Hello!
I recently purchased an ESP8266, and decided to try to connect it to my Arduino and begin working with it.
I was following this tutorial:
http://www.teomaragakis.com/hardware/electronics/how-to-connect-an-esp8266-to-an-arduino-uno/comment-page-1/#comments
I did the wiring, everything seemed fine however, when I would type in the "AT" command, ESP8266 would not respond at all. I tried using different Baud Rates, and switched to the "Both NL and CR" option. But no luck whatsoever.
Also, I noticed a strange thing, whenever I would send in a command from the Serial Monitor, the "RX" LED would light up on my Arduino for a split second. Shouldn't the "TX" LED be lighting up?
I am very new to programming as well as to the Arduino.
What could be I possibly be doing wrong?
Is my ESP8266 dead?
Thanks a ton!
read Arduino to ESP8266 By Serial Communication | Martyn Currey
A ESP module needs a 3.3V power supply. The one from the Arduino is generally insufficient.
I just realizes there are LEDs on the ESP8266, and none of them were glowing.
Well looks we have a power problem here!
(And I was wondering, what a stupid module it is, no LED's whatsoever lol)
Two possibilities here:
- Arduino fails to provide enough current and/or voltage
- Faulty ESP8266
I will post update soon.
McSuperbX1:
2) Faulty ESP8266
I have 7 of the ESP-01 purchased from different sellers on eBay.
Not one of them was faulty.
Usually operator error.
