I spent 5 hours searching on stack overflow, reading through documentation, and asking people I know for help with this issue. Basically my code reads an input string, character by character, from a bluetooth serial device.
It appears to be equal when printed, although when compared using == or .equals it does not say they are equal. It doesn't say they are equal if I even convert them using .c_str and use strcmp == 0.
It turns out there is an invisible character at the end. I thought it might be a tab or new line initially, but it did not appear as anything when printed.
Anyways this is my code, and I just thought I would put it out there to help anyone with the same issue.
TLDR:
- compare string lengths, and be sure there are no extra characters that are invisible in the string
- you can remove the extra characters to fix this
Code:
#include "BluetoothSerial.h"
// Check if Bluetooth configs are enabled
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
// Bluetooth Serial object
BluetoothSerial SerialBT;
// GPIO where LED is connected to
const int ledPin = 2;
// Handle received and sent messages
String message = "";
char incomingChar;
// Timer: auxiliar variables
unsigned long previousMillis = 0; // Stores last time temperature was published
const long interval = 2000; // interval at which to publish sensor readings
pinMode(ledPin, OUTPUT);
// Bluetooth device name
SerialBT.begin("ESP32 with led hehe");
Serial.println("The device started, now you can pair it with bluetooth!");
// Send temperature readings
if (currentMillis - previousMillis >= interval){
SerialBT.println("Random number: " + String(random(100)));
// Read received messages (LED control command)
if (SerialBT.available()){
message = "";
char incomingChar = SerialBT.read();
while (incomingChar != '\n'){
message += String(incomingChar);
if (message.length()>1){//remove last invisible character
message = message.substring(0,message.length()-1);
//Serial.flush();
//Serial.write(incomingChar);
// Check received message and control output accordingly
if(!message.equals("")){
Serial.println("message:" + message + ".");
if (message.equalsIgnoreCase("on")){
Serial.println("ONNNNN");
digitalWrite(ledPin, HIGH);
//message = "";
else if (message.equalsIgnoreCase("off")){
Serial.println("OFFF");
digitalWrite(ledPin, LOW);
//message = "";
}else{
Serial.println("u typed something else");
message = "";
