Hi, I'm trying to do a motorized equatorial mount for my telescope and I have ran into an issue when controlling the DEC and RA axis stepper motors with serial commands. Sometimes the motors stop moving in the middle of a command and the whole arduino "crashes" and I have to press the physical reset to get the motors moving again. This is more common when using negative number of steps for the motors. I'm using postep25-256 stepper motor controllers power by a Atx power supply. Im not sure if the problem is with the hardware or with the code.
#include <AccelStepper.h>
byte DIR_PIN = 2;
byte STEP_PIN = 4;
byte DIR_PIN2 = 9;
byte STEP_PIN2= 10;
AccelStepper RAmotor(AccelStepper::DRIVER, STEP_PIN, DIR_PIN);
AccelStepper DECmotor(AccelStepper::DRIVER, STEP_PIN2, DIR_PIN2);
long targetRA = 0;
long targetDEC = 0;
bool isGoTo = false;
Serial.begin(19200);
RAmotor.setMaxSpeed(1000);
RAmotor.setAcceleration(500);
DECmotor.setMaxSpeed(1000);
DECmotor.setAcceleration(500);
if (Serial.available() > 0) {
String command = Serial.readStringUntil('\n');
if (command == "R+") {
isGoTo = false;
RAmotor.setSpeed(1000);
else if (command == "R-") {
isGoTo = false;
RAmotor.setSpeed(-1000);
else if (command == "D+") {
isGoTo = false;
DECmotor.setSpeed(1000);
else if (command == "D-") {
isGoTo = false;
DECmotor.setSpeed(-1000);
else if (command == "RASTOP") {
RAmotor.setSpeed(0);
else if (command == "DECSTOP") {
DECmotor.setSpeed(0);
else if (command.startsWith("RA")) {
long newTargetRA = command.substring(2).toInt();
targetRA += newTargetRA;
RAmotor.moveTo(targetRA);
isGoTo = true;
else if (command.startsWith("DEC")) {
long newtargetDEC = command.substring(3).toInt();
targetDEC += newtargetDEC;
DECmotor.moveTo(targetDEC);
isGoTo = true;
if (!isGoTo) {
if (RAmotor.speed() != 0) {
RAmotor.runSpeed();
if (DECmotor.speed() != 0) {
DECmotor.runSpeed();
if (RAmotor.distanceToGo() != 0) {
RAmotor.run();
if (DECmotor.distanceToGo() != 0) {
DECmotor.run();
