Hi all,
I am sending integer values from an Arduino Nano to another Arduino Nano to control a light-dimmer and a relais. When the light dimmer unit is connected, the sending does not work properly: There is just no value received or you need to wait ca. 1-3s until you can send another int value.
Code of the Master (simplified for demonstration)
#include <Wire.h>
int value = 0;
Wire.begin();
value = value + 20
byte buffer[2];
buffer[0] = value >> 8;
buffer[1] = value & 255;
Wire.beginTransmission(4);
Wire.write(buffer, 2);
Wire.endTransmission();
delay(500); //delay() only for demonstration
Code of the Slave (controlling the dimmer and relais)
#include <PushButton.h>
#include <Wire.h>
#include <TimerOne.h>
#include <Button.h>
#include <ButtonEventCallback.h>
#include <Bounce2.h>
int x = 0;
int RelaisDigitalPort = 12;
int RelaisState = LOW;
int volatile i = 0;
volatile boolean zero_cross = 0;
int AC_pin = 11;
int DimmLevelAry[] = //360 steps to adjust light intensity
{33, 47, 58, 67, 75, 82, 89, 95, 101, 106, 111, 116, 121, 126, 130, 135,
139, 143, 147, 151, 155, 159, 162, 166, 169, 173, 176, 179, 183, 186, 189,
192, 195, 198, 201, 204, 207, 210, 213, 216, 219, 221, 224, 227, 230, 232,
235, 237, 240, 243, 245, 248, 250, 253, 255, 258, 260, 262, 265, 267, 270,
272, 274, 277, 279, 281, 283, 286, 288, 290, 292, 295, 297, 299, 301, 303,
306, 308, 310, 312, 314, 316, 318, 320, 323, 325, 327, 329, 331, 333, 335,
337, 339, 341, 343, 345, 347, 349, 351, 353, 355, 357, 359, 361, 363, 365,
367, 369, 370, 372, 374, 376, 378, 380, 382, 384, 386, 388, 389, 391, 393,
395, 397, 399, 401, 403, 404, 406, 408, 410, 412, 414, 415, 417, 419, 421,
423, 425, 426, 428, 430, 432, 434, 435, 437, 439, 441, 443, 444, 446, 448,
450, 452, 453, 455, 457, 459, 460, 462, 464, 466, 468, 469, 471, 473, 475,
476, 478, 480, 482, 484, 485, 487, 489, 491, 492, 494, 496, 498, 499, 501,
503, 505, 507, 508, 510, 512, 514, 515, 517, 519, 521, 523, 524, 526, 528,
530, 531, 533, 535, 537, 539, 540, 542, 544, 546, 547, 549, 551, 553, 555,
556, 558, 560, 562, 564, 565, 567, 569, 571, 573, 574, 576, 578, 580, 582,
584, 585, 587, 589, 591, 593, 595, 596, 598, 600, 602, 604, 606, 608, 610,
611, 613, 615, 617, 619, 621, 623, 625, 627, 629, 630, 632, 634, 636, 638,
640, 642, 644, 646, 648, 650, 652, 654, 656, 658, 660, 662, 664, 666, 668,
670, 672, 674, 676, 679, 681, 683, 685, 687, 689, 691, 693, 696, 698, 700,
702, 704, 707, 709, 711, 713, 716, 718, 720, 722, 725, 727, 729, 732, 734,
737, 739, 741, 744, 746, 749, 751, 754, 756, 759, 762, 764, 767, 769, 772,
775, 778, 780, 783, 786, 789, 792, 795, 798, 801, 804, 807, 810, 813, 816,
820, 823, 826, 830, 833, 837, 840, 844, 848, 852, 856, 860, 864, 869, 873,
878, 883, 888, 893, 898, 904, 910, 917, 924, 932, 941, 952, 966, 999, 1000};
int DimmLevel = 0;
int inc = 1;
int freqStep = 10;
Serial.setTimeout(50);
Wire.begin(4);
Wire.onReceive(receiveEvent);
pinMode(RelaisDigitalPort, OUTPUT);
pinMode(AC_pin, OUTPUT);
attachInterrupt(1, zero_cross_detect, RISING);
Timer1.initialize(freqStep);
Timer1.attachInterrupt(DimmLevel_check, freqStep);
void zero_cross_detect() {
zero_cross = true;
i = 0;
digitalWrite(AC_pin, LOW);
void DimmLevel_check() {
if (zero_cross == true) {
if (i >= DimmLevel) {
digitalWrite(AC_pin, HIGH);
i = 0;
zero_cross = false;
else {
i++;
void receiveEvent()
while(Wire.available())
x = 0;
x = Wire.read() << 8 | Wire.read();
if (x == 10000) {
LichtSwitch();
else if (x > 33 && x < 1001) {
DimmLevel = DimmLevelAry[x];
void LichtSwitch(){
if (RelaisState == 0) {
digitalWrite(RelaisDigitalPort, HIGH);
RelaisState = 1;
else {
digitalWrite(RelaisDigitalPort, LOW);
RelaisState = 0;
What I tried:
- Disconnect the dimmer module: Everything works perfectly, but of couse I would like to use it with the dimmer module!
- Use serial communication instead if I2C: Basically the same problem
- **Change baudrate:**No improvement
I checked the forum for comparable issues, but I cannot e.g. detach the interrupt as the light needs to stay on all the time obviously :).
I would appreciate your help!
