Hi everyone, I’m experiencing an issue using interrupts on pin 2 of an Arduino Nano 33 IoT. The button connected to pin 2 (configured as INPUT_PULLUP) is supposed to trigger an interrupt set on RISING. However, with the code provided below, the interrupt never triggers.
Important detail:
If I use a simpler test code that only checks the interrupt functionality without including additional libraries or features, and i uploud it by IDE the button works perfectly. It seems the problem is related to the complexity of the project.
The project includes:
- An LED matrix (WS2812B) controlled using the FastLED library.
- Synchronization with Arduino IoT Cloud to change visual effects.
Here’s the full code. Note that the project has additional pages containing only the function definitions.
#include <FastLED.h>
#include "thingProperties.h"
#define DATA_PIN 5
#define NUM_LEDS 152
CRGB leds[NUM_LEDS];
int Lum = 65;
int speed = 400;
int color = 0;
int color2 = 0;
int purple = 230;
volatile unsigned long lastDebounceTime = 0; // Last button state change time
const unsigned long debounceDelay = 400; // Debounce time
volatile bool aggiornareEffetto = false; // Variable to signal button state change
volatile int statopulsante = 0; // Must be volatile as it's used in the interrupt
const int pulsante = 2;
const int heartShape[NUM_LEDS][2] = {
{2,0}, {3,0}, {4,0}, {5,0}, {11,0}, {12,0}, {13,0}, {14,0},
/* Other elements defined here */
{8,13},
FastLED.setDither(BINARY_DITHER);
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
attachInterrupt(digitalPinToInterrupt(2), Pulsante, RISING); // Configure interrupt on pin 2
pinMode(pulsante, INPUT_PULLUP); // Set button pin as INPUT_PULLUP
initProperties(); // Defined in thingProperties.h
ArduinoCloud.begin(ArduinoIoTPreferredConnection); // Connect to Arduino IoT Cloud
void Pulsante() {
unsigned long currentTime = millis();
if ((currentTime - lastDebounceTime) > debounceDelay) {
aggiornareEffetto = true;
lastDebounceTime = currentTime;
void onEffettiChange() {
Serial.println("Effect changed!");
switch (effetti) {
case 0: pulseHeart(); break;
case 1: expandAndContractHeart(); break;
case 2: heartLayersEffect(); break;
case 3: rainbowHeart(); break;
case 4: sparkleHeart(); break;
default: break;
ArduinoCloud.update();
if (aggiornareEffetto) {
statopulsante = (statopulsante + 1) % 4;
Serial.println("Button state updated: " + String(statopulsante));
executeCorrespondingFunction();
void executeCorrespondingFunction() {
updatetrim();
switch (statopulsante) {
case 0: break;
case 1: break;
case 2: break;
case 3: break;
default: break;
Has anyone encountered similar issues with Arduino Nano 33 IoT? Could there be hardware limitations or library conflicts causing this? Thanks a lot for your help!
