I'm running into some issues with the ethershield. I've got the program listed below as well as the circuit running. The included image is a seperate shield so imagine that in the stack of shields. This was fairly stable in my test environment running via USB. I've since moved it into a kegerator and it's running on a 7v switching wall-wort. It's incredibly unstable and usually locks up and can't be seen on the network. I've also noted that the board is quite warm while running off the 7v wall wort. Is this normal and do you have any ideas?
Thanks in advance!
/// This is a collection of code snippits found ///
/// from around the web as well as code written ///
/// by yours truly. This is a very rough ///
/// version 0.1 ///
/// Last compiled on Arduino version 17 ///
/// FLOW METER STUFF HERE
volatile int state = LOW;
float keg1_liter_count = 8; // This is used for counting liters drank, drunk, sipped, nursed, etc!
float keg2_liter_count = 0; // This is used for counting liters drank, drunk, sipped, nursed, etc!
int flow[] = {0, 0}; // This var is attached to the interupt and gets incremented on each flow count used for both kegs
float keg1_liters_full = 29; // this value will store the number of liters of a full keg (default as pony keg)
float keg2_liters_full = 29; // this value will store the number of liters of a full keg (default as pony keg)
/// END FLOW METER STUFF
#include <EEPROM.h>
/// TEMPERATURE CONFIG STUFF HERE
#include <OneWire.h>
OneWire therm1(8); // initiate OneWire on pin 8 (Thermometer 1)
OneWire therm2(9); // initiate OneWire on pin 9 (Thermometer 2)
byte present = 0, data[12], therm1_addr[8], therm2_addr[8];
int intPostDecimal, boolSign, intHexTempReading, intTempReadingBeforeSplit, preDecimal, i;
float fltPostDecimal, intHexTempReadingerature;
char sign[2] = "-"; // in the rare event we're dealing with negative numbers...if we are...OH NOES
float temp1 = 111.11; // this is the DSB18S20 attached to digital pin 8
float temp2 = 222.22; // this is the DSB18S20 attached to digital pin 9
//int insigtemp; // pretty sure this isn't used
int count; // This is used to determine which thermometer we're working on
/// END TEMPERATURE STUFF
/// ETHERSHIELD STUFF HERE
#include <Ethernet.h>
#include <String.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // Set the MAC address...more than 1 kegbot requires this to be diff on each
byte ip[] = { 192, 168, 1, 36 }; // IP address for the ethernet shield
Server server(80); // This is the port that we're serving up the webpages on
/// END EITHERSHIELD STUFF
// Flow Meter stuff
pinMode(5, OUTPUT); // no fucking clue what I was doing here
attachInterrupt(0, count_beer1, RISING); // setup the interrupt for keg1 digital pin 2
attachInterrupt(1, count_beer2, RISING); // setup the interrupt for keg2 digital pin 3
// END FLOW METER STUFF //
Ethernet.begin(mac, ip);
server.begin();
if (flow[0] > 2200) { // This is used for counting liters instead of pulses on keg1
keg1_liter_count += 1; // increment the liter count
flow[0] = flow[0] - 2200;
//EEPROM.write(10, keg1_liter_count); // Write it to eeprom in case we lose power
if (flow[1] > 2200) { // This is used for counting liters instead of pulses on keg2
keg2_liter_count += 1; // increment the liter count
flow[1] = flow[1] - 2200;
// EEPROM.write(20, keg2_liter_count); // Write it to eeprom in case we lose power
printTemperature();
// delay(5000);
Client client = server.available();
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if we've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so we can send a reply
if (c == '\n' && current_line_is_blank) {
client.println("Content-Type: text/html");
client.println();
if (c == '\n') {
// we're starting a new line
} else if (c != '\r') {
// we've gotten a character on the current line
current_line_is_blank = false;
if(boolSign) {
client.print(sign); // god I hope we never need this
client.print(temp1); // print value of temp sensor 1 (digitl pin 8)
client.print(","); // comma seperate the values for prettyness (think explode in php)
if(boolSign) {
client.print(temp2); // print value of temp sensor 2 (digitl pin 9)
// DONE PRINTING TEMPS ///
client.print(((keg1_liters_full - keg1_liter_count) / keg1_liters_full) * 100); // Print percent left in Keg 1
//client.println("Ounces left in Keg #2 -- ");
client.println(((keg2_liters_full - keg2_liter_count) / keg2_liters_full) * 100); // Print percent left in Keg 1
// give the web browser time to receive the data
delay(1);
count = 0;
client.stop();
/// Flow Meter Intterrupt stuff ///
void count_beer1() {
flow[0] += 1;
void count_beer2() {
flow[1] += 1;
/// BEGIN TEMPERATURE FUNCTIONS ///
int getTemperature(int low_Byte, int high_Byte) {
intHexTempReading = (high_Byte << 8) + low_Byte;
boolSign = intHexTempReading & 0x8000;
if(boolSign) {
intHexTempReading = (intHexTempReading ^ 0xffff) + 1;
intTempReadingBeforeSplit = 6.25 * intHexTempReading; // multiply by (100 * precision) = (100 * 0.0625) = 6.25 = 12-bit precision
preDecimal = intTempReadingBeforeSplit / 100;
intPostDecimal = intTempReadingBeforeSplit % 100;
fltPostDecimal = intPostDecimal;
if(intPostDecimal<10) {
intHexTempReadingerature = preDecimal+(fltPostDecimal/1000);
else {
intHexTempReadingerature = preDecimal+(fltPostDecimal/100);
if(boolSign) {
//Serial.print(sign);
//Serial.println(convert_c_to_f(intHexTempReadingerature));
if(count == 1) {
temp1 = convert_c_to_f(intHexTempReadingerature);
//Serial.println(temp1);
else if(count == 2) {
temp2 = convert_c_to_f(intHexTempReadingerature);
//Serial.println(temp2);
else {
//Serial.println("no data to print");
return 0;
float convert_c_to_f(int celsius) {
return((celsius*1.8)+32); // (Celsius * 9/5) + 32 = Fahrenheit
int printTemperature(void) {
if(!therm1.search(therm1_addr)) { // No more addresses
therm1.reset_search();
if(!therm2.search(therm2_addr)) { // No more addresses
therm2.reset_search();
if(OneWire::crc8(therm1_addr,7)!=therm1_addr[7]) { // Checksum invalid
//Serial.println("Thermometer #1 CRC checksum invalid");
if(OneWire::crc8(therm2_addr,7)!=therm2_addr[7]) { // Checksum invalid
//Serial.println("Thermometer #2 CRC checksum invalid");
therm1.reset();
therm1.select(therm1_addr);
therm1.write(0x44, 1); // start conversation w/ parasite power
therm2.reset();
therm2.select(therm2_addr);
therm2.write(0x44, 1); // start conversation w/ parasite power
present = therm1.reset();
therm1.write(0xBE); // read scratchpad
for(i=0;i<9;i++) { // need 9 bytes
data[i] = therm1.read();
//Serial.print("Thermometer #1: ");
count = 1;
getTemperature(data[0], data[1]);
// temp1 = getTemperature(data[0], data[1]);
present = therm2.reset();
therm2.write(0xBE); // read scratchpad
data[i] = therm2.read();
//Serial.print("Thermometer #2: ");
count = 2;
count = 0;
// temp2 = getTemperature(data[0], data[1]);
return 0;
/// END OF TEMPERATURE FUNCTIONS ///
