Issues burning bootloader onto new 328P-PU chips using UNO as ISP (8MHz)
Let me preface this that I did reference the existing thread from 2011, but the solution therein did not fix my issue.
I'm trying to load my program onto a 328P chip using an Uno as an ISP. This chip will be using its internal oscillator at 8MHz.
Following https://www.arduino.cc/en/Tutorial/ArduinoISP, I loaded my UNO without any fanfare.
I then used the ICSP pins to wire to my 328P chip (in a ZIF socket) and placed a 10uF cap between GND (typo has been fixed) and RESET. I tested for continuity and found all was good.
I then attempted to burn the appropriate(?) bootloader to my 328P (programmer as "Arduino as ISP") with my board selection as "ATmega328 on breadboard" from the minimal configuration found under https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard. I get a failure and the error reads
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
I'm assuming that somewhere I need to alter or add an entry for 328P, but I'm at a loss as to where. I can't even find the "ATmega328 on a breadboard" entry in my boards.txt to even reference it. Looking at the avrdude.conf, there's some language about 328P after the 328 entry, but I've no clue what it is actually doing.
Prop-Forge:
...and placed a 10uF cap between 5V and RESET...
Ding, ding, ding. We have a winner!
Is the 10 uF capacitor on the Uno, or on the breadboard?
Prop-Forge:
No. That's has nothing to do with your error. That board is actually configured for ATmega328P, and won't even work for ATmega328. For some reason, all through Arduino's documentation and board names, they used to call ATmega328P "ATmega328". I guess the person writing the stuff didn't know that there is an important difference between ATmega328 and ATmega328P and, no, you can't just leave off the "P" (and why would you want to anyway?). This inaccuracy caused a lot of confusion over the years. I went on a campaign to get it all fixed a while back and did manage to get a lot of it fixed, but for some reason they balked at fixing the error in all of the documentation, including that Arduino on a Breadboard tutorial:
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Check the checkbox next to "Show verbose output during: upload
  • Click "OK"
  • Tools > Burn Bootloader
  • After the Burn Bootloader process fails, you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the Burn Bootloader output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
The capacitor is on the Uno I'm using as my programmer.
Error as follows:
Arduino: 1.8.9 (Windows 7), Board: "ATmega328 on a breadboard (8 MHz internal clock)"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% -0.00s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.00s
Error while burning bootloader.
         this check.
avrdude done.  Thank you.
option enabled in File -> Preferences.
Prop-Forge:
Still wired incorrectly?
Nope. It was correct on the board, but I had a brain fart when I was typing.
Any possibility the chip already has the fuses set for a crystal? Some Vendors put the Uno bootloader on the chips.
If that is the case you will either have to put a crystal on your chip or install the chip on a spare Uno to burn the 8MHz internal clock bootloader and fuses or check out Gammon's breadboard using pin 9, Alternate clock source.
kprims:
Gammon Forum : Electronics : Microprocessors : How to make an Arduino-compatible minimal board
I bought them (from Digikey I think) without the bootloader on them, and this one in particular is right from the tube and has never been used before.
Is this the same thing the UNO is doing? I do have a Tiny AVR programmer from SF.
If I'm going to have to do a fair number of these chips, now and into the future, am I better off just buying a dedicated programmer that can reset fuses and do all that nonsense?
Is this Technoblogy - Using an ATmega328 without a crystal the same thing as the UNO is doing? I have a Tiny AVR programmer from SF.
Yes A USBtinyISP will do the same thing for burning the bootloader and setting the fuses. You would select Programmer: USBtinyISP with it wired correctly.
You may have a bad chip, try another one. Remember, if the fuses have been set for an external clock you will still need a crystal to change the fuses.
...reasonable clock signal on XTAL1. An actual crystal is not required.
That could be accomplished via Gammon's pin D9 method?
Yes.
There are at least two published versions of the ArduinoISP sketch capable of providing a clock.
If I were to use my TINY AVR Programmer as a programmer, and seat the 328P to be bootloaded/programmed into the UNO, I assume I'd just hook up the 6 ICSP pins:
1-1
2-2
6-6
and proceed with ArduinoISP for loading the bootloader to the 328P (on the UNO).
That way, I can program the 328P to be either 8 or 16MHz, right?
Yes. But you should select USBtinyISP as the programmer. You might want to check out MiniCore also.
Minicore
"Yes" that it will work.
"I don't know" in regards to the wiring. I believe you are correct that the wiring is "straight through". But I suggest a careful check of the Sparkfun documentation. At a minimum, do not mix up VCC and GND.
