Issues compiling StandardFirmata example?
Hi all,
I'm trying to verify / compile the StandardFirmata example (https://github.com/No9/arduino-sketches/blob/master/StandardFirmata.cpp) in the Arduino 1.0.5 environment, and I made sure to add Firmata.cpp/.h and Boards.h to the sketch. However, it's repeatedly erroring with " 'class FirmataClass' has no member named 'write' ". (It definitely is defined in both Firmata.h and .cpp.) I have no clue what's going wrong - any help would be appreciated!
What does this mean? You weren't supposed to make ANY changes to the sketch.
I tried it with no changes first and found the same error. I included the other files when I noticed that StandardFirmata had an #include <Firmata.h> which I figured probably had to be in the same project file, but it didn’t seem to help when I added it.
I just noticed that the file I linked was a .cpp, but the file that I was using (that auto-downloaded as example code) is a .ino - I don’t imagine this is a problem, but I could be wrong.
For some reason, closing and reopening the program fixed the problem =/ thanks anyway
