Issues with with Acebutton library and tracking double and long presses
Hi, I am currently using the AceButton library to track keypresses, and it worked fine untill i tried using code from they simultaneous keypress example, after which the double and long press do no register
code here:
#include <AceButton.h>
#include <stdint.h>
#include <Arduino.h>
#include <SPI.h>
#include <TimeLib.h>
#include <TimeAlarms.h>
#include <Servo.h>
#include <FlashStorage_SAMD.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "RTClib.h"
#include "chars.h"
#define TIME_24_HOUR true
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
uint16_t address1 = 10;
uint16_t address2 = 5;
AlarmId id;
Servo myservo;
RTC_DS3231 rtc;
unsigned long MOVING_TIME = 3000;
unsigned long currentMillis;
unsigned long previousMillis;
unsigned long elapsedMillis;
unsigned long lastButtonPressTime = 0;
int screenTimeout;
bool delay_state = false;
bool alarm_state = false;
bool alarm_triggered = false;
bool screenOn;
int hours = 0;
int minutes = 0;
int minutesNew = 0;
int hoursNew = 0;
const int reset_servo = 100;
const int release_servo = 0;
bool switch_state = false;
bool rtc_synch_state = false;
bool time_display_state = false;
String timeString;
String timeDisplayString;
char charArray[100];
String stringTest;
char delimiters[] = ",";
int synch_val[6] = { 0 };
using namespace ace_button;
const uint8_t BUTTON1_PIN = 1;
const uint8_t BUTTON2_PIN = 2;
const uint8_t BUTTON3_PIN = 3;
ButtonConfig buttonConfig;
AceButton b1(&buttonConfig, BUTTON1_PIN);
AceButton b2(&buttonConfig, BUTTON2_PIN);
AceButton b3(&buttonConfig, BUTTON3_PIN);
class ButtonHandler : public IEventHandler {
public:
  explicit ButtonHandler() {}
  void handleEvent(AceButton* button, uint8_t eventType,
                   uint8_t /*buttonState*/) override {
    uint8_t pin = button->getPin();
    switch (eventType) {
      case AceButton::kEventPressed:
          screenTimeout = 15000;
          uint16_t now = millis();
          if (pin == 1) {
            updateTime(-1);
          } else if (pin == 2) {
            mIsB1Pressed = true;
            updateTime(1);
          } else if (pin == 3) {
            mIsB2Pressed = true;
            switch_state = !switch_state;
            printUpdatedTime();
          if (checkBothPressed()) {
            handleBothPressed();
        lastButtonPressTime = millis();
      case AceButton::kEventLongPressed:
        if (button->getPin() == 3) {
          saveAlarmTime();
      case AceButton::kEventRepeatPressed:
        //if (time_display_state == false) {
          if (button->getPin() == 1) {
            updateTime(-1);
          } else if (button->getPin() == 2) {
            updateTime(1);
      case AceButton::kEventDoubleClicked:
          time_display_state = !time_display_state;
          time_display();
          screenTimeout = 30000;
          printUpdatedTime();
      case AceButton::kEventClicked:
            updateTime(-1);
            updateTime(1);
 /* if (time_display_state == true) {
    time_display();
  void handleBothPressed() {
  void time_display() {
  timeDisplayString = String(hour()) + "h" + String(minute()) + "m" + String(second()) + "s";
  display.clearDisplay();
  display.setTextSize(1);
  display.setCursor(0, 0);
  display.print("meow meow meow meow");
  display.setCursor(0, 7);
  display.setTextSize(2);
  display.setCursor(0, 28);
  display.print(timeDisplayString);
  display.setCursor(0, 56);
  display.print("ello there");
  display.display();
  void saveAlarmTime() {
    EEPROM.put(address1, minutesNew);
    EEPROM.put(address2, hoursNew);
    minutes = minutesNew;
    hours = hoursNew;
    timeString = String(hoursNew) + "h" + String(minutesNew) + "m";
    // display Alarm Time
    display.print("Alarm Time");
    display.setTextSize(3);
    display.print(timeString);
    display.print("Alarm Saved!");
    display.display();
    if (!EEPROM.getCommitASAP()) {
      EEPROM.commit();
  void printUpdatedTime() {
    if (!switch_state) {
      display.print("Modifying Minutes");
      display.print("Modifying Hours");
    display.display();
  void updateTime(int increment) {
    if (!switch_state) {  // Update minutes
      int oldMinutes = minutesNew;
      minutesNew = (minutesNew + increment + 60) % 60;
      if (increment > 0 && oldMinutes > minutesNew) {
        // Wrapped around forward
        hoursNew = (hoursNew + 1 + 24) % 24;
      } else if (increment < 0 && oldMinutes < minutesNew) {
        // Wrapped around backward
        hoursNew = (hoursNew - 1 + 24) % 24;
    } else {  // Update hours
      hoursNew = (hoursNew + increment + 24) % 24;
    printUpdatedTime();
private:
  bool checkBothPressed() {
    bool bothPressed = mIsB1Pressed && mIsB2Pressed;
    if (bothPressed && !mBothPressed) {
      mBothPressed = true;
      return true;
      return false;
private:
  bool mIsB1Pressed = false;
  bool mIsB2Pressed = false;
  bool mBothPressed = false;
ButtonHandler handleEvent;
void checkButtons() {
  static uint16_t lastCheck;
  // DO NOT USE delay(5) to do this.
  // The (uint16_t) cast is required on 32-bit processors, harmless on 8-bit.
  if ((uint16_t)(now - lastCheck) >= 5) {
    lastCheck = now;
    b1.check();
    b2.check();
    b3.check();
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  if (!rtc.begin()) {
    for (int i; i <= 60; i++) {
      pinMode(PIN_LED2, OUTPUT);
      digitalWrite(PIN_LED2, HIGH);
      digitalWrite(PIN_LED2, LOW);
    while (1) delay(10);
  delay(200);
  display.setTextColor(WHITE);
  myservo.attach(7);
  myservo.write(reset_servo);
  EEPROM.get(address1, minutes);
  EEPROM.get(address2, hours);
  hoursNew = abs(hours);
  minutesNew = abs(minutes);
  pinMode(1, INPUT_PULLUP);
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  buttonConfig.setIEventHandler(&handleEvent);
  ButtonConfig* buttonConfig = ButtonConfig::getSystemButtonConfig();
  //buttonConfig->setEventHandler(handleEvent);
  buttonConfig->setFeature(ButtonConfig::kFeatureClick);
  buttonConfig->setFeature(ButtonConfig::kFeatureDoubleClick);
  buttonConfig->setFeature(ButtonConfig::kFeatureLongPress);
  buttonConfig->setFeature(ButtonConfig::kFeatureRepeatPress);
  checkButtons();
  DateTime now = rtc.now();
  if (rtc_synch_state == false) {
    setTime(now.hour(), now.minute(), now.second(), now.dayOfTheWeek(), now.month(), now.year());
    rtc_synch_state = true;
  checkButtons();
  Alarm.delay(1);
  if (!alarm_state) {
    Alarm.alarmRepeat(hours, minutes, 0, MorningAlarm);
    alarm_state = true;
  if (millis() - lastButtonPressTime >= screenTimeout) {
    if (screenOn) {
      display.display();
      screenOn = false;
    if (!screenOn) {
      screenOn = true;
      //printUpdatedTime();
currentMillis = millis();
  /*if (millis() > 10000) {
    Serial.flush();
    Serial.end();
  static unsigned long lastTime = 0;
  static unsigned long serialTime = 0;
  if (Serial.available() > 0) {
    stringTest = Serial.readStringUntil('\n');  // Read until newline character
    serial_synch();
  elapsedMillis = currentMillis - previousMillis;
void serial_synch() {
  stringTest.toCharArray(charArray, sizeof(charArray));  // Convert String to char array
  char* ptr = strtok(charArray, delimiters);
  int index = 0;
  while (ptr != NULL && index < 6) {
    synch_val[index] = atoi(ptr);
    index++;
    ptr = strtok(NULL, delimiters);
  rtc.adjust(DateTime(synch_val[0] + 2000, synch_val[1], synch_val[2], synch_val[3], synch_val[4], synch_val[5]));
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(10, 0);
  display.println("Integers received:");
  // Display each integer value
  for (int i = 0; i < 6; i++) {
    display.print("synch_val[");
    display.print(i);
    display.print("] = ");
    display.println(synch_val[i]);
  display.display();
  display.display();
void moveServoToPosition(int target, int origin, int step) {
  while (origin != target) {
    origin += step;
    myservo.write(origin);
    Alarm.delay(20);
void MorningAlarm() {
  if (elapsedMillis >= 15000) {
    display.drawBitmap(0, 0, myBitmap, 128, 64, WHITE);
    display.display();
    moveServoToPosition(release_servo, reset_servo, -1);
    Alarm.delay(5000);
    moveServoToPosition(reset_servo, release_servo, 1);
    elapsedMillis = 0;
ps: not sure which category to choose
Got a link to it? Never heard of that one.
Here it is:
its been super great so far but yeah im probably doing something wrong
Wow. That's a lot just to handle button presses.
Sorry, most of the button handling libraries are pretty simple. I can usually figure them out pretty quick. I don't know if I can wade through all of that right now. Hopefully someone knows the library.
No worries! Would you know what libraries i could use that would handle simultaneous presses as well as double and long presses?
I don't. I usually handle my own buttons as needed. There are many out there but I really don't know which ones support what.
I'm sure someone here will know.
How many buttons? Do you have anything describing their actions?
its fairly simple:
three buttons, up down and select
up button can be pressed once to increment a value by one, and if long pressed, itll increment by one every 200ms
same for down
select button:
simple click selects if youre incrementing hours or minutes
long press saves the alarm time
simultaneous press of down and select would open serial communication to synch RTC via this java thingy i made
the issue is that when i added the check for simultaneous presses, the double and long press stopped working lol
