Hello,
I am working on a lighting project using an sharp IR proximity sensor and some LEDs. My goal is to use the proximity of a person to slowly fade a light on. Originally, I wanted to use the sensor to judge the brightness of the LEDs based off of proximity, but the sensor had too much feedback and the LED would flicker randomly. All I want now is for the LED to fade on slowly at a certain distance. Once the person walks out of that distance, the LED will fade out slowly.
I know this sounds like a simple motion sensor, but I want a nice gradual fade in both directions to help with my concept.
here is my code so far, I have eliminated my attempts to fade for they were probably ridiculous:
int SensorPin = A0; #define ledPin = 9;
// initialize the digital pins as an output.
int val = analogRead(SensorPin);
if (val >= 150)
{digitalWrite(9, HIGH); // Turns ON Relay on digital pin 4
delay(1000); // wait for a second
else if (val <= 170)
{digitalWrite(9, LOW); // Turns OFF Relay on digital pin 4
delay(1000); // wait for a second // wait for a second
Serial.print(val);
Serial.println(" ");}
So, wherever ledPin appears later in the code, = 9; will be substituted. Does that make sense?
if (val >= 150)
That does not look like fading an LED. It looks like code to turn a relay on. That comment is just plain stupid. It is NOT at all what the code is doing. Not the same pin. Not the same hardware connect to the pin.
That's a bit unfair Paul.
Unless you explain to someone how are they supposed to know that the silly C/C++ system requires an = when you do byte ledPin = 9; and requires you to omit the = (and the ;) when you do #define ledPin 9
Not really. A person might look at my comment and say "No, that doesn't make sense. Why would that happen?". Or, a person might look at that and say "Well, duh. That was stupid. I'll fix that right away!". I don't know how OP will react, so I offer a hint or clue.
When I get stuck, I don't want someone to write the code for me. I want a hint. If I'm really stuck, like 47 hints later and I still don't know what I'm doing wrong, then I want someone to write (some of) the code for me, I prefer to assume that most of the posters here are like me.
I appreciate the feedback.
I do apologize for the "// comments" in my code, for they were residual comments from an earlier code i wrote.
however, what i want is for the LED to fade on at a specific distance rather then it fade with actual proximity.
this would be like a modified "motion sensor" that has a slow fade on/off when the user get within X distance of it.
here is my revised code that I need to add fade feature:
It seems to be close, however I'm not getting the slow fade on and off...
I want the light to gradually (around 1.5 seconds) turn on/off once the proximity is reached.
I was thinking it could be a feature the actually maps out a few brightness values to ramp up the when it turns on and off.
This seems right to me, but it doesn't work:
int SensorPin = A0; #define ledPin 9;
so... experiment with the values that trigger the fades in the example below...
or are you trying to modify the fade if the person moves closer (fade up) or further (fade down) at any value along the sensor's range?
perhaps you should define exactly what you want your sensor/led to do, and then (we can help) program it.
int SensorPin = A0;
int ledPin = 9;
int oldVal;
pinMode(9, OUTPUT);
pinMode(SensorPin, INPUT);
if (val <= 150 && oldVal > 150)//<<<<<<<<<<<< HERE I wrote when the sensor returns less than 150... should you change that?
fadeUp();
else if (val >= 170 && oldVal < 170)//<<<<<<<<<<HERE I wrote when the sensor returns greater than 170... should you adjust that?
fadeDown();
oldVal = val;
void fadeUp()
for (int i = 0; i <= 255; i++)
analogWrite(ledPin, i);
delay(10);
void fadeDown()
analogWrite(ledPin, 255 - i);
delay(10);
Basically,
I want the sensor to turn ON and stay ON when someone is within a certain distance. When they walk away (outside of the distance) the LED will turn OFF and stay OFF. The fade is just a transitional effect into those states of ON and OFF.
I just don't want an abrupt switch between ON and OFF.
thanks again for your help BulldogLowell, we are getting closer.
