Hi everyone,
I am trying to build a LED clock using Arduino Nano, DS1307 RTC , LED matrix display.
I have succeeded in displaying the time and date as per the code sourced from many forums .
My requirements are that :
Time should be displayed. (Currently the seconds part is not fully visible due to the display being only 4 LED matrix units)
Current date to be displayed after an animation like "FADE". (Currently the year part is not fully visible due to the display being only 4 LED matrix units. Eg: 26/12 is only visible instead of 26/12/2017)
Temperature (LM35), Day and Month name to be displayed after an animation like "SLICE". (Not yet started).
The main issue is that although the time is being displayed I am facing difficulty in making the "timeStamp" into an animation effect as per the MD_Parola catalog.
Any guidance would be much appreciated.
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include <MD_DS1307.h>
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#include <RTClib.h>
#define MAX_DEVICES 4
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
RTC_DS1307 rtc;
MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
//MD_Parola P = MD_Parola(CS_PIN, MAX_DEVICES);
void setup ()
Wire.begin();
Serial.begin(57600);
P.begin();
if(! rtc.begin())
Serial.println("Couldn't find RTC");
while (1);
if(! rtc.isrunning())
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
void loop ()
DateTime now = rtc.now();
char timeStamp[15];
char dateStamp[15];
if(now.hour() > 12)
int h = now.hour() - 12 ;
sprintf(timeStamp, "%d:%d:%d", h ,now.minute(), now.second());
Serial.println(timeStamp);
sprintf(dateStamp, "%d/%d/%d", now.day(),now.month(),now.year());
Serial.println(dateStamp);
P.print(timeStamp);
if (now.second() == 25 | now.second() == 35)
P.print(dateStamp);
delay(5000);
#define SPEED_TIME 25
#define PAUSE_TIME 2000
P.displayText(timeStamp, CENTER, SPEED_TIME, PAUSE_TIME, SCROLL_LEFT, SCROLL_RIGHT);
P.displayAnimate();
OR
P.displayText(timeStamp, SPEED_TIME,PAUSE_TIME,PA_SLICE);
P.displayAnimate();
Since i am typing from my mobile I am unable to add these and see the endresult. So i am asking the Gurus if I can get any animation using the above lines?
Or am i missing anything here.
I just want to add animation to the time displayed in the matrix display.
This is the one which I did. Hope someone can simplify it if needed.
#include <Wire.h>
#include <SPI.h>
#include <RTClib.h>
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
#define PAUSE_TIME 3000
#define SCROLL_SPEED 30
RTC_DS1307 rtc;
//MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
void setup ()
Wire.begin();
P.begin();
if(! rtc.begin())
while (1);
void loop ()
char timeStamp[15];
char dateStamp[15];
sprintf(timeStamp, "%02d:%02d", now.hour() ,now.minute());
sprintf(dateStamp, "%02d/%02d", now.day(),now.month());
for (uint8_t i=0; i<ARRAY_SIZE(timeStamp); i++)
P.displayText(timeStamp, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_MESH);
P.displayAnimate();
while (!P.displayAnimate())
for (uint8_t q=0; q<ARRAY_SIZE(timeStamp); q++)
int dow = now.dayOfTheWeek();
char *d ;
switch(dow)
case 1:
Serial.println("MON");
d = "MON";
case 2:
Serial.println("TUE");
d = "TUE";
case 3:
Serial.println("WED");
d = "WED";
case 4:
Serial.println("THU");
d = "THU";
case 5:
Serial.println("FRI");
d = "FRI";
case 6:
Serial.println("SAT");
d = "SAT";
case 0:
Serial.println("SUN");
d = "SUN";
P.displayText(d, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_BLINDS);
P.displayAnimate();
for (uint8_t j=0; j<ARRAY_SIZE(dateStamp); j++)
P.displayText(dateStamp, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_SCROLL_LEFT);
for (uint8_t r=0; r<ARRAY_SIZE(dateStamp); r++)
int moy = now.month();
char *e ;
switch(moy)
case 1:
Serial.println("JAN");
e = "JAN";
case 2:
Serial.println("FEB");
e = "FEB";
case 3:
Serial.println("MAR");
e = "MAR";
case 4:
Serial.println("APR");
e = "APR";
case 5:
Serial.println("MAY");
e = "MAY";
case 6:
Serial.println("JUN");
e = "JUN";
case 7:
Serial.println("JUL");
e = "JUL";
case 8:
Serial.println("AUG");
e = "AUG";
case 9:
Serial.println("SEP");
e = "SEP";
case 10:
Serial.println("OCT");
e = "OCT";
case 11:
Serial.println("NOV");
e = "NOV";
case 12:
Serial.println("DEC");
e = "DEC";
P.displayText(e, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_SCAN_HORIZ);
P.displayAnimate();
for (uint8_t k=0; k<ARRAY_SIZE(dateStamp); k++)
int iVarToCast = now.year();
char buffer[4];
dtostrf(iVarToCast, 4, 0, buffer);
P.displayText(buffer, PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_SCROLL_LEFT);
Serial.println(buffer);
vijithcv:
Everything works except two issues.
The Week and Month name is clipped if I use the scroll function. Eg: It shows only Januar and while it scrolls it doesn't display the remaining.
The seconds doesn't increment while I enable the Parola scroll or any other animation. Its like the current second is saved in the char array and its displaying that value at that instant only.
I added a LM35 Sensor and I face the same issue wherein the temperature is not displayed real time. If there is any increase in temperature its displayed in the next animation sequence. Its also like frozen.
I think when the value is put into a char array and while using Parola library it shows the value as a word and any change in the value is shown in the next cycle of animation.
I hope i made my problem little bit clear.
Anyway it keeps the time and temperature day and date properly. Only minus I am not getting a live display.
