I have been trying to combine a light code with this tone keyboard so that when the button is pressed, sound and light are produced. A different LED for the different buttons. this is the code i have now, and its just for the tone KB, please how to i combine the LED section to this?
Keyboard
Plays a pitch that changes based on a changing
input circuit:
3 pushbuttons from +5V to analog in 0 through
3
3 10K resistors from analog in 0 through 3 to
ground
// if button press on A0 is detected
if (digitalRead(A0) == HIGH) {
tone(8, 440, 100); // play tone 57 (A4 = 440 Hz)
// if button press on A1 is detected
if (digitalRead(A1) == HIGH) {
tone(8, 494, 100); // play tone 59 (B4 = 494 Hz)
if (digitalRead(A2) == HIGH) {
tone(8, 523, 100); // play tone 60 (C5 = 523 Hz)
delay(10); // Delay a little bit to improve simulation performance
PaulS:
Of course, with those useless delay()s, make sure you press the switch long enough.
Small steps Paul.
You may want to jump in and solve all of the problems at once but I don't think the OP is ready for that. I am sure that we can see plenty of problems coming down the line if delay() is used but let's deal with them as they arise.
I totally agree. I just want OP to be aware of the fact that the direction he is moving while painting the floor is not the direction where the door is.
