Hi everyone,
I'm using an ESP8266 with a 128x64 OLED display and the U8g2 library. Despite following the documentation, my bitmap isn't displaying correctly. Here's my setup:
- Pins: SCL - GPIO 5 (D1), SDA - GPIO 4 (D2)
- Code Snippet:
#include <Arduino.h>
#include <U8g2lib.h>
// Declarar el constructor para la pantalla OLED
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, /* clock=*/ 14, /* data=*/ 12, /* reset=*/ U8X8_PIN_NONE);
// Array de la imagen del gato
const unsigned char epd_bitmap_images [] PROGMEM = {
0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0xE0, 0x00,
0x80, 0x0F, 0x00, 0x00, 0xF0, 0x01, 0xC0, 0x3D, 0x00, 0x00, 0xBC, 0x03,
0xC0, 0x70, 0x00, 0x00, 0x0E, 0x03, 0x60, 0xE0, 0x00, 0x00, 0x07, 0x06,
0x60, 0xC0, 0x01, 0x80, 0x03, 0x06, 0x30, 0x80, 0x03, 0xC0, 0x01, 0x0C,
0x30, 0x00, 0x07, 0xE0, 0x00, 0x0C, 0x18, 0x00, 0x06, 0x60, 0x00, 0x18,
0x18, 0x00, 0x0C, 0x30, 0x00, 0x18, 0x18, 0x00, 0xFC, 0x3F, 0x00, 0x18,
0x0C, 0x00, 0xFC, 0x3F, 0x00, 0x30, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x30,
0x0C, 0x00, 0x00, 0x00, 0x00, 0x30, 0x06, 0x00, 0x00, 0x00, 0x00, 0x60,
0x06, 0x00, 0x00, 0x00, 0x00, 0x60, 0x06, 0x00, 0x00, 0x00, 0x00, 0x60,
0x06, 0x00, 0x00, 0x00, 0x00, 0x60, 0x03, 0xE0, 0x01, 0xC0, 0x03, 0xC0,
0x03, 0xE0, 0x03, 0xC0, 0x07, 0xC0, 0x03, 0x30, 0x03, 0x60, 0x06, 0xC0,
0x03, 0x70, 0x03, 0xE0, 0x06, 0xC0, 0x03, 0xE0, 0x03, 0xC0, 0x07, 0xC0,
0x03, 0xC0, 0x01, 0x80, 0x03, 0xC0, 0x03, 0x00, 0x00, 0x00, 0x00, 0xC0,
0x03, 0x00, 0xFC, 0x0F, 0x00, 0xC0, 0xC3, 0x03, 0xFC, 0x0F, 0xF0, 0xC0,
0x83, 0xFF, 0x18, 0xC6, 0xFF, 0xC0, 0x03, 0xFC, 0x37, 0xFB, 0x0F, 0xC0,
0x03, 0x00, 0xF7, 0x33, 0x00, 0xC0, 0xC3, 0x03, 0xE0, 0x01, 0xF0, 0xC0,
0xC6, 0x7F, 0xC0, 0x80, 0xFF, 0x60, 0x06, 0xFC, 0xC7, 0xF8, 0x0F, 0x60,
0x0E, 0x80, 0xC7, 0x78, 0x00, 0x70, 0x0C, 0x00, 0xC0, 0x00, 0x00, 0x30,
0x1C, 0x00, 0xC0, 0x00, 0x00, 0x38, 0x38, 0x00, 0xC0, 0x00, 0x00, 0x1C,
0x70, 0x00, 0x40, 0x00, 0x00, 0x0E, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x07,
0xC0, 0x03, 0x00, 0x00, 0xC0, 0x03, 0x00, 0x0F, 0x00, 0x00, 0xF0, 0x00,
0x00, 0x7E, 0x00, 0x00, 0x7E, 0x00, 0x00, 0xF8, 0x0F, 0xF0, 0x0F, 0x00,
0x00, 0xC0, 0xFF, 0xFF, 0x03, 0x00, 0x00, 0x00, 0xF0, 0x0F, 0x00, 0x00,
void setup(void) {
u8g2.begin();
void loop(void) {
u8g2.clearBuffer(); // Limpiar el buffer de la pantalla
u8g2.drawXBMP(0, 0, 128, 64, epd_bitmap_images); // Dibujar la imagen en la pantalla
u8g2.sendBuffer(); // Enviar el buffer a la pantalla
Despite this, the image appears corrupted. Any advice on what might be wrong? Thanks!
********EDIT ************
I was able to resolve the issue, it was my stupidity, i had the wrong settings on the image2cpp....
The canvas size I selected did not match my actual size.
