If you plan to put them in parallel, then you must measure DC polarity of the disks.
Put a single piezo disk on something that supports the edge, like a 1" rubber O-ring.
Hold the black lead of a DMM (set to 2volt DC) on the brass edge, and press the red lead gently in the middle of the white piezo part. You will see the voltage go positive or negative when pressed.
If you have trouble seeing it, then add a 100n cap across the DMM leads.
Select the disks for positive or negative going voltage when pressed.
Still don't see how you are going to charge a battery with that.
When posting links, remove the question mark and everything behind it before posting.
The question mark and everything hta follows is you personal browsing habit.
Leo..
