////////////////////////////EC Sensor Library////////////////////////////////////////
#include "DFRobot_EC.h"
#include <EEPROM.h>
#define EC_PIN A1
float voltage,ecValue,temperature = 25;
DFRobot_EC ec;
///////////////////////////////LCD Library///////////////////////////////////////////
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
#include "Arduino.h"
const byte switchState = 0;
const int pump1 = 2; //for PH down
const int pump2 = 3; //for nutrients (EC / PPM)
const int pump3 = 4; //for PH up
const int pump4 = 5; //for nutrients circulation
const int pump5 = 6; //Seedling circulation pump
//const int pump6 = 7; //Seedling circulation pump
//const int lamps = 7; //Lamps
//const int fans = 8; //cooling fan (5v)
/////////////////////PH Sensor Values and Set-up/////////////////////////////////////
float calibration_value = 21.34-.18; // .68 Here we attend the calibration adding or deducting values
int phval = 0;
unsigned long int avgval;
int buffer_arr[10], temp;
int ph_Read = A7;
////////////////////////////////PUMPS Values//////////////////////////////////////
unsigned long prev_Time_1 = 0;
unsigned long prev_Time_2 = 0;
unsigned long prev_Time_3 = 0;
unsigned long prev_Time_4 = 0; //Circulation each dosing
unsigned long prev_Time_5 = 0;
//unsigned long prev_Time_6 = 0; //Circulation each 60 min
const unsigned long inter_on = 8000;
const unsigned long inter_off = 32000;
const unsigned long inter_circulation_on = 60000;
const unsigned long inter_circulation_off = (60000*10);
const unsigned long inter_seedling_on = 60000;
const unsigned long inter_seedling_off = (60000*10);
byte pump1_state = HIGH;
byte pump2_state = HIGH;
byte pump3_state = HIGH;
byte pump4_state = HIGH;
byte pump5_state = HIGH;
//byte pump6_state = HIGH;
byte customChar0[8] = { //Circulation//
0b01110,
0b10001,
0b10001,
0b10000,
0b10000,
0b10001,
0b10001,
0b01110
byte customChar1[8] = { //Seedling//
0b01110,
0b10001,
0b01001,
0b00100,
0b00010,
0b10001,
0b10001,
0b01110
byte customChar2[8] = { //Arrow Down//
0b00100,
0b00100,
0b00100,
0b00100,
0b00100,
0b11111,
0b01110,
0b00100
byte customChar3[8] = { //Arrow UP//
0b00100,
0b01110,
0b11111,
0b00100,
0b00100,
0b00100,
0b00100,
0b00100
ec.begin();
while(!Serial);
lcd.begin();
lcd.createChar(0, customChar0); //Arrow UP//
lcd.createChar(1, customChar1); //Arrow Down//
lcd.createChar(2, customChar2); //Circulation//
lcd.createChar(3, customChar3); //Seedling//
lcd.backlight();
lcd.setCursor(2, 1);
lcd.print("/./.ROOMMATE././");
lcd.setCursor(2, 2);
lcd.print("/////DOSING/////");
delay(2000);
lcd.clear();
//pinMode(switchPHDWN,INPUT);
digitalWrite(pump1,HIGH);
pinMode(pump1,OUTPUT);
digitalWrite(pump2,HIGH);
pinMode(pump2,OUTPUT);
digitalWrite(pump3,HIGH);
pinMode(pump3,OUTPUT);
digitalWrite(pump4,HIGH);
pinMode(pump4,OUTPUT);
digitalWrite(pump5,HIGH);
pinMode(pump5,OUTPUT);
//digitalWrite(pump6,HIGH);
//pinMode(pump6,OUTPUT);
unsigned long current_Time = millis();
////////EC Sensor Lecture///////////
static unsigned long timepoint = millis();
if(millis()-timepoint>1000U) //time interval: 1s
voltage = analogRead(EC_PIN)/1024.0*5000; // read the voltage
Serial.print("voltage:");
Serial.print(voltage);
//temperature = readTemperature(); // read your temperature sensor to execute temperature compensation
ecValue = ec.readEC(voltage,temperature); // convert voltage to EC with temperature compensation
Serial.print(" temperature:");
Serial.print(temperature,1);
Serial.print("^C EC:");
Serial.print(ecValue,2);
Serial.println("ms/cm");
ec.calibration(voltage,temperature);
////////////PH Sensor Lecture////////////////
for (int i = 0; i < 10; i++)
buffer_arr[i] = analogRead(A7);
delay(100);
for (int i = 0; i < 9; i++)
for (int j = i + 1; j < 10; j++)
if (buffer_arr[i] > buffer_arr[j])
temp = buffer_arr[i];
buffer_arr[i] = buffer_arr[j];
buffer_arr[j] = temp;
avgval = 0;
for (int i = 2; i < 8; i++)
avgval += buffer_arr[i];
float volt = (float)avgval * 6.00 / 1024 / 9; //5.0 volts
float ph_act = -5.70 * volt + calibration_value;
Serial.print(" PH= ");
Serial.print(ph_act);
Serial.print(" ");
Serial.println(millis());
///////////////////////////CALIBRATION//////////////////////////////////////
float Set_PH = 7.0;
float Dose_PHAdj =.30;
float Set_EC = 1.5;
float Dose_ECAdj =.20;
/////////////////////////LCD DISPLAY INFORMATION////////////////////////////
lcd.setCursor(0,0);
lcd.print("PH Level=");
lcd.setCursor(10,0);
lcd.print(ph_act);
lcd.setCursor(0,1);
lcd.print("EC Level=");
lcd.setCursor(10,1);
lcd.print(ecValue);
lcd.setCursor(0,2);
lcd.print("PH Volt=");
lcd.setCursor(9,2);
if((pump5_state == HIGH) &&
(current_Time - prev_Time_5 >= inter_seedling_off))
pump5_state = LOW;
prev_Time_5 = current_Time;
digitalWrite(pump5,pump5_state);
Serial.print("PUMP5_ON!!Seedling");
Serial.print("-");
lcd.setCursor(19,0);
lcd.write((byte)1);
else if
((pump5_state == LOW) &&
(current_Time - prev_Time_5 >= inter_seedling_on))
pump5_state = HIGH;
Serial.print("PUMP5_OFF!!");
Serial.print("-");
lcd.print(" ");
////////////////////////////////Circulation/////////////////////////////////
if((pump4_state == HIGH) &&
(current_Time - prev_Time_4 >= inter_circulation_off))
pump4_state = LOW;
prev_Time_4 = current_Time;
digitalWrite(pump4,pump4_state);
Serial.print("PUMP4_ON!!Seedling");
Serial.print("-");
lcd.setCursor(19,1);
lcd.write((byte)0);
else if
((pump4_state == LOW) &&
(current_Time - prev_Time_4 >= inter_circulation_on))
pump4_state = HIGH;
Serial.print("PUMP4_OFF!!");
Serial.print("-");
lcd.print(" ");
////////////////////////////Pump1_PH DOWN////////////////////////////////////
if((ph_act >= (Set_PH+Dose_PHAdj)) &&
(pump1_state == HIGH) &&
(current_Time - prev_Time_1 >= (inter_off)))
pump1_state = LOW;
prev_Time_1 = current_Time;
digitalWrite(pump1,pump1_state);
Serial.print("PUMP1_ON!!PH DOWN");
Serial.print("-");
lcd.setCursor(18,0);
lcd.write((byte)2);
else if
((pump1_state == LOW) &&
(current_Time - prev_Time_1 >= inter_on))
pump1_state = HIGH;
Serial.print("PUMP1_OFF");
lcd.print(" ");
////////////////////////////Pump3_PH UP////////////////////////////////////
if((ph_act <= (Set_PH-Dose_PHAdj)) &&
(pump3_state == HIGH) &&
(current_Time - prev_Time_3 >= (inter_off)))
pump3_state = LOW;
prev_Time_3 = current_Time;
digitalWrite(pump3,pump3_state);
Serial.print("-");
lcd.setCursor(17,0);
lcd.write((byte)3);
else if
((pump3_state == LOW) &&
(current_Time - prev_Time_3 >= inter_on))
pump3_state = HIGH;
/////////////////////////////Pump2_EC UP////////////////////////////////////
if((ecValue <= (Set_EC-Dose_ECAdj))&&
(pump2_state == HIGH) &&
(current_Time - prev_Time_2 >= inter_off))
pump2_state = LOW;
prev_Time_2 = current_Time;
digitalWrite(pump2,pump2_state);
Serial.print("PUMP2_ON!!EC UP");
Serial.print("-");
lcd.setCursor(18,1);
lcd.write((byte)3);
else if
((pump2_state == LOW) &&
(current_Time - prev_Time_2 >= inter_on))
pump2_state = HIGH;
lcd.print(" ");
