Issues with RGB LED behaviour
Hello to all,
I am currently working on a project for my CNC machine.
I am building a "keyboard" which will be used as an interface for sending shortcuts and macros on my PC G-code sender. My keyboard is controlled by Arduino ProMicro.
The function for buttons is tested and is working. Also, the LEDs are working, but the issue is when I want to be a little bit more "hipster".
I want that when press a certain button, the color is changed and blinks. I get it for the first one when the LEDs blink ORANGE. In my code is void test(). But when I add a second one void test2(), everything is messed up.
To explain a little bit of bacground.
When you press button C_Hold, i want that LED from 0-19 are blkinking ORANGE until you pres same button again.
When you press button C_Stop, I want that LEDs from 0-19 are blinking red, but only n cycles and then colors are return to IDLE setting
Orange function does not work anymore and red is not limited.
// Library adding
#include <Keypad.h>
#include <Keyboard.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#include <Encoder.h>
//Matrix rows and columns
const byte numRows = 5; //No. of rows
const byte numCols = 5; //No. of columns
// Arduino Pins definition
//Keyboard pins
byte rowPins[numRows] = {21, 20, 19, 18, 15}; //vrstice
byte colPins[numCols] = {6, 7, 8, 9, 10}; //stolpci
//LEDs pin and No. Definition
#define LED_PIN 14
#define NUM_LEDS 24
//Encoder pins definition
Encoder encoder2(3, 2);//Enkoder 1 - Jog enkoder
Encoder encoder1(5, 4);//Enkoder 2 - Feed enkoder
// Keyboard Matrix
//Keyboard matrix
char keyMap[numRows][numCols] = {
  {'1', '2', '3', '4', '5'},
  {'6', '7', '8', '9', '0'},
  {'A', 'B', 'C', 'D', 'E'},
  {'F', 'G', 'H', 'I', 'J'},
  {'K', 'L', 'M', 'N', 'O'}
//Keyboard initialization
Keypad keypad = Keypad(makeKeymap(keyMap), rowPins, colPins, numRows, numCols);
//Color definition
//								  Red,    Grn,    Blu
#define	BLACK			    0,      0,      0
#define	CHARCOAL		 50,     50,     50
#define	DARK_GREY	  140,    140,    140
#define	GREY			  185,    185,    185
#define	LIGHT_GREY	250,    250,    250
#define	WHITE   		255,    255,    255
#define	RED     		255,      0,      0
#define	PINK   		  255,    130,    208
#define	GREEN   		  0,    255,      0
#define	DARK_GREEN    0,     30,      0
#define	OLIVE   		 30,     30,      1
#define	BLUE    		  0,      0,    255
#define	LIGHT_BLUE	 55,     68,     85
#define	NAVY   		    0,      0,     30
#define	PURPLE   	  140,      0,    255
#define	LAVENDER    218,    151,    255
#define	ORANGE   	  255,     80,      0
#define	CYAN    		  0,    255,    255
#define	MAGENTA 		255,      0,    255
#define	YELLOW  		255,    255,      0
// Definition of buttons "shortcut/macro"
char C_Start[]      = { KEY_LEFT_CTRL, 'i',               '\0'};
char C_Hold[]       = { KEY_LEFT_CTRL, KEY_TAB,           '\0'};
char C_Stop[]       = { KEY_LEFT_CTRL, KEY_ESC,           '\0'};
char S_Start[]      = { KEY_LEFT_CTRL, 'u',               '\0'};
char Ref_Home[]     = { KEY_LEFT_CTRL, KEY_HOME,          '\0'};
char Go_To_Zero[]   = { KEY_LEFT_CTRL, KEY_DELETE,        '\0'};
char Zero_X[]       = { KEY_LEFT_CTRL, 'x',               '\0'};
char Zero_Y[]       = { KEY_LEFT_CTRL, 'y',               '\0'};
char Zero_Z[]       = { KEY_LEFT_CTRL, 'z',               '\0'};
char Cnc_Res[]      = { KEY_LEFT_CTRL, KEY_END,           '\0'};
char Probe_Start[]  = { KEY_LEFT_CTRL, 'p',               '\0'};
char Step_Chose[]   = { KEY_LEFT_CTRL, 'c',               '\0'};
char X_Plus[]       = { KEY_LEFT_CTRL, KEY_RIGHT_ARROW,   '\0'};
char X_Minus[]      = { KEY_LEFT_CTRL, KEY_LEFT_ARROW,    '\0'};
char Y_Plus[]       = { KEY_LEFT_CTRL, KEY_UP_ARROW,      '\0'};
char Y_Minus[]      = { KEY_LEFT_CTRL, KEY_DOWN_ARROW,    '\0'};
char Z_Plus[]       = { KEY_LEFT_CTRL, KEY_PAGE_UP,       '\0'};
char Z_Minus[]      = { KEY_LEFT_CTRL, KEY_PAGE_DOWN,     '\0'};
char Free1[]        = { KEY_LEFT_CTRL, 'a',               '\0'};
char Free2[]        = { KEY_LEFT_CTRL, 'j',               '\0'};
char Jog_Reset[]    = { KEY_LEFT_CTRL, 't',               '\0'};
char Feed_Reset[]   = { KEY_LEFT_CTRL, 'r',               '\0'};
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUM_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
int colorUpdate = 0;
//Variables
int stepCount =1;               // Counter for jog feed distance (0.1mm, 1mm, 10mm, 100mm)
int buttonState = 0;            // Initial Button state
int lastButtonState = 0;        // Previous Button state
int ledBrightnes=150;           //LED Brightness setup
int colorModeSet=0;             // Color mode
long positionEncoder1  = -999; //encoderA LEFT position variable
long positionEncoder2  = -999; //encoderB RIGHT position variable
//LED blinking setup
const long periodsH[] = {100, 300, 100, 300, 100, 300, 1000, 0};
const long periodsS[] = {100, 500, 100, 500, 100, 500, 1000, 0};
byte index;
unsigned long startTime;
unsigned long currentTime;
bool ledState;
byte indexS;
unsigned long startTimeS;
unsigned long currentTimeS;
bool ledStateS;
int cycleCounter = 0;
  Keyboard.begin();     //Keyboard Initialisation
  Serial.begin(9600);   //Serial monitor - optional
  pixels.begin();       // This initializes the NeoPixel library.
  StepChooseInitial();  // Calibration of keybard and g-code sender
  mainKeyFunction();
  setColorsMode0();
  encoder1_Jog();
  encoder2_Feed();
  pixels.setBrightness(ledBrightnes);
// Button function - Main function
void mainKeyFunction(){
  char key = keypad.getKey(); //Pressed button check
  if (key != NO_KEY) { //Check if buton is pressed
  switch(key) {
      case '1': Keyboard.press(C_Start);
                Keyboard.releaseAll();
                delay(50);
      case '2': Keyboard.press(C_Hold);
                delay(50);
      case '3': Keyboard.press(C_Stop);
                delay(50);
      case '4': Keyboard.press(S_Start);
                delay(50);
      case '5': Keyboard.press(Ref_Home);
                delay(50);
      case '6': Keyboard.press(Go_To_Zero);
                delay(50);
      case '7': Keyboard.press(Zero_X);
                delay(50);
      case '8': Keyboard.press(Zero_Y);
                delay(50);
      case '9': Keyboard.press(Zero_Z);
                delay(50);
      case '0': Keyboard.press(Cnc_Res);
                delay(50);
      case 'A': Keyboard.press(Probe_Start);
                delay(50);
      case 'B': Keyboard.press(Step_Chose);
                delay(50);
      case 'C': Keyboard.press(X_Plus);
                delay(50);
      case 'D': Keyboard.press(X_Minus);
                delay(50);
      case 'E': Keyboard.press(Y_Plus);
                delay(50);
      case 'F': Keyboard.press(Y_Minus);
                delay(50);
      case 'G': Keyboard.press(Z_Plus);
                delay(50);
      case 'H': Keyboard.press(Z_Minus);
                delay(50);
      case 'I': Keyboard.press(Free1);
                delay(50);
      case 'J': Keyboard.press(Free2);
                delay(50);
      case 'K': Keyboard.press('L'); // Feed reset
                stepCount++;
                if (colorModeSet==0 || colorModeSet==1){
                  colorModeSet=2;
                delay(50);
      case 'L': Keyboard.press('R'); // Jog reset
                stepCount--;
                if( colorModeSet==0){
                  colorModeSet=1;
                }else {
                  colorModeSet=0;
                delay(50);
    Serial.println(key); //Izpišemo vrednost tipke v serijski monitor
// Color setup function
//Loop for addressing colors on LED - IDLE
void setColorsMode0(){
  switch(colorModeSet){
    case 0: if (colorUpdate == 0){                                    // have the neopixels been updated?
        pixels.setPixelColor(0,  pixels.Color( GREEN ));
        pixels.setPixelColor(1,  pixels.Color( ORANGE ));
        pixels.setPixelColor(2,  pixels.Color( RED ));
        pixels.setPixelColor(3,  pixels.Color( GREEN ));
        pixels.setPixelColor(4,  pixels.Color( ORANGE ));
        pixels.setPixelColor(5,  pixels.Color( GREEN ));
        pixels.setPixelColor(6,  pixels.Color( BLUE ));
        pixels.setPixelColor(7,  pixels.Color( BLUE ));
        pixels.setPixelColor(8,  pixels.Color( BLUE ));
        pixels.setPixelColor(9,  pixels.Color( WHITE ));
        pixels.setPixelColor(10, pixels.Color( BLUE ));
        pixels.setPixelColor(11, pixels.Color( YELLOW ));
        pixels.setPixelColor(12, pixels.Color( BLUE ));
        pixels.setPixelColor(13, pixels.Color( BLUE ));
        pixels.setPixelColor(14, pixels.Color( WHITE ));
        pixels.setPixelColor(15, pixels.Color( WHITE ));
        pixels.setPixelColor(16, pixels.Color( BLUE ));
        pixels.setPixelColor(17, pixels.Color( BLUE ));
        pixels.setPixelColor(18, pixels.Color( BLUE ));
        pixels.setPixelColor(19, pixels.Color( WHITE ));
        //Function for jog feed resolution step choose
        char stepLit=stepCount;
        switch(stepLit){
          case 0: pixels.setPixelColor(20, pixels.Color( GREEN ));
                  pixels.setPixelColor(21, pixels.Color( LIGHT_BLUE ));
                  pixels.setPixelColor(22, pixels.Color( LIGHT_BLUE ));
                  pixels.setPixelColor(23, pixels.Color( LIGHT_BLUE ));
          case 1: pixels.setPixelColor(20, pixels.Color( LIGHT_BLUE ));
                  pixels.setPixelColor(21, pixels.Color( GREEN ));
          case 2: pixels.setPixelColor(20, pixels.Color( LIGHT_BLUE ));
                  pixels.setPixelColor(22, pixels.Color( GREEN ));
          case 3: pixels.setPixelColor(20, pixels.Color( LIGHT_BLUE ));
                  pixels.setPixelColor(23, pixels.Color( GREEN ));
      pixels.show();
      colorUpdate=0;
    case 1: if (colorUpdate == 0){
        test();
        colorUpdate=0;
    case 2: if (colorUpdate==0){
        test2();
        colorUpdate=0;
// Encoders Functions
//Loop for reading Encoder1
void encoder1_Jog(){
  long newPos = encoder1.read()/4; //When the encoder lands on a valley, this is an increment of 4.
                                          // your encoder might be different (divide by 2) i dunno.
  if (newPos != positionEncoder1 && newPos > positionEncoder1) {
    positionEncoder1 = newPos;//CCW - minus JOG
    Keyboard.releaseAll();                    }
  if (newPos != positionEncoder1 && newPos < positionEncoder1) {
    positionEncoder1 = newPos;//CW - plus JOG
    Keyboard.press('b');
//Loop for reading Encoder2
void encoder2_Feed(){
  long newPos = encoder2.read()/4; //When the encoder lands on a valley, this is an increment of 4.
  if (newPos != positionEncoder2 && newPos > positionEncoder2) {
    positionEncoder2 = newPos;//CCW - minus FEED
    Keyboard.press('M');
  if (newPos != positionEncoder2 && newPos < positionEncoder2) {
    positionEncoder2 = newPos;//CW - plus FEED
    Keyboard.press('P');
// Jog and Feed resolution step function
//Loop for initial calibration
void StepChooseInitial(){
    if (stepCount !=0){
      for (int i = 0; i < 3; i++) {
        Keyboard.press('2');
  stepCount=0;
//Loop for
void Step_Choose(){
    if (stepCount<4){
    Keyboard.press('1');
    stepCount++;
    if (stepCount==4){
    stepCount=0;
void test(){
  currentTime = millis();
  if (currentTime - startTime >= periodsH[index]) {
    if (ledState == false) {
      for (int i = 0; i < 20; i++) {
        pixels.setPixelColor(i,  pixels.Color( BLACK ));
      ledState = true;
        pixels.setPixelColor(i,  pixels.Color( ORANGE ));
      ledState = false;
    index = ++index % 8;
    startTime = currentTime;
      switch(stepLit){
pixels.show();
void test2(){
  currentTimeS = millis();
    if (currentTimeS - startTimeS >= periodsS[indexS]) {
    if (ledStateS == false) {
      ledStateS = true;
        pixels.setPixelColor(i,  pixels.Color( RED ));
      ledStateS = false;
    indexS = ++indexS % 8;
    startTimeS = currentTimeS;
    pixels.show();
      if (++cycleCounter == 2) { // Preverjanje števca ciklov
      colorModeSet=0;
      setColorsMode0();
  pixels.show();
And my second question, how can I intergrate function that is checking if for exyample Free1 button is pressed + another one, that you change function of a button?
example: If you press and Hold Free1 button, and rotationg Encoder1 you have brightness change.
I have also ideas to add other functions to keyboard but I need to do this first.
// Library adding
#include <Keypad.h>
#ifdef __AVR__
#endif
//Keyboard pins
#define LED_PIN 14
#define NUM_LEDS 24
// Keyboard Matrix
//Keyboard matrix
//Color definition
//                  Red,    Grn,    Blu
//Variables
int stepCount = 1;              // Counter for jog feed distance (0.1mm, 1mm, 10mm, 100mm)
int ledBrightnes = 150;         //LED Brightness setup
int colorModeSet = 0;           // Color mode
byte index;
bool ledState;
byte indexS;
bool ledStateS;
  mainKeyFunction();
  setColorsMode0();
  encoder1_Jog();
  encoder2_Feed();
void Key2LED(byte mode) {
  switch (mode) {
    case 2:
      for (int i = 0; i < 20; i++)pixels.setPixelColor(i,  pixels.Color( ORANGE ));
    case 1:
      for (int i = 0; i < 20; i++)pixels.setPixelColor(i,  pixels.Color( RED ));
  pixels.show();
  delay(50);
void mainKeyFunction() {
    switch (key) {
        delay(50);
        Key2LED(2);
        delay(50);
        Key2LED(1);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        delay(50);
        stepCount++;
        if (colorModeSet == 0 || colorModeSet == 1) {
          colorModeSet = 2;
        delay(50);
        stepCount--;
        if ( colorModeSet == 0) {
          colorModeSet = 1;
          colorModeSet = 0;
        delay(50);
void setColorsMode0() {
  switch (colorModeSet) {
    case 0: if (colorUpdate == 0) {                                   // have the neopixels been updated?
        char stepLit = stepCount;
        switch (stepLit) {
        pixels.show();
        colorUpdate = 0;
    case 1: if (colorUpdate == 0) {
        test();
        colorUpdate = 0;
    case 2: if (colorUpdate == 0) {
        test2();
        colorUpdate = 0;
void encoder1_Jog() {
  long newPos = encoder1.read() / 4; //When the encoder lands on a valley, this is an increment of 4.
void encoder2_Feed() {
  long newPos = encoder2.read() / 4; //When the encoder lands on a valley, this is an increment of 4.
void StepChooseInitial() {
  if (stepCount != 0) {
  stepCount = 0;
void Step_Choose() {
  if (stepCount < 4) {
    stepCount++;
  if (stepCount == 4) {
    stepCount = 0;
void test() {
      ledState = true;
      ledState = false;
  switch (stepLit) {
  pixels.show();
void test2() {
      ledStateS = true;
      ledStateS = false;
    pixels.show();
    colorModeSet = 0;
    setColorsMode0();
  pixels.show();
@kolaha all your edits, various spaces, ..., to the code made it very difficult to see that you added the KEY2LED() to presumably correct the problem.
your edits create many deltas that a diff recognized.
if you're just going to post code without explanation, it makes sense to only make the necessary changes so that a diff can expose your changes
Maybe @kolaha just wanted @GasperStef to consider some code.
a7
