I had issues using timer interrupts and the arduino standard servo library at the same time. Because I could not find a solution on the internet I wanted to share my solution here. So this might help someone with a similar but probably rare problem.
I am using the atmega2560 on my own pcb with the megacore boardsmanager. I am driving several stepper motors with s2209 stepper drivers and the accelStepper library and one servo with the standard arduino servo library.
My system is communicating through CAN bus (MCP2515). When I wanted to add a recurring status update (once a second) through a timer interrupt, my code would not compile anymore. I got this error message:
Error compiling for board ATmega2560.
Here my two functions which worked in the end. (setupHeartBeat() needs to be placed in setup(). )
void setupHeartBeat()
// initialize timer4
// * https://www.robotshop.com/community/forum/t/arduino-101-timers-and-interrupts/13072
// CPU frequency 16Mhz
// maximum timer counter value (256 for 8bit, 65536 for 16bit timer)
// Divide CPU frequency through the choosen prescaler (16000000 / 256 = 62500)
// Divide result through the desired frequency (62500 / 1Hz = 62500)
// Verify the result against the maximum timer counter value (62500 < 65536 success) if fail, choose bigger
noInterrupts(); // disable all interrupts
// reset the registers to 0 before making the relevant settings
TCCR4A = 0;
TCCR4B = 0;
TCNT4 = 0;
OCR4A = 62500; // compare match register 16MHz/256/1Hz (section 17.2.1 of atmega2560 manual)
TCCR4B |= (1 << WGM42); // CTC mode (Table 17-2 of atmega2560 manual)
TCCR4B |= (1 << CS42); // 256 prescaler (Table 17-6 of atmega2560 manual)
TIMSK4 |= (1 << OCIE4A); // enable timer compare interrupt (section 19.9.6 of atmega2560 manual)
interrupts(); // enable all interrupts
// Timer SETUP
ISR(TIMER4_COMPA_vect) // timer compare interrupt service routine
digitalWrite(ledPin, digitalRead(ledPin) ^ 1); // toggle LED pin
This was a test Skript to toggle an LED just like the Blink example.
I figured it must have had to do with a timer collision. So I looked through all the stuff I used which might use timers or interrupts. Initially I choose timer 4 because timer 0 is reserved for arduino standards like millis() and I read somewhere that timer 5 is used for servos in case of the atmega2560. When removing the servo library in a test script the timer interrupt worked as intended. Looking into the servo library it seemed that the servo library occupies all the 16-Bit timers that were left, which must have caused the error. I commented the relevant section (timer4) for my mcu and the problem was solved. So the LED blinks while a servo does its job.
Here the section of ServoTimers.h that I changed:
#elif defined(__AVR_ATmega640__) || defined(__AVR_ATmega1280__) \
|| defined(__AVR_ATmega2560__)
#define _useTimer5
#define _useTimer1
#define _useTimer3
// #define _useTimer4
// typedef enum { _timer5, _timer1, _timer3, _timer4, _Nbr_16timers } timer16_Sequence_t;
typedef enum { _timer5, _timer1, _timer3, _Nbr_16timers } timer16_Sequence_t;
Just because I was using the megacore boardsmanager I had to consider which servo library to change.
If someone knows a better solution to this issue than changing a standard library I would be happy for any suggestions.
