int x;
int speed_inv = 1000;
pinMode(9,OUTPUT); // 9 as PUL
pinMode(8,OUTPUT); // 8 as DIR
pinMode(3, OUTPUT); // 3 as LED
digitalWrite(8,HIGH); // rotation +
digitalWrite(3,HIGH); // LED ON
// repeat 400 times a revolution when setting 400 on driver
for(x = 0; x < 400; x++){
digitalWrite(9,HIGH); // Output high
delayMicroseconds(speed_inv);
digitalWrite(9,LOW); // Output low
digitalWrite(3,LOW); // LED OFF
Board : Arduino UNO R3 Digital Stepper Driver : DM556T PSU : 24V/DC, 2.5A, 60W Stepper Motor : NEMA 23
More information • The motor works, I have already tried the same configuration (but in "common-anode") with a PLC (Zelio) and the ACE 11 from Velocio.net and it worked. • I have already tried also replacing the stepper driver, and it still doesn't work. • I tried both config' for the stepper driver: "common-anode" and "common-cathode". • With an ammeter, between PUL+ and PUL- there are pulses of 0 to 5V and 5V between DIR+ and DIR-. • I tried several wiring several codes found on the internet but nothing worked.
Thank you to those who take the time to read and respond in advance.
Have a good day
Hello, thank you for the response.
I did not give all the information, sorry !
The motor is supposed to run but it does not, this is the part of the project that does not work (but the motor is running, as indicated above, on another project)
The code is correct (from what I have seen on the internet, it seems to be good and it is compilable).
The LED works well, it's a way for me to see the status of the program.
I have already done this kind of project and the motor was running well (same power supply, same stepper driver, same motor but a PLC)
(and I just redid it it still works)
Sorry, than I don't know the problem. I'm actually a Beginner (I have been doing arduino for 6months). I will think about this and give you as soon as possible an answer. But at the moment...
I hope your project will work one day.
I'm sorry to say these sentences. But I don't know the problem or the soloution.
But you should looking forward to hearing from me soon
Thank you, I appreciate your involvement in my issue, even if it is not solved yet.
I also hope that this project will succeed (I'm also a beginner) !
I will wait for your news or those of someone else, who knows.
The black wire is connected with two wires from the stepper. These three wires are in the breadbord at the -port. I think thats's GND. But please correct me, if I'm wrong
I am fairly certain that you do not have the ground of the servo driver connected to the UNO. connect a jumper from the terminal on the servo driver marked ground to the breadboard rail where you have the black wire from the UNO inserted and try running your code.
Hi everyone, thanks for taking the time to respond!
I'm sorry, I got home early and won't have a chance to review the system until Monday (I'm really sorry).
But what I can tell you is that the GND from the driver isn't connected to the UNO GND but to the - of the PSU. Is it a problem ?
Ok i see, this is probably the error causing the motor not to spin...
I will come back to the project on Monday and I will let you know if the problem is solved or not.
