Issues with attiny 85 and 32 KHZ clock crystal
That is the maximum clock frequency for that part. Atmel sells two versions of the ATtiny85. A low voltage version with a maximum clock frequency of 10 MHz and a "normal" version with a maximum clock frequency of 20 MHz.
If you had looked at the datasheet snippet Tom Carpenter graciously posted in Reply #7 you would have seen that the Clock Frequency can vary from 0 MHz to 20 MHz.
