Issues getting SdFat libraries to work
I’m struggling getting SD devices working with nRF2401 wireless transcievers, and It’s been suggested a different sd library should be used.
Basically replacing
#include <SD.h>
with
#include <SdFat.h>
SdFat SD;
Issue #1
My IDE (1.6.10) can’t find the SdDat.h which is located in:
C:\Program Files (x86)\Arduino\libraries\SD\src\utility
how do you include this h file?
Issue #2 (after severly hacking my folder structure–which can’t be what everyone else does to get libraries working…) my next issue will be SdFat does not name a type on this line:
SdFat SD;
Thanks in advance.
// it's been suggested to get SD devices working with nRF2401 wireless transcievers, a different
// sd library should be used
// but my IDE can't find the SdDat.h which is located in:
// C:\Program Files (x86)\Arduino\libraries\SD\src\utility
// how do you include this h file?
#include <SdFat.h>
// assuming i can find the library
//my next issue will be SdFat does not name a type
SdFat SD;
KrisKasprzak:
Basically replacing
#include <SD.h>
with
#include <SdFat.h>
Where was this suggested. If it was publicly please post a link. Although the Arduino SD library does contain a file named SdFat.h, my guess is they are actually talking about a 3rd party library of that name, most likely GitHub - greiman/SdFat: Arduino FAT16/FAT32 exFAT Library. You would need to install that library.
If you actually did want to include the SdFat.h file located at C:\Program Files (x86)\Arduino\libraries\SD\src\utility\SdFat.h you would need to do this:
#include <SD.h>
#include <utility/SdFat.h>
The first line adds the C:\Program Files (x86)\Arduino\libraries\SD\src\utility folder to the include path.
KrisKasprzak:
SdFat SD;
Further evidence that it’s the 3rd party SdFat library you should be using.
The suggestion was from this post from a member named "fat16lib"
I'll try that library
Thanks
OK, they said SdFat beta so it could actually be this one instead(same author but different repository): GitHub - greiman/SdFat-beta: Beta SdFat for test of new features. Of course that message was 2014 so what was beta then might not be beta now.
