Issues with using rotary encoder
Hello,
I am currently completing a circuit that is a PID Temp controller. Everything is going good, (been working on this for quite awhile now!) except for one thing, I can’t get my rotary encoder to properly work!At first, I could not get through the menus I have set in my code (4 to be exact), but this has since been fixed after I removed one of my resistors that connected to my data and clk pins on my encoder(now both my data and clk are conected to one 10k resistor) . I had to do this because without it I could travel through my menus, but turning my encoder shaft did not increase or decrease values. After reconnecting the clk to the ONE lone resistor instead of 2, there is still one issue. My encoder only returns a negative value! Regardless of whether I rotate cw or ccw, the numbers just decrease more and more. Any ideas?
Here is a link to my schematic, encoder, and the next post will be the current code I am using. Any help is much appreciated.
https://www.electronoobs.com/eng_arduino_tut24_sch3.php
Current Code
/* Max6675 Module ==> Arduino
  • CS ==> D10
  • SO ==> D12
  • SCK ==> D13
  • Vcc ==> Vcc (5v)
  • Gnd ==> Gnd */
    #include <SPI.h>
//LCD config
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4); //sometimes the adress is not 0x3f. Change to 0x27 if it dosn’t work.
/* i2c LCD Module ==> Arduino
  • SCL ==> A5
  • SDA ==> A4
  • Vcc ==> Vcc (5v)
  • Gnd ==> Gnd */
//I/O
int PWM_pin = 3; //Pin for PWM signal to the MOSFET driver (the BJT npn with pullup)
int clk = 8; //Pin 1 from rotary encoder
int data = 9; //Pin 2 from rotary encoder
//Variables
float set_temperature = 0; //Default temperature setpoint. Leave it 0 and control it with rotary encoder
float temperature_read = 0.0;
float PID_error = 0;
float previous_error = 0;
float elapsedTime, Time, timePrev;
float PID_value = 0;
int button_pressed = 0;
int menu_activated=0;
float last_set_temperature = 0;
//Vraiables for rotary encoder state detection
int clk_State;
int Last_State;
bool dt_State;
//PID constants
int kp = 90; int ki = 30; int kd = 80;
int PID_p = 0; int PID_i = 0; int PID_d = 0;
float last_kp = 0;
float last_ki = 0;
float last_kd = 0;
int PID_values_fixed =0;
//Pins for the SPI with MAX6675
#define MAX6675_CS 10
#define MAX6675_SO 12
#define MAX6675_SCK 13
pinMode(PWM_pin,OUTPUT);
TCCR2B = TCCR2B & B11111000 | 0x03; // pin 3 and 11 PWM frequency of 928.5 Hz
Time = millis();
Last_State = (PINB & B00000001); //Detect first state of the encoder
PCICR |= (1 << PCIE0); //enable PCMSK0 scan
PCMSK0 |= (1 << PCINT0); //Set pin D8 trigger an interrupt on state change.
PCMSK0 |= (1 << PCINT1); //Set pin D9 trigger an interrupt on state change.
PCMSK0 |= (1 << PCINT3); //Set pin D11 trigger an interrupt on state change.
pinMode(11,INPUT);
pinMode(9,INPUT);
pinMode(8,INPUT);
lcd.init();
lcd.backlight();
if(menu_activated==0)
// First we read the real value of temperature
temperature_read = readThermocouple();
//Next we calculate the error between the setpoint and the real value
PID_error = set_temperature - temperature_read + 3;
//Calculate the P value
PID_p = 0.01kp * PID_error;
//Calculate the I value in a range on ±3
PID_i = 0.01
PID_i + (ki * PID_error);
//For derivative we need real time to calculate speed change rate
timePrev = Time; // the previous time is stored before the actual time read
Time = millis(); // actual time read
elapsedTime = (Time - timePrev) / 1000;
//Now we can calculate the D calue
PID_d = 0.01kd((PID_error - previous_error)/elapsedTime);
//Final total PID value is the sum of P + I + D
PID_value = PID_p + PID_i + PID_d;
//We define PWM range between 0 and 255
if(PID_value < 0)
{ PID_value = 0; }
if(PID_value > 255)
{ PID_value = 255; }
//Now we can write the PWM signal to the mosfet on digital pin D3
//Since we activate the MOSFET with a 0 to the base of the BJT, we write 255-PID value (inverted)
analogWrite(PWM_pin,255-PID_value);
previous_error = PID_error; //Remember to store the previous error for next loop.
delay(250); //Refresh rate + delay of LCD print
//lcd.clear();
lcd.setCursor(0,0);
lcd.print(“PID TEMP control”);
lcd.setCursor(0,1);
lcd.print(“S:”);
lcd.setCursor(2,1);
lcd.print(set_temperature,1);
lcd.setCursor(9,1);
lcd.print(“R:”);
lcd.setCursor(11,1);
lcd.print(temperature_read,1);
}//end of menu 0 (PID control)
//First page of menu (temp setpoint)
if(menu_activated == 1)
analogWrite(PWM_pin,255);
if(set_temperature != last_set_temperature)
lcd.clear();
lcd.setCursor(0,0);
lcd.print(“Set temperature”);
lcd.setCursor(0,1);
lcd.print(set_temperature);
last_set_temperature = set_temperature;
}//end of menu 1
//Second page of menu (P set)
if(menu_activated == 2)
if(kp != last_kp)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set P value ");
lcd.setCursor(0,1);
lcd.print(kp);
last_kp = kp;
}//end of menu 2
//Third page of menu (I set)
if(menu_activated == 3)
if(ki != last_ki)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set I value ");
lcd.setCursor(0,1);
lcd.print(ki);
last_ki = ki;
}//end of menu 3
//Forth page of menu (D set)
if(menu_activated == 4)
if(kd != last_kd)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set D value ");
lcd.setCursor(0,1);
lcd.print(kd);
last_kd = kd;
}//end of menu 4
}//Loop end
//The function that reads the SPI data from MAX6675
double readThermocouple() {
uint16_t v;
pinMode(MAX6675_CS, OUTPUT);
pinMode(MAX6675_SO, INPUT);
pinMode(MAX6675_SCK, OUTPUT);
digitalWrite(MAX6675_CS, LOW);
delay(1);
// Read in 16 bits,
// 15 = 0 always
// 14…2 = 0.25 degree counts MSB First
// 2 = 1 if thermocouple is open circuit
// 1…0 = uninteresting status
v = shiftIn(MAX6675_SO, MAX6675_SCK, MSBFIRST);
v <<= 8;
v |= shiftIn(MAX6675_SO, MAX6675_SCK, MSBFIRST);
digitalWrite(MAX6675_CS, HIGH);
if (v & 0x4)
// Bit 2 indicates if the thermocouple is disconnected
return NAN;
// The lower three bits (0,1,2) are discarded status bits
v >>= 3;
// The remaining bits are the number of 0.25 degree (C) counts
return v*0.25;
//The interruption vector for push button and rotary encoder
ISR(PCINT0_vect){
if(menu_activated==1)
clk_State = (PINB & B00000001); //pin 8 state? It is HIGH?
dt_State = (PINB & B00000010);
if (clk_State != Last_State){
// If the data state is different to the clock state, that means the encoder is rotating clockwise
if (dt_State != clk_State) {
set_temperature = set_temperature+0.5 ;
else {
set_temperature = set_temperature-0.5;
Last_State = clk_State; // Updates the previous state of the clock with the current state
if(menu_activated==2) { clk_State = (PINB & B00000001); //pin 8 state? dt_State = (PINB & B00000010); if (clk_State != Last_State){ // If the data state is different to the clock state, that means the encoder is rotating clockwise if (dt_State != clk_State) { kp = kp+1 ; } else { kp = kp-1; } } Last_State = clk_State; // Updates the previous state of the clock with the current state }
if(menu_activated==3) { clk_State = (PINB & B00000001); //pin 8 state? dt_State = (PINB & B00000010); if (clk_State != Last_State){ // If the data state is different to the clock state, that means the encoder is rotating clockwise if (dt_State != clk_State) { ki = ki+1 ; } else { ki = ki-1; } } Last_State = clk_State; // Updates the previous state of the clock with the current state }
if(menu_activated==4) { clk_State = (PINB & B00000001); //pin 8 state? dt_State = (PINB & B00000010); if (clk_State != Last_State){ // If the data state is different to the clock state, that means the encoder is rotating clockwise if (dt_State != clk_State) { kd = kd+1 ; } else { kd = kd-1; } } Last_State = clk_State; // Updates the previous state of the clock with the current state }
//Push button was pressed! if (PINB & B00001000) //Pin D11 is HIGH? { button_pressed = 1; } //We navigate through the 4 menus with each button pressed else if(button_pressed == 1) {
if(menu_activated==4) { menu_activated = 0; PID_values_fixed=1; button_pressed=0; delay(1000); }
if(menu_activated==3) { menu_activated = menu_activated + 1; button_pressed=0; kd = kd + 1; delay(1000); }
if(menu_activated==2) { menu_activated = menu_activated + 1; button_pressed=0; ki = ki + 1; delay(1000); }
if(menu_activated==1) { menu_activated = menu_activated + 1; button_pressed=0; kp = kp + 1; delay(1000); }
if(menu_activated==0 && PID_values_fixed != 1) { menu_activated = menu_activated + 1; button_pressed=0; set_temperature = set_temperature+1; delay(1000); } PID_values_fixed = 0;
Had to break it up in 3 parts, huge code. :confused:
Please edit your posts to add code tags, as described in the "How to use this forum" post.
It is always best to post the minimum amount of code that demonstrates the problem.
Hint: make sure you get the project components working separately, using simple example programs, before combining them into large, hard-to-debug packages.
