Issues pertaining to the WiFi "Server" for the Nano RP2040
So I have some issues pertaining to the WiFiNINA_Generic Server example code, at least, a modified version of it. The main issues is that the Nano "crashes" when it gets to the point highlighted in the included code. I kind of need that line, so if anyone knows how to fix this, please tell me. I wo
#include <WiFiNINA_Generic.h>
#include <Arduino_LSM6DS3.h>
#include "defines.h"
#include <Servo.h>
#include <Wire.h>
#include <SPI.h>
static const double AVERAGE_GRAVITY_ERROR = 0.05;
static const byte BUZZER_PIN = 4;
static const byte SERVO_PIN = 5;
static char ssid[] = ""; // your network SSID (name)
static char pass[] = ""; // your network password (use for WPA, or use as key for WEP), length must be 8+
double directionVector[3];//x,y,z
double averageAcceleration[3];//x,y,z
double averageAngle[3];//x,y,z
double accelerationMagnitude;
double verticalDisplacement;
double velocityAfterInitalAcceleration;
double netVelocity;
float gyro[3];
float accel[3];
//0: while timer
//1: total time from the start to last average
//2: total time from the start to this average
int timer[3];
int keyIndex = 0;                 // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
//The times when the rocket starts(ignition), apogee, ends(impact), and Acceleration Ends
int times[4];
bool isLanded = false;
bool chuteDeployed = false;
boolean currentLineIsBlank;
char c;
WiFiServer server(80);
WiFiClient client;
Servo releaseServo;
  pinMode(BUZZER_PIN, OUTPUT);
  releaseServo.attach(SERVO_PIN);
  releaseServo.write(0);//"Zeros" the servo at the closed position
  //IMU.begin();//Starts the IMU
  //Wait until connected
  while(status != WL_CONNECTED){
    Serial.print(F("Attempting to connect to SSID: "));
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
  // print the SSID of the network you're attached to:
  Serial.print(F("SSID: "));
  Serial.println(WiFi.SSID());
  Serial.print(F("IP Address: "));
  server.begin();
  client = server.available();
  //Buzzes that the Nano is powered
  analogWrite(BUZZER_PIN, 150);
  delay(100);
  analogWrite(BUZZER_PIN,  0 );
  while(!client){
    Serial.println("Waiting for a client!");
    delay(100);
  Serial.println("Client Connected!");
  if(client){
    // an http request ends with a blank line
    currentLineIsBlank = true;
    while(client.connected()){
      startClient();
      client.println("Getting Data");
      endClient();
  int waitTime = 2000;
  timer[0] = millis();
  while(timer[0] - millis() <= waitTime){
    IMU.readGyroscope(gyro[0], gyro[1], gyro[2]);
    IMU.readAcceleration(accel[0], accel[1], accel[2]);
    Serial.println(gyro[0]);
    Serial.println(gyro[1]);
    Serial.println(gyro[2]);
    Serial.println(accel[0]);
    Serial.println(accel[1]);
    Serial.println(accel[2]);
    timer[2] = millis() - timer[0];//Total time since start
    for(byte i = 0; i < 3; i++){
      //Gravity is fluctuating if it swings above 1.05 and bellow 0.95. It adds 50 milliseconds to the timer when this occurs
      if((averageAcceleration[i] + AVERAGE_GRAVITY_ERROR >= 1.05 || averageAcceleration[i] - AVERAGE_GRAVITY_ERROR <= 0.95) && timer[0] - millis() >= 1750) waitTime += 50;
      averageAcceleration[i] = (averageAcceleration[i] * timer[1] + accel[i]) / timer[2];
      directionVector[i] = (directionVector[i] * timer[1] + cos(gyro[i]) * accel[i]) / timer[2];
      averageAngle[i] = (averageAngle[i] * timer[1] + gyro[i]) / timer[2];
    //After 20 seconds, yells and terminates
    if(waitTime >= 20000){
      digitalWrite(BUZZER_PIN, HIGH);
      digitalWrite(BUZZER_PIN, LOW);
      client.println("Unable to get good vectors!/nRestart Please");
      while(true);//Does not proceed with anything else
    timer[1] = millis() - timer[0];
    if(client){
        startClient();
        updateClient();
        endClient();
  //Signify that the data collection is done
  delay(50);
bool isInFlight = false;
  if(client){
      Serial.println("In Loop, with a client");
      startClient();
      updateClient();
      endClient();
  //Gravity should be positive, so when ANY of them go negative
  if(isInFlight == false){
      //In Flight if any go negative beyond a certain value
      if(accel[i] <= -0.1){
        isInFlight = true;
        //Ignition
        if(times[0] == 0) times[0] = millis();
  if(isInFlight == true){
    //c = square root (x^2 + y^2)
    double c = pow(0.5, (pow(2, accel[0]) + pow(2, accel[1])));
    //v = square root (z^2 + c^2)
    accelerationMagnitude = pow(0.5, (pow(2, accel[2]) + pow(2, c) ) );
    if(!chuteDeployed){
      timer[1] = millis();
      //Takes the magnitude of acceleration, times the difference in time
      netVelocity = accelerationMagnitude * (timer[1] - timer[0]);
      if(!(accelerationMagnitude + AVERAGE_GRAVITY_ERROR >= 1.0) || !(accelerationMagnitude - AVERAGE_GRAVITY_ERROR <= 0.95)){
        velocityAfterInitalAcceleration += accelerationMagnitude * (timer[1] - timer[0]);
      verticalDisplacement += netVelocity * (timer[1] - timer[0]);
    //And now we have the current magnitude of acceleration
    //If it's within an error, then we are now falling only under gravity
    if((netVelocity + AVERAGE_GRAVITY_ERROR >= -0.05 || netVelocity - AVERAGE_GRAVITY_ERROR <= 0.05) && !chuteDeployed){
      times[1] = millis();//Updates the apogee time
      chuteDeployed = true;
  //Deploy the chute 1 second after apogee
  if(chuteDeployed){
    //Tries it again
    if(status != WL_CONNECTED){
      Serial.println("Can't connect!");
    if(times[1] + 1000 >= millis()){
      releaseServo.write(180);
      if(client){
          startClient();
          updateClient();
          client.println(times[0]);
          client.println(times[1]);
          client.println(times[2]);
          endClient();
void startClient(){
  if(client.available()){
    //It hangs here!
    c = client.read();
    Serial.write(c);
    // if you've gotten to the end of the line (received a newline
    // character) and the line is blank, the http request has ended,
    // so you can send a reply
    if(c == '\n' && currentLineIsBlank){
      //Basic setup info
      client.println("Content-Type: text/html");
      client.println("Connection: close");  // the connection will be closed after completion of the response
      client.println("Refresh: 1");  // refresh the page automatically every 1 sec
      client.println();
      client.println("<!DOCTYPE HTML>");
      client.println("<html>");
void endClient(){
  if(client){
    client.println("</html>");
    if(c == '\n'){
      //Starting a new line
    }else if(c != '\r'){
      //Character is on the current line
      currentLineIsBlank = false;
  // give the web browser time to receive the data
  delay(1);
  // close the connection:
  client.stop();
void updateClient(){
  //Putting the data on the site
//This stuff isn't nesscasary, just putting things. No real stuff going on here
I don't see any "highlighted" line in your code.
So it is in the 'startClient' method, near the bottom.
I think your issue might be the last two lines. I think they should be part of the if clause. Think about what happens when if(client) returns false?
Yeah, that was the issue. Looking at the example, the client.end() is within the if(client){}
