start]
2024-03-24T17:07:18.473Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-03-24T17:07:18.473Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-03-24T17:07:18.542Z root ERROR [hosted-plugin: 21836] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2024-03-24T17:07:18.542Z root ERROR [hosted-plugin: 21836] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
2024-03-24T17:07:18.542Z root ERROR [hosted-plugin: 21836] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
2024-03-24T17:07:18.542Z root ERROR [hosted-plugin: 21836] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2024-03-24T17:07:18.542Z root ERROR [hosted-plugin: 21836] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
2024-03-24T17:07:18.542Z root ERROR [hosted-plugin: 21836] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
2024-03-24T17:07:18.543Z root ERROR [hosted-plugin: 21836] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is nullConflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
2024-03-24T17:07:18.543Z root ERROR [hosted-plugin: 21836] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-03-24T17:07:18.554Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): PluginManagerExtImpl/init()
2024-03-24T17:07:18.555Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-arduino-api@0.1.2 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.594Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(cortex-debug@1.5.1 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.595Z root INFO [hosted-plugin: 21836] Debugger contribution has been registered: cortex-debug
2024-03-24T17:07:18.595Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-arduino-tools@0.1.3 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.595Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(cpp@1.52.1 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.596Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(json@1.46.1 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.596Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(json-language-features@1.46.1 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.597Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.597Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-cs@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.598Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-de@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.598Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-es@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.599Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-fr@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.599Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.600Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-it@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.600Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-ja@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.600Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-ko@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.600Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.601Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-pl@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.601Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-pt-BR@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.601Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-ru@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.601Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-tr@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.602Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.602Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-zh-hans@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.602Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): initializing(vscode-language-pack-zh-hant@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-24T17:07:18.654Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): PluginManagerExtImpl/loadPlugin(C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2024-03-24T17:07:18.656Z root INFO [hosted-plugin: 21836] calling activation function on Arduino IDE API for VS Code extensions
2024-03-24T17:07:18.658Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): PluginManagerExtImpl/loadPlugin(C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2024-03-24T17:07:18.678Z root INFO [hosted-plugin: 21836] calling activation function on JSON Language Features (built-in)
2024-03-24T17:07:18.709Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): PluginManagerExtImpl/loadPlugin(C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2024-03-24T17:07:18.727Z root INFO [hosted-plugin: 21836] calling activation function on VS Code Arduino Tools
2024-03-24T17:07:18.743Z root INFO [97028198-668b-4941-aac0-bd47df2af4fd] Starting plugins.
2024-03-24T17:07:18.745Z root INFO [hosted-plugin: 21836] PLUGIN_HOST(21836): PluginManagerExtImpl/loadPlugin(C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2024-03-24T17:07:18.767Z root INFO [hosted-plugin: 21836] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-03-24T17:07:18.767Z root INFO [hosted-plugin: 21836] calling activation function on Cortex-Debug
2024-03-24T17:07:18.770Z root INFO [hosted-plugin: 21836] GDB server console created
2024-03-24T17:07:18.777Z root INFO [97028198-668b-4941-aac0-bd47df2af4fd] Start of 23 plugins: 315.6 ms [Finished 2.562 s after frontend start]
2024-03-24T17:07:19.394Z root INFO Frontend application start: 2021.3 ms [Finished 3.585 s after backend start]
Checking for update
2024-03-24T17:07:19.408Z root INFO Replace loading indicator with ready workbench UI (animation): 844.6 ms [Finished 3.089 s after frontend start]
2024-03-24T17:07:19.409Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-03-24T17:07:19.409Z root WARN Linked preference "workbench.colorCustomizations" not found.
2024-03-24T17:07:19.800Z daemon INFO time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="arduino:CMSIS@4.5.0"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.5.1"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="esp32:mkspiffs@0.2.3"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="arduino:bossac@1.8.0-48-gb176eee"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.0"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.14.1"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="arduino:CMSIS-Atmel@1.2.0"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="arduino:openocd@0.10.0-arduino7"
time="2024-03-24T12:07:19-05:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
2024-03-24T17:07:19.813Z root ERROR Failed to get debug config: SparkFun:samd:samd21_mini, undefined Error: Debugging is not supported.
    at Object.callback (C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:81340)
    at Object.onReceiveStatus (C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:788706)
    at Object.onReceiveStatus (C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784657)
    at Object.onReceiveStatus (C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
    at C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:870224
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
2024-03-24T17:07:19.813Z root ERROR Request checkDebugEnabled failed with error: Debugging is not supported. Error: Debugging is not supported.
2024-03-24T17:07:19.846Z root INFO Starting language server: SparkFun:samd:samd21_mini
Update for version 2.3.2 is not available (latest version: 2.3.2, downgrade is allowed).
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <GPS.ino> and sketch folder name <PicoTrackerAPRS>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <a_printEnvValues.ino> and sketch folder name <BlinkTest>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <File_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <Update_Display.ino> and sketch folder name <Garage_Monitor_Uno>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <a_Environmental_values.ino> and sketch folder name <PicoTrackerAPRS>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <Endianess.ino> and sketch folder name <FirmwareUpdater>. Skipping
2024-03-24T17:07:19.911Z sketches-service WARN Mismatching sketch file <InterruptProMicro.ino> and sketch folder name <Interrupt>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <a_printEnvValues.ino> and sketch folder name <BlinkTest>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <File_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <Update_Display.ino> and sketch folder name <Garage_Monitor_Uno>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <a_Environmental_values.ino> and sketch folder name <PicoTrackerAPRS>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <Endianess.ino> and sketch folder name <FirmwareUpdater>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <InterruptProMicro.ino> and sketch folder name <Interrupt>. Skipping
2024-03-24T17:07:19.912Z sketches-service WARN Mismatching sketch file <GPS.ino> and sketch folder name <PicoTrackerAPRS>. Skipping
2024-03-24T17:07:19.920Z root ERROR ---- !!!SLOW!!! DURATION: search took 411.847 ms. Args: [{"query":"Arduino_BuiltIn"}] ----
2024-03-24T17:07:20.028Z root ERROR ---- !!!SLOW!!! DURATION: search took 619.678 ms. Args: [{"type":"Updatable"}] ----
2024-03-24T17:07:20.180Z root INFO >>> Starting library package installation... {
  exampleUris: [],
  installedVersion: undefined,
  author: 'Arduino',
  availableVersions: [ '1.0.0' ],
  includes: [],
  description: 'The sole purpose of this library is to install the standard Arduino libraries which are typically included with the Arduino IDE.',
  moreInfoLink: 'https://github.com/arduino-libraries/Arduino_BuiltIn',
  summary: 'Shell Arduino library to provide the standard built-in libraries',
  category: 'Other',
  types: [ 'Arduino' ],
  index: 0
2024-03-24T17:07:20.180Z discovery-log INFO stop
2024-03-24T17:07:20.180Z discovery-log INFO >>> Stopping boards watcher...
2024-03-24T17:07:20.180Z discovery-log INFO Canceling boards watcher...
2024-03-24T17:07:20.180Z discovery-log INFO disposing requesting cancel
2024-03-24T17:07:20.180Z discovery-log INFO disposing canceled
2024-03-24T17:07:20.181Z discovery-log INFO error received
2024-03-24T17:07:20.181Z discovery-log INFO cancel error received!
2024-03-24T17:07:20.181Z discovery-log INFO stop received event: either end or cancel
2024-03-24T17:07:20.181Z discovery-log INFO stop stopped
2024-03-24T17:07:20.181Z discovery-log INFO received end
2024-03-24T17:07:20.378Z daemon INFO time="2024-03-24T12:07:20-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-24T17:07:20.378Z daemon INFO time="2024-03-24T12:07:20-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.7\\libraries" location=platform
2024-03-24T17:07:20.378Z daemon INFO time="2024-03-24T12:07:20-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
2024-03-24T17:07:20.878Z daemon INFO time="2024-03-24T12:07:20-05:00" level=info msg="Resolving include TinyGPSPlus.h for arch samd"
2024-03-24T17:07:20.879Z daemon INFO time="2024-03-24T12:07:20-05:00" level=info msg="  found better lib" lib=TinyGPSPlus prio=6A7
2024-03-24T17:07:21.404Z root WARN Widget was activated, but did not accept focus after 2000ms: serial-monitor
2024-03-24T17:07:21.776Z daemon INFO time="2024-03-24T12:07:21-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-24T17:07:21.776Z daemon INFO time="2024-03-24T12:07:21-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.7\\libraries" location=platform
2024-03-24T17:07:21.776Z daemon INFO time="2024-03-24T12:07:21-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
2024-03-24T17:07:24.941Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Checking signature" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-03-24T17:07:24.942Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loading hardware from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages"
2024-03-24T17:07:24.942Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loading package MattairTech_Arduino from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\hardware"
2024-03-24T17:07:24.945Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T12:07:24-05:00" level=info msg="Loaded platform" platform="MattairTech_Arduino:samd@1.6.18-beta-b1"
2024-03-24T17:07:24.945Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\tools"
time="2024-03-24T12:07:24-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\tools"
2024-03-24T17:07:24.945Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="MattairTech_Arduino:CMSIS-Atmel@1.0.0-mattairtech-2"
2024-03-24T17:07:24.945Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="MattairTech_Arduino:bossac@1.7.0-mattairtech-3"
2024-03-24T17:07:24.945Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loading package SparkFun from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware"
2024-03-24T17:07:24.946Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T12:07:24-05:00" level=info msg="Loaded platform" platform="SparkFun:avr@1.1.13"
2024-03-24T17:07:24.947Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T12:07:24-05:00" level=info msg="Loaded platform" platform="SparkFun:samd@1.8.7"
2024-03-24T17:07:24.947Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loading package arduino from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-03-24T17:07:24.949Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T12:07:24-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2024-03-24T17:07:24.949Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json"
2024-03-24T17:07:24.950Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T12:07:24-05:00" level=info msg="Loaded platform" platform="arduino:megaavr@1.8.8"
2024-03-24T17:07:24.951Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\installed.json"
2024-03-24T17:07:24.952Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T12:07:24-05:00" level=info msg="Loaded platform" platform="arduino:samd@1.8.14"
2024-03-24T17:07:24.952Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-03-24T12:07:24-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-03-24T17:07:24.953Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:CMSIS@4.5.0"
2024-03-24T17:07:24.953Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:CMSIS-Atmel@1.2.0"
2024-03-24T17:07:24.953Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.0"
2024-03-24T17:07:24.953Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.1"
2024-03-24T17:07:24.953Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-03-24T17:07:24.954Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
2024-03-24T17:07:24.954Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2024-03-24T17:07:24.954Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
2024-03-24T17:07:24.954Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-03-24T17:07:24.954Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-03-24T17:07:24.954Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.7.0-arduino3"
2024-03-24T17:07:24.954Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.8.0-48-gb176eee"
2024-03-24T17:07:24.955Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2024-03-24T17:07:24.955Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.10.0-arduino7"
2024-03-24T17:07:24.955Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.9.0-arduino"
2024-03-24T17:07:24.955Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loading package builtin from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-03-24T17:07:24.955Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-24T12:07:24-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-03-24T17:07:24.956Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-03-24T17:07:24.956Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-03-24T17:07:24.956Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-03-24T17:07:24.956Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-03-24T17:07:24.956Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-03-24T17:07:24.957Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loading package esp32 from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-03-24T17:07:24.957Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\installed.json"
2024-03-24T17:07:24.982Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T12:07:24-05:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
2024-03-24T17:07:24.982Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-03-24T12:07:24-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2024-03-24T17:07:24.982Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@3.0.0"
2024-03-24T17:07:24.982Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
2024-03-24T17:07:24.982Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-03-24T17:07:24.982Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2024-03-24T17:07:24.983Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
2024-03-24T17:07:24.983Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-24T17:07:24.983Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
2024-03-24T17:07:24.983Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
2024-03-24T17:07:24.983Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
2024-03-24T17:07:24.983Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-24T17:07:24.983Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-24T17:07:24.983Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T12:07:24-05:00" level=info msg="Loading hardware from: C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware"
2024-03-24T17:07:24.984Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loading package arduino from: C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino"
2024-03-24T17:07:24.985Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-24T17:07:24.985Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.4"
2024-03-24T17:07:24.985Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="sending command QUIT to discovery builtin:dfu-discovery"
2024-03-24T17:07:24.985Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: quit, message: OK"
2024-03-24T17:07:24.985Z daemon INFO time="2024-03-24T12:07:24-05:00" level=info msg="killing discovery builtin:dfu-discovery process"
time="2024-03-24T12:07:24-05:00" level=info msg="Discovery event channel closed builtin:dfu-discovery. Exiting goroutine."
2024-03-24T17:07:25.002Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Closed and removed discovery builtin:dfu-discovery"
time="2024-03-24T12:07:25-05:00" level=info msg="sending command QUIT to discovery builtin:serial-discovery"
2024-03-24T17:07:25.002Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="from discovery builtin:serial-discovery received message type: quit, message: OK"
2024-03-24T17:07:25.002Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="killing discovery builtin:serial-discovery process"
time="2024-03-24T12:07:25-05:00" level=info msg="Discovery event channel closed builtin:serial-discovery. Exiting goroutine."
2024-03-24T17:07:25.018Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Closed and removed discovery builtin:serial-discovery"
time="2024-03-24T12:07:25-05:00" level=info msg="sending command QUIT to discovery builtin:mdns-discovery"
2024-03-24T17:07:25.018Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: quit, message: OK"
2024-03-24T17:07:25.018Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="killing discovery builtin:mdns-discovery process"
time="2024-03-24T12:07:25-05:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
2024-03-24T17:07:25.034Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Closed and removed discovery builtin:mdns-discovery"
2024-03-24T17:07:25.034Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="starting discovery builtin:serial-discovery process"
2024-03-24T17:07:25.036Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="started discovery builtin:serial-discovery process"
time="2024-03-24T12:07:25-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:serial-discovery"
2024-03-24T17:07:25.041Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-24T17:07:25.041Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2024-03-24T12:07:25-05:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2024-03-24T17:07:25.041Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="starting discovery builtin:mdns-discovery process"
2024-03-24T17:07:25.043Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2024-03-24T12:07:25-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:mdns-discovery"
2024-03-24T17:07:25.047Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM1"
2024-03-24T17:07:25.048Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-24T17:07:25.048Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
2024-03-24T17:07:25.048Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2024-03-24T17:07:25.048Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="starting discovery builtin:dfu-discovery process"
2024-03-24T17:07:25.050Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="started discovery builtin:dfu-discovery process"
time="2024-03-24T12:07:25-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:dfu-discovery"
2024-03-24T17:07:25.058Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-24T17:07:25.058Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="sending command START_SYNC to discovery builtin:dfu-discovery"
2024-03-24T17:07:25.059Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: start_sync, message: OK"
2024-03-24T17:07:25.063Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2024-03-24T17:07:25.064Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
2024-03-24T17:07:25.066Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\libraries" location=platform
2024-03-24T17:07:25.068Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\avr\\1.1.13\\libraries" location=platform
2024-03-24T17:07:25.070Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.7\\libraries" location=platform
2024-03-24T17:07:25.072Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" location=platform
2024-03-24T17:07:25.075Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\hardware\\samd\\1.6.18-beta-b1\\libraries" location=platform
time="2024-03-24T12:07:25-05:00" level=info msg="Loading libraries index file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-24T17:07:25.187Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-24T17:07:25.188Z daemon INFO time="2024-03-24T12:07:25-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
2024-03-24T17:07:25.647Z discovery-log INFO start
2024-03-24T17:07:25.647Z discovery-log INFO start new deferred
2024-03-24T17:07:25.647Z discovery-log INFO start resolved watching
2024-03-24T17:07:25.647Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-03-24T17:07:25.827Z root ERROR ---- !!!SLOW!!! DURATION: search took 179.866 ms. Args: [{}] ----
2024-03-24T17:07:25.827Z root INFO <<< Library package installation done. {
  exampleUris: [],
  author: 'Arduino',
  includes: [],
  category: 'Other',
  index: 0
2024-03-24T17:07:25.827Z root WARN Detected a new port that has been already discovered. The old value will be overridden. Old value: {"port":{"address":"COM1","addressLabel":"COM1","protocol":"serial","protocolLabel":"Serial Port"},"boards":[]}, new value: {"boards":[],"port":{"address":"COM1","addressLabel":"COM1","protocol":"serial","protocolLabel":"Serial Port"}}
2024-03-24T17:07:26.071Z root INFO Starting language server: SparkFun:samd:samd21_mini
2024-03-24T17:07:26.419Z daemon INFO time="2024-03-24T12:07:26-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-24T17:07:26.419Z daemon INFO time="2024-03-24T12:07:26-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.7\\libraries" location=platform
2024-03-24T17:07:26.419Z daemon INFO time="2024-03-24T12:07:26-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
2024-03-24T17:07:26.847Z daemon INFO time="2024-03-24T12:07:26-05:00" level=info msg="Resolving include TinyGPSPlus.h for arch samd"
time="2024-03-24T12:07:26-05:00" level=info msg="  found better lib" lib=TinyGPSPlus prio=6A7
2024-03-24T17:07:27.727Z daemon INFO time="2024-03-24T12:07:27-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-24T17:07:27.727Z daemon INFO time="2024-03-24T12:07:27-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.7\\libraries" location=platform
2024-03-24T17:07:27.727Z daemon INFO time="2024-03-24T12:07:27-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
I see something suspicious here:
You have versions 1.8.6 and 1.8.4 of the "Arduino AVR Boards" platform (which has the machine identifier arduino:avr) installed. Under normal conditions, only a single version of a platform should be installed (Arduino IDE doesn't have any support for multiple versions of a given platform being installed simultaneously).
I'm not 100% certain that this is the cause of the "Could not find platform. " error, but I suspect it is. It might be possible to fix the problem by using the Arduino IDE Boards Manager to uninstall and then reinstall Arduino AVR Boards. I'll provide instructions you can follow to do that:
  1. Start Arduino IDE as usual (you don't need to start if from PowerShell this time if you don't want).
  2. Wait until you see the "Could not find platform. " error.
  3. Select Tools > Board > Boards Manager... from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
  4. Scroll down through the list of boards platforms until you see the "Arduino AVR Boards" entry.
  5. Hover the mouse pointer over the "Arduino AVR Boards" entry.
    You will see a ●●● icon appear at the top right corner of the entry.
  6. Click the ●●● icon.
    A menu will open.
  7. Select "Remove" from the menu.
    An "Uninstall" dialog will open.
  8. Click the "YES" button in the "Uninstall" dialog.
    The dialog will close.
  9. Wait for the uninstall process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    Successfully uninstalled platform ...
  10. You should now see either an "INSTALL" or "UPDATE" button at the bottom of the "Arduino AVR Boards" entry.
  11. Wait for the installation process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    Successfully installed platform ...
  12. Select File > Quit from the Arduino IDE menus.
    All Arduino IDE windows will close.
  13. Start Arduino IDE.
You will still see the messages about the first run dependency installations (which the IDE will attempt to install on every startup until it is successful), but this time it should look something like this:
Platform arduino:avr@1.8.6 already installed
Already installed Keyboard@1.0.5
Already installed LiquidCrystal@1.0.7
Already installed SD@1.2.4
Already installed Servo@1.2.1
Already installed Stepper@1.1.3
Already installed Ethernet@2.0.2
Already installed Firmata@2.5.9
Already installed Mouse@1.0.1
Already installed TFT@1.0.6
Already installed Arduino_BuiltIn@1.0.0
(note that the "Could not find platform. " error did not occur this time)
On subsequent IDE startups, you will not see these message since it has now completed the first run dependencies installation process successfully.
I am unable to locate the Arduino AVR Boards platform in the Boards Manager.
Even searching for AVR with the 'type' pulldown set to All.
I do show Arudiono megaAVR Boards, Atmel AVR Xplained-minis, EMORO 2560, littleBits Arduino AVR Modules, and SparkFun AVR Boards.
That is very strange. It certainly explains the error message, but I don't know how it could be possible that the platform would be missing since the "package index" file that populates Boards Manager is checked for corruption.
Please try this:
  1. Press the Ctrl+Shift+P keyboard shortcut (Command+Shift+P for macOS users) to open the "Command Palette".
    A menu will appear on the editor toolbar:
    Command Palette screenshot
  2. Select the "Arduino: Update Package Index" command from the menu.
    You can scroll down through the list of commands to find it or type the name in the field.
    A "Downloading index: package_index.tar.bz2" notification will appear at the bottom right corner of the Arduino IDE window.
  3. Wait for the notification to disappear.
  4. If the "Boards Manager" view is not already open in the left side panel, select Tools > Board > Boards Manager... from the Arduino IDE menus to open it.
  5. If you have a query in the search field of Boards Manager, delete it.
    This is necessary because the search results won't automatically update otherwise.
Now check to see if "Arduino AVR Boards" is present in the list of platforms in Boards Manager.
Still no joy.
I saw the notification appear and then go away.
No search filters present and Type set to All.
OK, that is unfortunate. We can try a manual removal of the "Arduino AVR Boards" platform.
Please try this:
  1. If Arduino IDE is running, select File > Quit from the Arduino IDE menus.
  2. Delete the folder at the following path:
    C:\Users\Roger Hammond\AppData\Local\Arduino15\packages\arduino\hardware\avr\
    :exclamation: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
    :warning: Please be careful when deleting things from your computer. When in doubt, back up!
Now start Arduino IDE. You will still see the messages about the first run dependency installations (which the IDE will attempt to install on every startup until it is successful), but this time it should look something like this:
There was a folder named 1.8.6 in C:\Users\Roger Hammond\AppData\Local\Arduino15\packages\arduino\hardware\avr\
I deleted it.
When I start the IDE I still get all of the same 'Already installed...' in the output window as well as the Could not install Arduino AVR platform: Error: Could not find platform.
I expected that there would have been a 1.8.4 folder there as well. It is possible the 1.8.4 installation is at a different location though. Please start the IDE from PowerShell and provide the terminal logs, following the instructions I gave in post #2.
Here's the latest PowerShell dump:
PS C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 15140
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Roger%20Hammond/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-03-25T02:09:57.409Z root INFO Backend Object.initialize: 3.1 ms [Finished 0.427 s after backend start]
2024-03-25T02:09:57.409Z root INFO Backend Object.configure: 2.4 ms [Finished 0.427 s after backend start]
2024-03-25T02:09:57.410Z root INFO Backend s.onStart: 1.3 ms [Finished 0.427 s after backend start]
2024-03-25T02:09:57.410Z root INFO Backend s.configure: 0.2 ms [Finished 0.444 s after backend start]
2024-03-25T02:09:57.410Z root INFO Backend d.onStart: 0.1 ms [Finished 0.444 s after backend start]
2024-03-25T02:09:57.411Z root INFO Backend d.configure: 0.1 ms [Finished 0.444 s after backend start]
2024-03-25T02:09:57.411Z root INFO Backend d.initialize: 16.4 ms [Finished 0.444 s after backend start]
2024-03-25T02:09:57.411Z root INFO Backend c.onStart: 0.2 ms [Finished 0.444 s after backend start]
2024-03-25T02:09:57.412Z root INFO Backend a.configure: 0.7 ms [Finished 0.445 s after backend start]
2024-03-25T02:09:57.412Z config INFO >>> Initializing CLI configuration...
2024-03-25T02:09:57.412Z root INFO Backend c.initialize: 0.3 ms [Finished 0.445 s after backend start]
2024-03-25T02:09:57.413Z root INFO Backend R.onStart: 0.4 ms [Finished 0.445 s after backend start]
2024-03-25T02:09:57.413Z config INFO Loading CLI configuration from c:\Users\Roger Hammond\.arduinoIDE\arduino-cli.yaml...
2024-03-25T02:09:57.413Z daemon INFO Starting daemon from C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-03-25T02:09:57.413Z root INFO Backend a.initialize: 0.2 ms [Finished 0.446 s after backend start]
2024-03-25T02:09:57.413Z root INFO Backend w.onStart: 0.7 ms [Finished 0.446 s after backend start]
2024-03-25T02:09:57.413Z root INFO Backend r.configure: 1.0 ms [Finished 0.446 s after backend start]
2024-03-25T02:09:57.413Z discovery-log INFO start
2024-03-25T02:09:57.413Z discovery-log INFO start new deferred
2024-03-25T02:09:57.413Z root INFO Backend d.initialize: 0.3 ms [Finished 0.446 s after backend start]
2024-03-25T02:09:57.413Z root INFO Backend y.onStart: 1.1 ms [Finished 0.447 s after backend start]
2024-03-25T02:09:57.413Z root INFO Backend r.configure: 1.0 ms [Finished 0.447 s after backend start]
2024-03-25T02:09:57.413Z root INFO Backend a.onStart: 0.3 ms [Finished 0.448 s after backend start]
2024-03-25T02:09:57.413Z root INFO Backend h.configure: 0.2 ms [Finished 0.448 s after backend start]
2024-03-25T02:09:57.413Z root INFO Backend s.configure: 0.1 ms [Finished 0.448 s after backend start]
2024-03-25T02:09:57.413Z root INFO Backend l.configure: 0.0 ms [Finished 0.448 s after backend start]
2024-03-25T02:09:57.415Z root INFO Theia app listening on http://127.0.0.1:63428.
2024-03-25T02:09:57.415Z root INFO Finished starting backend application: 1.8 ms [Finished 0.450 s after backend start]
2024-03-25T02:09:57.415Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Roger%20Hammond/.arduinoIDE/plugins does not exist.
2024-03-25T02:09:57.416Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Roger%20Hammond/.arduinoIDE/extensions does not exist.
2024-03-25T02:09:57.416Z root WARN The local plugin referenced by local-dir:C:\Users\Roger Hammond\.arduinoIDE\plugins does not exist.
2024-03-25T02:09:57.420Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\Roger Hammond\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-03-25T02:09:57.420Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-03-25T02:09:57.420Z config INFO Loaded the CLI configuration.
2024-03-25T02:09:57.438Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Roger%20Hammond/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Roger%20Hammond/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-03-25T02:09:57.438Z config INFO Validating the CLI configuration...
2024-03-25T02:09:57.439Z config INFO The CLI config is valid.
2024-03-25T02:09:57.439Z config INFO <<< Initialized the CLI configuration.
Restoring workspace roots: c:\Users\Roger Hammond\Documents\Arduino\PointInPoly
2024-03-25T02:09:57.448Z root INFO Resolve plugins list: 35.1 ms [Finished 0.483 s after backend start]
isTempSketch: false. Input was c:\Users\Roger Hammond\Documents\Arduino\PointInPoly\PointInPoly.ino
2024-03-25T02:09:57.467Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Using config file: c:\\Users\\Roger Hammond\\.arduinoIDE\\arduino-cli.yaml"
time="2024-03-24T21:09:57-05:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-03-25T02:09:57.467Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Executing `arduino-cli daemon`"
2024-03-25T02:09:57.471Z daemon INFO Daemon is now listening on 127.0.0.1:63429
{"IP":"127.0.0.1","Port":"63429"}
2024-03-25T02:09:57.471Z daemon INFO Daemon is running.
2024-03-25T02:09:57.505Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Checking signature" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-03-25T02:09:57.505Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loading hardware from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages"
2024-03-25T02:09:57.506Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loading package MattairTech_Arduino from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\hardware"
2024-03-25T02:09:57.521Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-25T02:09:57.521Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded platform" platform="MattairTech_Arduino:samd@1.6.18-beta-b1"
time="2024-03-24T21:09:57-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\tools"
time="2024-03-24T21:09:57-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\tools"
2024-03-25T02:09:57.521Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="MattairTech_Arduino:CMSIS-Atmel@1.0.0-mattairtech-2"
2024-03-25T02:09:57.521Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="MattairTech_Arduino:bossac@1.7.0-mattairtech-3"
2024-03-25T02:09:57.522Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loading package SparkFun from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware"
2024-03-25T02:09:57.530Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded platform" platform="SparkFun:avr@1.1.13"
2024-03-25T02:09:57.541Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded platform" platform="SparkFun:samd@1.8.7"
2024-03-25T02:09:57.541Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loading package arduino from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-03-25T02:09:57.546Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json"
2024-03-25T02:09:57.557Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded platform" platform="arduino:megaavr@1.8.8"
2024-03-25T02:09:57.562Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\installed.json"
2024-03-25T02:09:57.573Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-25T02:09:57.573Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded platform" platform="arduino:samd@1.8.14"
time="2024-03-24T21:09:57-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-03-24T21:09:57-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-03-25T02:09:57.574Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:CMSIS@4.5.0"
2024-03-25T02:09:57.574Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:CMSIS-Atmel@1.2.0"
2024-03-25T02:09:57.576Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.0"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.1"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.7.0-arduino3"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.8.0-48-gb176eee"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.10.0-arduino7"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.9.0-arduino"
time="2024-03-24T21:09:57-05:00" level=info msg="Loading package builtin from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-03-25T02:09:57.594Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-24T21:09:57-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-03-24T21:09:57-05:00" level=info msg="Loading package esp32 from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
time="2024-03-24T21:09:57-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\installed.json"
2024-03-25T02:09:57.622Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-25T02:09:57.622Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
time="2024-03-24T21:09:57-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-03-24T21:09:57-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2024-03-25T02:09:57.623Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@3.0.0"
2024-03-25T02:09:57.623Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
2024-03-25T02:09:57.623Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-03-25T02:09:57.624Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2024-03-25T02:09:57.624Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
2024-03-25T02:09:57.624Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-25T02:09:57.624Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
2024-03-25T02:09:57.624Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
2024-03-25T02:09:57.624Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
2024-03-25T02:09:57.624Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-25T02:09:57.624Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-25T02:09:57.625Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-25T02:09:57.625Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loading hardware from: C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware"
2024-03-25T02:09:57.625Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loading package arduino from: C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino"
2024-03-25T02:09:57.637Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-25T02:09:57.637Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.4"
2024-03-25T02:09:57.640Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" location=platform
2024-03-25T02:09:57.641Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
2024-03-25T02:09:57.642Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino\\avr\\libraries" location=platform
2024-03-25T02:09:57.644Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\libraries" location=platform
2024-03-25T02:09:57.646Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\avr\\1.1.13\\libraries" location=platform
2024-03-25T02:09:57.648Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.7\\libraries" location=platform
2024-03-25T02:09:57.651Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\hardware\\samd\\1.6.18-beta-b1\\libraries" location=platform
2024-03-25T02:09:57.651Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Loading libraries index file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-25T02:09:57.785Z daemon INFO time="2024-03-24T21:09:57-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-03-24T21:09:57-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-03-25T02:09:58.855Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 163.8 ms [Finished 1.359 s after frontend start]
2024-03-25T02:09:58.855Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-03-25T02:09:58.924Z discovery-log INFO start resolved watching
2024-03-25T02:09:58.933Z daemon INFO time="2024-03-24T21:09:58-05:00" level=info msg="starting discovery builtin:serial-discovery process"
time="2024-03-24T21:09:58-05:00" level=info msg="starting discovery builtin:dfu-discovery process"
time="2024-03-24T21:09:58-05:00" level=info msg="starting discovery builtin:mdns-discovery process"
time="2024-03-24T21:09:58-05:00" level=info msg="started discovery builtin:dfu-discovery process"
time="2024-03-24T21:09:58-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:dfu-discovery"
2024-03-25T02:09:58.936Z daemon INFO time="2024-03-24T21:09:58-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1"
time="2024-03-24T21:09:58-05:00" level=info msg="sending command START_SYNC to discovery builtin:dfu-discovery"
2024-03-25T02:09:58.937Z daemon INFO time="2024-03-24T21:09:58-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: start_sync, message: OK"
2024-03-25T02:09:58.968Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\Roger Hammond\Documents\Arduino\PointInPoly\PointInPoly.ino>, response: <c:\Users\Roger Hammond\Documents\Arduino\PointInPoly>.
2024-03-25T02:09:59.043Z root INFO Deploy plugins list: 35.1 ms [Finished 2.078 s after backend start]
2024-03-25T02:09:59.076Z root INFO Start frontend contributions: 437.4 ms [Finished 1.592 s after frontend start]
2024-03-25T02:09:59.076Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-03-25T02:09:59.091Z daemon INFO time="2024-03-24T21:09:59-05:00" level=info msg="started discovery builtin:serial-discovery process"
time="2024-03-24T21:09:59-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:serial-discovery"
2024-03-25T02:09:59.092Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-03-25T02:09:59.093Z root INFO >>> Restoring the layout state...
2024-03-25T02:09:59.093Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-03-25T02:09:59.093Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Roger%20Hammond/Documents/Arduino/PointInPoly/PointInPoly.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":14,\"column\":46},\"position\":{\"lineNumber\":14,\"column\":46}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":283,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":0}},"pinned":[false,false],"size":229,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":268},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"outputView"}
2024-03-25T02:09:59.093Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-03-25T02:09:59.096Z daemon INFO time="2024-03-24T21:09:59-05:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-25T02:09:59.096Z daemon INFO time="2024-03-24T21:09:59-05:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2024-03-24T21:09:59-05:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2024-03-25T02:09:59.101Z daemon INFO time="2024-03-24T21:09:59-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM1"
2024-03-25T02:09:59.117Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Waiting for backend deployment: 55.5 ms [Finished 1.644 s after frontend start]
2024-03-25T02:09:59.217Z daemon INFO time="2024-03-24T21:09:59-05:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2024-03-24T21:09:59-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:mdns-discovery"
time="2024-03-24T21:09:59-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
time="2024-03-24T21:09:59-05:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
time="2024-03-24T21:09:59-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2024-03-25T02:09:59.218Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-03-25T02:09:59.413Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500) starting instance
2024-03-25T02:09:59.764Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Sync of 23 plugins: 647.4 ms [Finished 2.292 s after frontend start]
2024-03-25T02:09:59.960Z root INFO <<< The layout has been successfully restored.
2024-03-25T02:10:00.000Z root INFO Initialize the workbench layout: 875.7 ms [Finished 2.488 s after frontend start]
2024-03-25T02:10:00.001Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-03-25T02:10:00.001Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Loading plugin contributions
2024-03-25T02:10:00.001Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Load contributions of 23 plugins: 38.2 ms [Finished 2.527 s after frontend start]
2024-03-25T02:10:00.007Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-03-25T02:10:00.007Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-03-25T02:10:00.083Z root ERROR [hosted-plugin: 20500] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2024-03-25T02:10:00.084Z root ERROR [hosted-plugin: 20500] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
2024-03-25T02:10:00.084Z root ERROR [hosted-plugin: 20500] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2024-03-25T02:10:00.084Z root ERROR [hosted-plugin: 20500] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2024-03-25T02:10:00.084Z root ERROR [hosted-plugin: 20500] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2024-03-25T02:10:00.084Z root ERROR [hosted-plugin: 20500] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2024-03-25T02:10:00.084Z root ERROR [hosted-plugin: 20500] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
2024-03-25T02:10:00.084Z root ERROR [hosted-plugin: 20500] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null2024-03-25T02:10:00.084Z root ERROR [hosted-plugin: 20500] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
2024-03-25T02:10:00.084Z root ERROR [hosted-plugin: 20500] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-03-25T02:10:00.223Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): PluginManagerExtImpl/init()
2024-03-25T02:10:00.225Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-arduino-api@0.1.2 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.341Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(cortex-debug@1.5.1 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.341Z root INFO [hosted-plugin: 20500] Debugger contribution has been registered: cortex-debug
2024-03-25T02:10:00.342Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-arduino-tools@0.1.3 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.342Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(cpp@1.52.1 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.342Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(json@1.46.1 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.343Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(json-language-features@1.46.1 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.343Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.344Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-cs@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.345Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-de@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.345Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-es@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.345Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-fr@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.346Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.346Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-it@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.346Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-ja@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.346Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-ko@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.347Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.347Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-pl@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.347Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-pt-BR@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.347Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-ru@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.348Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-tr@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.348Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.348Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-zh-hans@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.348Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): initializing(vscode-language-pack-zh-hant@1.80.0 with C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-03-25T02:10:00.391Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): PluginManagerExtImpl/loadPlugin(C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2024-03-25T02:10:00.405Z root INFO [hosted-plugin: 20500] calling activation function on Arduino IDE API for VS Code extensions
2024-03-25T02:10:00.416Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): PluginManagerExtImpl/loadPlugin(C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2024-03-25T02:10:00.492Z root INFO [hosted-plugin: 20500] calling activation function on JSON Language Features (built-in)
2024-03-25T02:10:00.526Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): PluginManagerExtImpl/loadPlugin(C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2024-03-25T02:10:00.567Z root INFO [hosted-plugin: 20500] calling activation function on VS Code Arduino Tools
2024-03-25T02:10:00.579Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Starting plugins.
2024-03-25T02:10:00.582Z root INFO [hosted-plugin: 20500] PLUGIN_HOST(20500): PluginManagerExtImpl/loadPlugin(C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2024-03-25T02:10:00.651Z root INFO [hosted-plugin: 20500] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-03-25T02:10:00.651Z root INFO [hosted-plugin: 20500] calling activation function on Cortex-Debug
2024-03-25T02:10:00.654Z root INFO [hosted-plugin: 20500] GDB server console created
2024-03-25T02:10:00.657Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Start of 23 plugins: 654.0 ms [Finished 3.184 s after frontend start]
2024-03-25T02:10:00.660Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Waiting for backend deployment: 2.0 ms [Finished 3.187 s after frontend start]
2024-03-25T02:10:00.660Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Sync of 0 plugins: 0.0 ms [Finished 3.187 s after frontend start]
2024-03-25T02:10:00.660Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Loading plugin contributions
2024-03-25T02:10:00.660Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Load contributions of 0 plugins: 0.0 ms [Finished 3.187 s after frontend start]
2024-03-25T02:10:00.670Z root INFO [1f46eb0b-ac74-4133-8c76-abeedbd9ed22] Start of 0 plugins: 9.8 ms [Finished 3.198 s after frontend start]
2024-03-25T02:10:00.952Z root INFO Frontend application start: 2175.8 ms [Finished 3.986 s after backend start]
2024-03-25T02:10:00.965Z root INFO Replace loading indicator with ready workbench UI (animation): 842.7 ms [Finished 3.372 s after frontend start]
2024-03-25T02:10:00.965Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-03-25T02:10:00.965Z root WARN Linked preference "workbench.colorCustomizations" not found.
Checking for update
2024-03-25T02:10:01.143Z daemon INFO time="2024-03-24T21:10:01-05:00" level=info msg="Updating libraries index"
time="2024-03-24T21:10:01-05:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2024-03-24T21:10:01-05:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2024-03-24T21:10:01-05:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-03-25T02:10:01.144Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2024-03-25T02:10:01.145Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2024-03-25T02:10:01.401Z root INFO Starting language server: arduino:avr:uno
2024-03-25T02:10:01.430Z sketches-service WARN Mismatching sketch file <GPS.ino> and sketch folder name <PicoTrackerAPRS>. Skipping
2024-03-25T02:10:01.430Z sketches-service WARN Mismatching sketch file <a_printEnvValues.ino> and sketch folder name <BlinkTest>. Skipping
2024-03-25T02:10:01.430Z sketches-service WARN Mismatching sketch file <File_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-25T02:10:01.430Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-25T02:10:01.430Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-25T02:10:01.430Z sketches-service WARN Mismatching sketch file <Update_Display.ino> and sketch folder name <Garage_Monitor_Uno>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <a_Environmental_values.ino> and sketch folder name <PicoTrackerAPRS>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <Endianess.ino> and sketch folder name <FirmwareUpdater>. Skipping
2024-03-25T02:10:01.431Z sketches-service WARN Mismatching sketch file <InterruptProMicro.ino> and sketch folder name <Interrupt>. Skipping
2024-03-25T02:10:01.437Z daemon INFO time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.0"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.14.1"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="esp32:mkspiffs@0.2.3"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="arduino:CMSIS-Atmel@1.2.0"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="arduino:CMSIS@4.5.0"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="arduino:openocd@0.10.0-arduino7"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.5.1"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-03-24T21:10:01-05:00" level=info msg="Tool required for debug" tool="arduino:bossac@1.8.0-48-gb176eee"
2024-03-25T02:10:01.439Z root ERROR Failed to get debug config: arduino:avr:uno, undefined Error: Debugging is not supported.
    at Object.callback (C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:81340)
    at Object.onReceiveStatus (C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:788706)
    at Object.onReceiveStatus (C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784657)
    at Object.onReceiveStatus (C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
    at C:\Users\Roger Hammond\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:870224
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
2024-03-25T02:10:01.439Z root ERROR Request checkDebugEnabled failed with error: Debugging is not supported. Error: Debugging is not supported.
2024-03-25T02:10:01.506Z root ERROR ---- !!!SLOW!!! DURATION: search took 444.325 ms. Args: [{"query":"Arduino_BuiltIn"}] ----
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <GPS.ino> and sketch folder name <PicoTrackerAPRS>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <a_printEnvValues.ino> and sketch folder name <BlinkTest>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <File_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <Update_Display.ino> and sketch folder name <Garage_Monitor_Uno>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <ICSP_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Hex_Uploader>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <a_Environmental_values.ino> and sketch folder name <PicoTrackerAPRS>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Board_Detector>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <Endianess.ino> and sketch folder name <FirmwareUpdater>. Skipping
2024-03-25T02:10:01.532Z sketches-service WARN Mismatching sketch file <InterruptProMicro.ino> and sketch folder name <Interrupt>. Skipping
2024-03-25T02:10:01.533Z sketches-service WARN Mismatching sketch file <HV_Serial_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.533Z sketches-service WARN Mismatching sketch file <HV_Parallel_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.533Z sketches-service WARN Mismatching sketch file <Programming_Utils.ino> and sketch folder name <Atmega_Board_Programmer>. Skipping
2024-03-25T02:10:01.533Z sketches-service WARN Mismatching sketch file <Endianess.ino> and sketch folder name <FirmwareUpdater>. Skipping
2024-03-25T02:10:01.533Z sketches-service WARN Mismatching sketch file <InterruptProMicro.ino> and sketch folder name <Interrupt>. Skipping
Update for version 2.3.2 is not available (latest version: 2.3.2, downgrade is allowed).
2024-03-25T02:10:01.639Z root ERROR ---- !!!SLOW!!! DURATION: search took 671.478 ms. Args: [{"type":"Updatable"}] ----
2024-03-25T02:10:01.646Z root INFO >>> Starting library package installation... {
  exampleUris: [],
  installedVersion: undefined,
  author: 'Arduino',
  availableVersions: [ '1.0.0' ],
  includes: [],
  description: 'The sole purpose of this library is to install the standard Arduino libraries which are typically included with the Arduino IDE.',
  moreInfoLink: 'https://github.com/arduino-libraries/Arduino_BuiltIn',
  summary: 'Shell Arduino library to provide the standard built-in libraries',
  category: 'Other',
  types: [ 'Arduino' ],
  index: 0
2024-03-25T02:10:01.646Z discovery-log INFO stop
2024-03-25T02:10:01.646Z discovery-log INFO >>> Stopping boards watcher...
2024-03-25T02:10:01.646Z discovery-log INFO Canceling boards watcher...
2024-03-25T02:10:01.646Z discovery-log INFO disposing requesting cancel
2024-03-25T02:10:01.646Z discovery-log INFO disposing canceled
2024-03-25T02:10:01.647Z discovery-log INFO error received
2024-03-25T02:10:01.647Z discovery-log INFO cancel error received!
2024-03-25T02:10:01.647Z discovery-log INFO stop received event: either end or cancel
2024-03-25T02:10:01.647Z discovery-log INFO stop stopped
2024-03-25T02:10:01.647Z discovery-log INFO received end
2024-03-25T02:10:01.807Z daemon INFO time="2024-03-24T21:10:01-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-25T02:10:01.807Z daemon INFO time="2024-03-24T21:10:01-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino\\avr\\libraries" location=platform
2024-03-25T02:10:01.807Z daemon INFO time="2024-03-24T21:10:01-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
2024-03-25T02:10:02.430Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Resolving include TinyGPSPlus.h for arch avr"
time="2024-03-24T21:10:02-05:00" level=info msg="  found better lib" lib=TinyGPSPlus prio=6A7
2024-03-25T02:10:02.550Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Checking signature" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-03-25T02:10:02.551Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loading hardware from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages"
2024-03-25T02:10:02.552Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loading package MattairTech_Arduino from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\hardware"
2024-03-25T02:10:02.554Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-25T02:10:02.554Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded platform" platform="MattairTech_Arduino:samd@1.6.18-beta-b1"
time="2024-03-24T21:10:02-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\tools"
time="2024-03-24T21:10:02-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\tools"
2024-03-25T02:10:02.554Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="MattairTech_Arduino:CMSIS-Atmel@1.0.0-mattairtech-2"
2024-03-25T02:10:02.554Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="MattairTech_Arduino:bossac@1.7.0-mattairtech-3"
2024-03-25T02:10:02.555Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loading package SparkFun from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware"
2024-03-25T02:10:02.556Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:10:02-05:00" level=info msg="Loaded platform" platform="SparkFun:avr@1.1.13"
2024-03-25T02:10:02.557Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:10:02-05:00" level=info msg="Loaded platform" platform="SparkFun:samd@1.8.7"
2024-03-25T02:10:02.557Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loading package arduino from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-03-25T02:10:02.558Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json"
2024-03-25T02:10:02.559Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-25T02:10:02.559Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded platform" platform="arduino:megaavr@1.8.8"
2024-03-25T02:10:02.561Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\installed.json"
2024-03-25T02:10:02.562Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-25T02:10:02.562Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded platform" platform="arduino:samd@1.8.14"
time="2024-03-24T21:10:02-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-03-24T21:10:02-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-03-25T02:10:02.562Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:CMSIS@4.5.0"
2024-03-25T02:10:02.562Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:CMSIS-Atmel@1.2.0"
2024-03-25T02:10:02.562Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.0"
2024-03-25T02:10:02.562Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.1"
2024-03-25T02:10:02.563Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-03-25T02:10:02.563Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
2024-03-25T02:10:02.563Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2024-03-25T02:10:02.563Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
2024-03-25T02:10:02.563Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-03-25T02:10:02.563Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-03-25T02:10:02.563Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.7.0-arduino3"
2024-03-25T02:10:02.563Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.8.0-48-gb176eee"
2024-03-25T02:10:02.563Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2024-03-25T02:10:02.563Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.10.0-arduino7"
2024-03-25T02:10:02.564Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.9.0-arduino"
2024-03-25T02:10:02.564Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loading package builtin from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-03-25T02:10:02.564Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-24T21:10:02-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-03-25T02:10:02.564Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-03-25T02:10:02.564Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-03-25T02:10:02.565Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-03-25T02:10:02.565Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-03-25T02:10:02.565Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-03-25T02:10:02.566Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loading package esp32 from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-03-25T02:10:02.566Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\installed.json"
2024-03-25T02:10:02.591Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:10:02-05:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
2024-03-25T02:10:02.591Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-03-24T21:10:02-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2024-03-25T02:10:02.592Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@3.0.0"
2024-03-25T02:10:02.592Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
2024-03-25T02:10:02.592Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-03-25T02:10:02.592Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2024-03-25T02:10:02.592Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
2024-03-25T02:10:02.593Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-25T02:10:02.593Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
2024-03-25T02:10:02.593Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
2024-03-25T02:10:02.593Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
2024-03-25T02:10:02.593Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-25T02:10:02.593Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-25T02:10:02.593Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T21:10:02-05:00" level=info msg="Loading hardware from: C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware"
2024-03-25T02:10:02.594Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Loading package arduino from: C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino"
2024-03-25T02:10:02.595Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:10:02-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.4"
2024-03-25T02:10:02.922Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="sending command QUIT to discovery builtin:serial-discovery"
2024-03-25T02:10:02.922Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="from discovery builtin:serial-discovery received message type: quit, message: OK"
time="2024-03-24T21:10:02-05:00" level=info msg="killing discovery builtin:serial-discovery process"
time="2024-03-24T21:10:02-05:00" level=info msg="Discovery event channel closed builtin:serial-discovery. Exiting goroutine."
2024-03-25T02:10:02.936Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Closed and removed discovery builtin:serial-discovery"
time="2024-03-24T21:10:02-05:00" level=info msg="sending command QUIT to discovery builtin:mdns-discovery"
2024-03-25T02:10:02.936Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: quit, message: OK"
2024-03-25T02:10:02.936Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="killing discovery builtin:mdns-discovery process"
time="2024-03-24T21:10:02-05:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
2024-03-25T02:10:02.952Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Closed and removed discovery builtin:mdns-discovery"
time="2024-03-24T21:10:02-05:00" level=info msg="sending command QUIT to discovery builtin:dfu-discovery"
2024-03-25T02:10:02.952Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: quit, message: OK"
2024-03-25T02:10:02.952Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="killing discovery builtin:dfu-discovery process"
time="2024-03-24T21:10:02-05:00" level=info msg="Discovery event channel closed builtin:dfu-discovery. Exiting goroutine."
2024-03-25T02:10:02.964Z root WARN Widget was activated, but did not accept focus after 2000ms: serial-monitor
2024-03-25T02:10:02.967Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Closed and removed discovery builtin:dfu-discovery"
2024-03-25T02:10:02.967Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="starting discovery builtin:serial-discovery process"
2024-03-25T02:10:02.969Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="started discovery builtin:serial-discovery process"
time="2024-03-24T21:10:02-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:serial-discovery"
2024-03-25T02:10:02.974Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-25T02:10:02.974Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
2024-03-25T02:10:02.974Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2024-03-25T02:10:02.974Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="starting discovery builtin:mdns-discovery process"
2024-03-25T02:10:02.976Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2024-03-24T21:10:02-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:mdns-discovery"
2024-03-25T02:10:02.980Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM1"
2024-03-25T02:10:02.982Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-25T02:10:02.982Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
2024-03-25T02:10:02.982Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2024-03-25T02:10:02.982Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="starting discovery builtin:dfu-discovery process"
2024-03-25T02:10:02.984Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="started discovery builtin:dfu-discovery process"
time="2024-03-24T21:10:02-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:dfu-discovery"
2024-03-25T02:10:02.991Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-25T02:10:02.991Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="sending command START_SYNC to discovery builtin:dfu-discovery"
2024-03-25T02:10:02.992Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: start_sync, message: OK"
2024-03-25T02:10:02.994Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" location=platform
2024-03-25T02:10:02.996Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\avr\\1.1.13\\libraries" location=platform
2024-03-25T02:10:02.998Z daemon INFO time="2024-03-24T21:10:02-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.7\\libraries" location=platform
2024-03-25T02:10:03.000Z daemon INFO time="2024-03-24T21:10:03-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\hardware\\samd\\1.6.18-beta-b1\\libraries" location=platform
2024-03-25T02:10:03.002Z daemon INFO time="2024-03-24T21:10:03-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
2024-03-25T02:10:03.004Z daemon INFO time="2024-03-24T21:10:03-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino\\avr\\libraries" location=platform
2024-03-25T02:10:03.007Z daemon INFO time="2024-03-24T21:10:03-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\libraries" location=platform
2024-03-25T02:10:03.007Z daemon INFO time="2024-03-24T21:10:03-05:00" level=info msg="Loading libraries index file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-25T02:10:03.136Z daemon INFO time="2024-03-24T21:10:03-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-25T02:10:03.137Z daemon INFO time="2024-03-24T21:10:03-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
2024-03-25T02:10:03.234Z daemon INFO time="2024-03-24T21:10:03-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-25T02:10:03.234Z daemon INFO time="2024-03-24T21:10:03-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino\\avr\\libraries" location=platform
2024-03-25T02:10:03.234Z daemon INFO time="2024-03-24T21:10:03-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
2024-03-25T02:10:06.532Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Checking signature" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-03-25T02:10:06.533Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loading hardware from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages"
2024-03-25T02:10:06.533Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loading package MattairTech_Arduino from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\hardware"
2024-03-25T02:10:06.536Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:10:06-05:00" level=info msg="Loaded platform" platform="MattairTech_Arduino:samd@1.6.18-beta-b1"
2024-03-25T02:10:06.536Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\tools"
time="2024-03-24T21:10:06-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\tools"
2024-03-25T02:10:06.536Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="MattairTech_Arduino:CMSIS-Atmel@1.0.0-mattairtech-2"
2024-03-25T02:10:06.536Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="MattairTech_Arduino:bossac@1.7.0-mattairtech-3"
2024-03-25T02:10:06.536Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loading package SparkFun from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware"
2024-03-25T02:10:06.537Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:10:06-05:00" level=info msg="Loaded platform" platform="SparkFun:avr@1.1.13"
2024-03-25T02:10:06.538Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:10:06-05:00" level=info msg="Loaded platform" platform="SparkFun:samd@1.8.7"
2024-03-25T02:10:06.538Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loading package arduino from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-03-25T02:10:06.539Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\installed.json"
2024-03-25T02:10:06.540Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-25T02:10:06.540Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded platform" platform="arduino:megaavr@1.8.8"
2024-03-25T02:10:06.541Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\installed.json"
2024-03-25T02:10:06.542Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
2024-03-25T02:10:06.542Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded platform" platform="arduino:samd@1.8.14"
time="2024-03-24T21:10:06-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-03-25T02:10:06.542Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-03-25T02:10:06.542Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:CMSIS@4.5.0"
2024-03-25T02:10:06.542Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:CMSIS-Atmel@1.2.0"
2024-03-25T02:10:06.542Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.0"
2024-03-25T02:10:06.542Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.2.1"
2024-03-25T02:10:06.542Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-03-25T02:10:06.542Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@4.8.3-2014q1"
2024-03-25T02:10:06.542Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2024-03-25T02:10:06.543Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino5"
2024-03-25T02:10:06.543Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-03-25T02:10:06.543Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-03-25T02:10:06.543Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.7.0-arduino3"
2024-03-25T02:10:06.543Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.8.0-48-gb176eee"
2024-03-25T02:10:06.543Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2024-03-25T02:10:06.543Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.10.0-arduino7"
2024-03-25T02:10:06.543Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.9.0-arduino"
2024-03-25T02:10:06.544Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loading package builtin from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-03-25T02:10:06.544Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-03-24T21:10:06-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-03-25T02:10:06.544Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-03-25T02:10:06.544Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-03-25T02:10:06.544Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-03-25T02:10:06.544Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-03-25T02:10:06.545Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-03-25T02:10:06.545Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loading package esp32 from: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-03-25T02:10:06.546Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Missing signature file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\installed.json"
2024-03-25T02:10:06.570Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:10:06-05:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
2024-03-25T02:10:06.570Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-03-24T21:10:06-05:00" level=info msg="Loading tools from dir: C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2024-03-25T02:10:06.571Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@3.0.0"
2024-03-25T02:10:06.571Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
2024-03-25T02:10:06.571Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-03-25T02:10:06.571Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2024-03-25T02:10:06.571Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
2024-03-25T02:10:06.572Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-25T02:10:06.572Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
2024-03-25T02:10:06.572Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
2024-03-25T02:10:06.572Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
2024-03-25T02:10:06.572Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-25T02:10:06.572Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-03-25T02:10:06.572Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-03-24T21:10:06-05:00" level=info msg="Loading hardware from: C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware"
2024-03-25T02:10:06.573Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Loading package arduino from: C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino"
2024-03-25T02:10:06.574Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-03-24T21:10:06-05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.4"
2024-03-25T02:10:06.574Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="sending command QUIT to discovery builtin:serial-discovery"
2024-03-25T02:10:06.574Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="from discovery builtin:serial-discovery received message type: quit, message: OK"
2024-03-25T02:10:06.574Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="killing discovery builtin:serial-discovery process"
2024-03-25T02:10:06.574Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Discovery event channel closed builtin:serial-discovery. Exiting goroutine."
2024-03-25T02:10:06.591Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Closed and removed discovery builtin:serial-discovery"
time="2024-03-24T21:10:06-05:00" level=info msg="sending command QUIT to discovery builtin:mdns-discovery"
2024-03-25T02:10:06.591Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: quit, message: OK"
2024-03-25T02:10:06.591Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="killing discovery builtin:mdns-discovery process"
time="2024-03-24T21:10:06-05:00" level=info msg="Discovery event channel closed builtin:mdns-discovery. Exiting goroutine."
2024-03-25T02:10:06.606Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Closed and removed discovery builtin:mdns-discovery"
time="2024-03-24T21:10:06-05:00" level=info msg="sending command QUIT to discovery builtin:dfu-discovery"
2024-03-25T02:10:06.606Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: quit, message: OK"
2024-03-25T02:10:06.606Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="killing discovery builtin:dfu-discovery process"
time="2024-03-24T21:10:06-05:00" level=info msg="Discovery event channel closed builtin:dfu-discovery. Exiting goroutine."
2024-03-25T02:10:06.621Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Closed and removed discovery builtin:dfu-discovery"
2024-03-25T02:10:06.621Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="starting discovery builtin:serial-discovery process"
2024-03-25T02:10:06.623Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="started discovery builtin:serial-discovery process"
time="2024-03-24T21:10:06-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:serial-discovery"
2024-03-25T02:10:06.628Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-25T02:10:06.628Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2024-03-24T21:10:06-05:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
2024-03-25T02:10:06.628Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="starting discovery builtin:mdns-discovery process"
2024-03-25T02:10:06.629Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2024-03-24T21:10:06-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:mdns-discovery"
2024-03-25T02:10:06.633Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: COM1"
2024-03-25T02:10:06.635Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-25T02:10:06.635Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
2024-03-25T02:10:06.635Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2024-03-25T02:10:06.636Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="starting discovery builtin:dfu-discovery process"
2024-03-25T02:10:06.637Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="started discovery builtin:dfu-discovery process"
time="2024-03-24T21:10:06-05:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:dfu-discovery"
2024-03-25T02:10:06.644Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1"
2024-03-25T02:10:06.644Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="sending command START_SYNC to discovery builtin:dfu-discovery"
2024-03-25T02:10:06.645Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="from discovery builtin:dfu-discovery received message type: start_sync, message: OK"
2024-03-25T02:10:06.646Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino\\avr\\libraries" location=platform
2024-03-25T02:10:06.648Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\libraries" location=platform
2024-03-25T02:10:06.650Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries" location=platform
2024-03-25T02:10:06.652Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" location=platform
2024-03-25T02:10:06.653Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\avr\\1.1.13\\libraries" location=platform
2024-03-25T02:10:06.655Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\SparkFun\\hardware\\samd\\1.8.7\\libraries" location=platform
2024-03-25T02:10:06.657Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\packages\\MattairTech_Arduino\\hardware\\samd\\1.6.18-beta-b1\\libraries" location=platform
time="2024-03-24T21:10:06-05:00" level=info msg="Loading libraries index file" index="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\library_index.json"
2024-03-25T02:10:06.753Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-25T02:10:06.754Z daemon INFO time="2024-03-24T21:10:06-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
2024-03-25T02:10:07.201Z discovery-log INFO start
2024-03-25T02:10:07.201Z discovery-log INFO start new deferred
2024-03-25T02:10:07.201Z discovery-log INFO start resolved watching
2024-03-25T02:10:07.201Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-03-25T02:10:07.364Z root ERROR ---- !!!SLOW!!! DURATION: search took 163.411 ms. Args: [{}] ----
2024-03-25T02:10:07.364Z root INFO <<< Library package installation done. {
  exampleUris: [],
  author: 'Arduino',
  includes: [],
  category: 'Other',
  index: 0
2024-03-25T02:10:07.365Z root WARN Detected a new port that has been already discovered. The old value will be overridden. Old value: {"port":{"address":"COM1","addressLabel":"COM1","protocol":"serial","protocolLabel":"Serial Port"},"boards":[]}, new value: {"boards":[],"port":{"address":"COM1","addressLabel":"COM1","protocol":"serial","protocolLabel":"Serial Port"}}
2024-03-25T02:10:07.612Z root INFO Starting language server: arduino:avr:uno
2024-03-25T02:10:07.955Z daemon INFO time="2024-03-24T21:10:07-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-25T02:10:07.955Z daemon INFO time="2024-03-24T21:10:07-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino\\avr\\libraries" location=platform
2024-03-25T02:10:07.955Z daemon INFO time="2024-03-24T21:10:07-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
2024-03-25T02:10:08.338Z daemon INFO time="2024-03-24T21:10:08-05:00" level=info msg="Resolving include TinyGPSPlus.h for arch avr"
2024-03-25T02:10:08.338Z daemon INFO time="2024-03-24T21:10:08-05:00" level=info msg="  found better lib" lib=TinyGPSPlus prio=6A7
2024-03-25T02:10:09.064Z daemon INFO time="2024-03-24T21:10:09-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-03-25T02:10:09.064Z daemon INFO time="2024-03-24T21:10:09-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\hardware\\arduino\\avr\\libraries" location=platform
2024-03-25T02:10:09.064Z daemon INFO time="2024-03-24T21:10:09-05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Roger Hammond\\Documents\\Arduino\\libraries" location=user
I can now see the location of the "Arduino AVR Boards " platform version 1.8.4 installation:
It is still not clear to me why the presence of this installation causes this problem. I guess the configuration of the platform is broken in some way. If so, the problem should be solved by deleting the bad platform:
Please try this:
  1. If Arduino IDE is running, select File > Quit from the Arduino IDE menus.
    All Arduino IDE windows will close.
  2. Delete the folder at the following path:
    C:\Users\Roger Hammond\Documents\Arduino\hardware\arduino\avr
    :warning: Please be careful when deleting things from your computer. When in doubt, back up!
Now start Arduino IDE. You will still see the messages about the first run dependency installations (which the IDE will attempt to install on every startup until it is successful), but this time it should look something like this:
Tool arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7 already installed
Tool arduino:avrdude@6.3.0-arduino17 already installed
Tool arduino:arduinoOTA@1.3.0 already installed
Downloading packages
arduino:avr@1.8.6
Installing platform arduino:avr@1.8.6
Configuring platform.
Platform arduino:avr@1.8.6 installed
Already installed Keyboard@1.0.5
Already installed LiquidCrystal@1.0.7
Already installed SD@1.2.4
Already installed Servo@1.2.1
Already installed Stepper@1.1.3
Already installed Ethernet@2.0.2
Already installed Firmata@2.5.9
Already installed Mouse@1.0.1
Already installed TFT@1.0.6
Already installed Arduino_BuiltIn@1.0.0
(note that the "Could not find platform. " error did not occur this time)
On subsequent IDE startups, you will not see these message since it has now completed the first run dependencies installation process successfully.
Success!
It looks like that solved my problem!
I appreciate all of the help you've given me on this issue. I have had some strange things going on for quite some time (likely my own fault) and I thought updating might resolve the issue.
Thank you again for all of your help and patience.
Have a great day!
R. Hammond
You are welcome. I'm glad it is working now.
Regards,
Per
