I am using arduino uno as a programmer and atmega32 as a target. I uploaded arduinoISP sketch with the programmer "AVRISP mkll". Then hooked up a 22 uf capacitor on reset and ground. I connected to atmega32 with vcc to vcc(pin 10 in target) and gnd to gnd(pin 11 and 31), pin 10, 11, 12, 13 to target pins 9, 6, 7, 8 which are reset, sck, mos0, mos1. Opened blink sketch with pin mode 13 output, selected board "atmega32 8mhz" then selected programmer "Arduino as ISP", and uploaded using a programmer.
Then this error shows up: avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
What did I do wrong though?
Verbose output:
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "E:\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega32
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 10 64 0 no 1024 4 0 9000 9000 0xff 0xff
flash 33 6 64 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
An error occurred while uploading the sketch
this check.
avrdude done. Thank you.
