Issues integrating lock, reed switch and load cell sensor in arduino program
Hi, I am trying to integrate solenoid lock, reed switch and load cell sensor in my arduino program. The issue I am facing is when I am using void loop the weight cell show the weight readings initially as 0 (no issues here), however, when I am trying to avoid using void loop and integrate lock and reed switch in my arduino program (my project requires not to get stuck in the void loop), the load cells initially show a different value (~34). I am unable to know here the issue is. Does integrating lock and reed switch affect the load cell readings? Here is my program when I am using the void loop in my program -
#include<HX711_ADC.h>
HX711_ADC LoadCell(4,5);
//Arduino state flag
bool arduino_state_flag = true;
int number = 0;
int lastWeightRecorded= 0;
int totalWeight = 0;
float i;
int led_pin= 9;
bool led_flag = false;
  Serial.begin(38400);
  LoadCell.begin();
  LoadCell.start(2000);/
  LoadCell.setCalFactor(130040);
  pinMode(led_pin, OUTPUT);
  const unsigned long time_delay = 2000UL;
    static unsigned long lastSampleTime = 0 - time_delay;
    unsigned long now = millis();
    LoadCell.update();
    if(now - lastSampleTime >= time_delay)
      lastSampleTime += time_delay;
        i = LoadCell.getData();
        int i_gram = i * 1000;
        if (i_gram > 5)
          led_flag = true;
          ledBlink();
            if(i_gram != lastWeightRecorded)
                lastWeightRecorded = i_gram;
                totalWeight = i_gram;
                //data[0] = totalWeight;
                //sendDataSerial();
                Serial.println("Testing");
          Serial.println("External object detected");
          Serial.print("Its weight is  :");
          Serial.println(totalWeight);
           else if ((i_gram <= -5) && (i_gram != lastWeightRecorded ))
            //It means some object has been removed from the basket so send the data to raspberry Pi
            led_flag = false;
            ledBlink();
            Serial.print("Weight[grams]: ");
            else if ((i_gram == 0) || (i_gram == -0) || (i_gram == lastWeightRecorded))
              led_flag = false;
              ledBlink();
              Serial.println("No weight change is detected");
              Serial.print("Tol Weight: ");
bool ledBlink()
  if(led_flag == true){
    digitalWrite(led_pin, HIGH);
    digitalWrite(led_pin, LOW);
    else if(led_flag == false){
The serial output is in Attachment 1. Here is my program without using void loop-
int number = 0;
float i;
int i_gram;
int led_pin= 9;
//pins for lock
int solenoidPin = 7;
//pins for reed switch
int reedSwitch = 2;
bool reedSwitchStatus;
bool receivedValue = true;
int x;
  pinMode(solenoidPin, OUTPUT);
  pinMode(reedSwitch, INPUT);
  digitalWrite(solenoidPin, HIGH);
  LoadCell.begin();//start connection to HX711
  LoadCell.start(2000);//load cells get 2 seconds to stabilize
  //For LED pin
  doorUnlock();
void doorUnlock()
  Serial.println("Door will be unlocked now");
  digitalWrite(solenoidPin, LOW);
  delay(5000);
  checkReedSwitchStatus();
void checkReedSwitchStatus()
  reedSwitchStatus = digitalRead(reedSwitch);
  if (reedSwitchStatus == 1)
      x = 1;
      weightTransaction();
      x = 0;
void weightTransaction()
  while(x==1)
    beginTransaction();
  while(x==0)
    endTransaction();
void beginTransaction()
        i_gram = i * 1000;
        Serial.print("Check i_gram ");
        Serial.println(i_gram);
        if (i_gram > 5)
          led_flag = true;
          ledBlink();
                Serial.println("Loop 1");
            Serial.println("Loop 2");
            led_flag = false;
            ledBlink();
              Serial.println("Loop 3");
              led_flag = false;
              ledBlink();
void endTransaction()
  Serial.println("ReedSwitch Detected. The system will close now");
    delay(3000);
    data[0] = 1000;
    LoadCell.powerDown();
    Wire.endTransmission();
  delay(50);
bool ledBlink()
The serial output for the above program is shown in Attachment 2. I am unable to understand why does the load cell show ~-34 in the second program. Kindly let me know where the issue is. Thanks in advance.
The first sketch only reads the loadcell every 2 seconds. The second sketch doesn't have that delay, although the logic is difficult to follow. You should check out the [Several Things at a Time[\url] to get a better idea about how to implement what you are trying to do.
You want to have your loop() executing as quickly as possible and remove all of your delay() calls and switch to calculating elapsed time. You can see an example in the IDE (File->Examples->02. Digital->BlinkWithoutDelay)](Demonstration code for several things at the same time - Project Guidance - Arduino Forum)
