// C++ code
int switchA = 6;
int Motor = 3;
int Potentiometer = 1;
Serial.begin(9600);// So I can use the serial monitor
//declaring the led outputs
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
pinMode(10, OUTPUT);
//declaring the fan motor output
pinMode(Motor, OUTPUT);
//the temp sensor input
pinMode(0, INPUT);
//Switch input pin
pinMode(switchA, INPUT);
//Potentiometer Input pin
pinMode(Potentiometer, INPUT);
Serial.print("voltage:");
Serial.print("\t");
Serial.println("deg C:");
Rankleds();//made a seperate function for the leds
Fanmotor();// This function is for the fan motor
void Rankleds()//Void for the leds
for(int ledpin=10; ledpin<=13; ledpin++)
/*Used a for loop to make things easier and shorter,
int ledpin=10 is initialisation
ledpin<=13 is conditiom
ledpin++ is increment
digitalWrite(ledpin, HIGH);//Turn Led ON
delay(750);// Wait 0.750 seconds
digitalWrite(ledpin, LOW);// Turn Led OFF
so a simple explanation: in this for loop,
it turns on the first led on pin 10 then waits 0.750 seconds
then turns it off then moves to the next led
which is on pin 11 and does the same thing until it finishes
at the led in pin 13, then goes in a loop
void Fanmotor()
float voltage, degreesC;
voltage = getVoltage();
degreesC = (voltage - 0.5)*100.0;
Serial.print(voltage);
Serial.print("\t");
Serial.println(degreesC);
if (digitalRead(switchA)==HIGH)
if(degreesC >= 22.0)
analogWrite(Motor, 255);
delay(20);
else if(degreesC < 22.0)
analogWrite(Motor, 0);
delay(20);
else if(digitalRead(switchA) == LOW){
int value = analogRead(Potentiometer);
float speed1 = (value/1024) * 255;
analogWrite(3, speed1);
Serial.println(digitalRead(switchA));
float getVoltage()
int reading = analogRead(0);
float voltage = reading * 5.0/1024.0;
return voltage;
