issues with implementing CRC8 on arduino serial
im trying implementing crc8 on serial communication arduino,but i having trouble on receiver side, it doesnt giving a zero remainder, is anything wrong with my code or i didnt get how the crc works, but i am already searching and this is what i got pls help .
Transmitter side:
value=220;
LFSRBuffer=crcNaive(value);
result = (value<<5)|LFSRBuffer;
mySerial.write(highByte(result));
mySerial.write(lowByte(result));
delay(3000);
uint16_t crcNaive(byte const message)
    uint8_t  remainder = message;
    for (int bit = 0; bit < 8; bit++)
        if ((remainder & 0x80) != 0)
            remainder = (byte)((remainder<<1) ^ POLYNOMIAL);
    else{
        remainder <<=1;
    return remainder;
Receiver side:
  if (mySerial.available() > 0) {
    hi = mySerial.read();
    lo = mySerial.read();
    result = word(hi,lo);
uint16_t resultx = crcNaive(result);
Serial.println(resultx,BIN);
delay(3000);
uint16_t crcNaive(uint16_t const message)
    uint16_t  remainder = message;
    else{
        remainder <<=1;
    return remainder;
Transmitter:
5? How many bits in a byte?
Receiver:
This will only guarantee you that the Arduino has read at least one byte. Your code assumes that it can read two bytes.
Change it to > 1
Next time, post all of the code in each sketch - but thanks for the code tags.
Pete
And the CRC check in the receiver only uses the low order 8 bits of the uint16_t. It should be checking all 16 bits. Then it should give you zero for the remainder.
Pete
