Issues with output from map() function
Hi all,
I am trying to map out the analog input read from a 20k potetiometer in order to drive a servo using a UNO board. I am getting the correct readings on my analogRead but the map function does not seem to actually map out the values. Please find below a copy of the commented code and some it's output on the serial monitor.
Code:
#include <Servo.h>
Servo Servo1;
int const PotentiometerPin = A0; //Assign "Potentiometer" to A0 Analog Input
int PVoltage; //Variable for Potentiometer Voltage after ADC (0,1023)
int PAngle; //Variable for Potentiometer Turn Angle (0,179)
Servo1.attach(3); //Assign to PWM 3
PVoltage = analogRead(PotentiometerPin);//Read potentiometer value
Serial.print("Potentiometer Value:");//Print message
Serial.print(PVoltage); //Print value
PAngle = map(PotentiometerPin, 0, 1023, 0, 179);//Maps Potentiometer Angle to motor angle
Serial.print(" Angle Value:"); //Print message
Serial.println(PAngle); //Print value and jump to next line
Servo1.write(PAngle); //Rotate servo to position between 0 and 179
delay(15); //Delay
Serial Monitor:
Potentiometer Value:73 Angle Value:2
Potentiometer Value:165 Angle Value:2
Potentiometer Value:274 Angle Value:2
Potentiometer Value:536 Angle Value:2
Potentiometer Value:662 Angle Value:2
My impression is that the reading at "A0" is correct; however, why does my output for PAngle variable always stay at 2?
Thanks in advance!
If you look at your sketch more closely you will see that you are reading the value into "PVoltage" but mapping "PotentiometerPin" which is a small constant (14 on the UNO).
That felt silly, how could I not see it :o ...
Thank you so much johnwasser!
